Why my external speaker doesn't work even it's connected with my system?
  • JMS THKR Apr 04, 2011
    You have a notebook computer, correct? Does the sound work with its built-in speakers? Have you tried using your external speakers with another computer? Thanks ~Jim :-)
    Problem Solver:
  • 16 Answers
Good day
Better check the speaker first for loose wires near the plug, then if its ok the second thing you need to check is you computer and by using a tester check if the ports for speaker is grounded or not. If it is indeed grounded better provide or buy another sound card.
Posted on Apr 04, 2011
I have a Sony Bravia KDL52S5100 , I connected my PS3 through HDMI and connected external speakers through the 3mm audio out on the side. It used to work fine but now the audio is not playing through my...
This information comes from the online reference book: Using the Sound Menu
Use the remote to open the TV menu. Select the Sound menu, and the "speakers" decision. From the two choices, "TV Speakers" tells the tv to use its built-in speakers. "Audio System" tells the TV to use an external audio system, and disables the internal speakers. Select "Audio System," and check to see if it works. If it still hasn't recognized that there is an external audio system plugged in, you may need to clean the stereo mini jack (3mm audio jack) with a small wooden toothpick or similar small diameter non-conducting device.
Feb 27, 2014 | Televison & Video
How to connect external speakers
Hello....I took a close look at your tv and. it doesn't seem to have an output for external speakers BUT...it does have line level outputs so it easily connected to amplified speaker systems or home theatre systems..If you want to expand your system...I would suggest a 5.1 channel surround sound system.....They are priced quite reasonably and will maximize your tv experience.....I hope this was helpful....PEACE...
Feb 08, 2012 | Sceptre X400BV-FHD 40 in. LCD TV
This t.v. doesn't have an audio output. How can I connect external/ sound speakers to it?
Hello!
you can use the Digital Coaxial port on the back of the tv.
use a mono RCA and connect it to a digital receiver eg:surround to get external sound.
(this only works with receivers with a digital input and will not give any sound
if connected do a analog input)
Sep 05, 2011 | Coby TFTV3227 32 in. LCD TV
I have an Onkyo tx ds777 model and I can only get sound to come out of the front speakers on direct mode. Stereo or any type of surround sound produces no sound at all. I have tried with my mp3 player...
You don't say if all speakers work with the setup procedure. THAT is step 1. Then try FM as it doesn't require any cabling. Then move on to more complex sources like external analog, then digital (and make sure to assign the ports).
Aug 22, 2011 | Onkyo TX-DS777
I have not sound
hi..
  • Check cables to speakers are properly connected
  • If External Speakers are used , check speakers are connected to an external power source.
  • Drivers for Audio ICs (Sound Card) are properly installed and working
  • Check Speaker Volume is not set to too low or mute
Mar 24, 2011 | Microsoft Windows XP Professional
I have a sharp aquos model number LC 60le81oun how do I set the settings to input 1 ?? I am trying to hook up external speakers and can't get sound if I hook it up straight to the tv but will get sound if...
Input 1 is an INPUT so you can't connect external speakers there and get sound from the television, which is what you are attempting.
Your two choices are the 3.5mm minijack hole that says AUDIO OUT terminal, which is under the Ethernet Terminal and the DIGITAL AUDIO OUTPUT terminal, which is under Input 7. If your external speaker system does not have a 3.5 mm minijack input to accept the 3.5 mm minijack cable then this isn't going to work. There are cables where one end is a 3.5 mm minijack and the other end is an RCA so you can try that and it MIGHT work. Other than that the Sharp televisions are known for not carrying sound over the fiber optic cables consistently so even if you bought a fiber optic cable and connected it between the digital audio output and a speaker system or sound bar there is no 100% guarantee it'll work. It is worth a try anyways.
Feb 09, 2011 | Sharp Televison & Video
My speakers don't work, I can plug in head phones or external speakers and they do work. it started after my son repeatedly pluged and unpluged the external speakers
There is a microswitch in the speaker jack of the system. It disables the on-board speakers when external speakers are connected. If sounds like that switch is stuck and the on-board speakers are staying disabled when the jack is removed.
Jan 30, 2010 | Dell Inspiron E1505 Notebook
Trying to connect external speakers
check with radio shack to see if they have something that will plug into the rear jack of the Bose...and has leads that you can wire to your speakers
May 27, 2009 | Bose Wave Music System CD Shelf System
How to connect Logitech X-540 to a laptop
buy a usb 2.0 type soundcard because your laptop does not support 5.1 surround speaker here is the link that will solve your problem http://www.amazon.com/Zalman-ZM-RSSC-External-Sound-Card/dp/B0001OZ2K8
Feb 10, 2009 | Logitech X-540 Computer Speakers
Magnavox projection tv hookup to external speakers
The external (audio out) connectors are intended for use with an external amp, not direct speaker connection.
Sep 02, 2017 | Televison & Video
Computers & Internet Logo
David Payne
David Payne
