Question about Vacuums
How to troubleshoot my cignaltv in the tv screen only the welcome to mediascape please wait for a moment.
My Shark Rocket won't turn back on.
Some models have a reset button on them if you have one push it all they way in and try that.
Feb 08, 2015 | Shark Rocket Self-Propelled Bagless...
How do I register my product?
Welcome to Shark Official Site
Phone Number
800-798-7398
Talk to a Human
Press 4, then 5.
Call Time
Average Wait: 7 mins - Mon.-Sat., 7 a.m.-11 p.m. ET
Nov 24, 2014 | Shark 12-Volt Cordless Hand Vac
Where could i buy a new switch and capacitor for my multimaster Msxe 636 - 2thanks
A capacitor is in in practice not nessecary but sometimes its only inside for radio interference suppression. remove it the switch is if you not know it also made to disassemble because of all its a realy dirt sensitive, but rarely defect i have never replace this part in all the time this year 20 years switches of this model al very little screwdriver is neccesary open it a little not neccesary to dismount it completely and spray wd40 inside wait a moment and blow the dirt carefully out remount and control always the AC cable for shure after.
Jan 28, 2014 | Fein Multimaster Rs - Msxe 636 - 2 Rs
Have lost my instructions for the above, please advise how I reset, thanks
Hi Mari,
Welcome to fixya!
You would need to supply the make and model number of your vacuum in order for someone to help you.
Please reply back. Thanks,
Handie Andie
Jul 23, 2011 | Vacuums
How do I restore my devices firmware for my zune 30gb
How to restore your Zune device software:------------
When you restore your Zune device software, the startup partition and the data partition are removed and rebuilt. In addition to removing the Zune device software, this process also erases all audio, videos, podcasts, and pictures that are stored on the Zune device.
Warning To restore the Zune device software, you must have a Windows-based computer that has an Internet connection. That computer must have the Zune software installed. And you must be able to connect the Zune device to a USB port on that computer by using a Zune Sync Cable. Do not perform the following steps if you do not have any one or more of these things immediately available.
After you start to restore the Zune device software, you cannot again use the device until you complete all the steps. You will not receive any confirmation or warning on the Zune device after you start the following procedure.
To restore the Zune device software, follow these steps:
1. Set the Hold Switch to unlocked.
2. Press and hold the Back button at the same time as you press and hold the top of the Zune Pad. When the Zune device begins to power up, release the buttons.
3. Immediately after you release the buttons in step 2, press and hold the following special button combination, depending on your Zune model:• If you have the 4GB Zune, the 8GB Zune, or the 80GB Zune, immediately press and hold the Back button at the same time as you press both the left side of the Zune Pad and the Play/Pause button. Continue to hold these buttons until your Zune device restarts and "Please wait" appears on the screen.
• If you have the 30GB Zune, immediately press and hold the Back button at the same time as you press both the left side of the Zune pad and the center of the Zune pad. Continue to hold these buttons until your Zune device restarts and "Please wait" appears on the screen.
Note "Clearing contents. Please wait" appears, followed by “Connect Zune to your PC."
4. After “Connect Zune to your PC” appears, connect the Zune device to the computer that has the current Zune software installed, and then update the device to the current Zune device software.
----------- Click this link directly for more troubleshooting:-- http://support.microsoft.com/kb/944909 -------- If error problem while restoring then click this link below:-- http://support.microsoft.com/kb/945278 ---------- Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 03, 2010 | Vacuums
Can you help me change the Sensor in my Sebo Auto X-1
do you still need help with this, or has the moment passed? If you still want help, please state why you think the sensor needs changing.
Nov 17, 2009 | Sebo Automatic X1 Bagged Upright Vacuum
Hoover steam vac dual v makes humming noise and nothing else.
Is the overfill valve (the yellow thing) in the waste container stuck in the up/full position? Maybe it just needs to be rinses well to avoid it being stuck and shutting off the vacuum portion of the cleaner.
Oct 09, 2008 | Hoover Steam Vac Dual V w/ SpinScrub...
How to replace dyson dc07 brush belt
Hi - You can download the manual by clicking the link underlined in blue below:
dyson dc07
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 15, 2008 | Vacuums
Bissell 5200 Upright wet/dry vacuum
go to Bissell.com and u can print the manual out solved. you welcome
Aug 30, 2008 | Bissell 5200 Upright Wet/Dry Vacuum
Vacuums Logo
187 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
