Question about Zanussi Washing Machines
Have just moved into a flat with a zanussi turbodry 1000 washer /dryer, WDA 1055 W I need a manual please.
SOURCE: Manual
have got the washer/dryer, and no instructions on how to use , please help get my cloths clean and dry. thanks
Posted on May 21, 2007
  • 1294 Answers
SOURCE: candy alise 1000 formula stainless
Click on brand name (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
Or click on "washing machines" above to find your brand.
Posted on Jan 01, 2008
SOURCE: Zanussi jetsystem Turbodry 1200
Hi, Ive moved into a new flat, and I have a zanussi jet stream 1400 turbo dry front loader. Of course, no instructions were left on how to use it. I cant seem to get anything but soaking wet clothes, no spin cycle, and certainly no turbo dry.
Can you tell me where I could download a users manual?
Posted on Feb 10, 2008
  • 121 Answers
SOURCE: Instruction Manual
it can be found here dont think thats the full model number but
http://www.whirlpool.co.uk/app.cnt/whr/en_GB/pageid/pgsrvifuhome001
Posted on Mar 03, 2008
  • 1294 Answers
SOURCE: Zanussi manuals
Click on 'washing machines' (below FIXYA) on this website, & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, u hv your manual on line. If available that is....................
Rate me pl if helped...................
Posted on Apr 04, 2008
Where can I find a manual?
You may view/download the manual here.
Mar 14, 2012 | Zanussi Washing Machines
Zanussi jetsystem turbodry 1600 wjs1665 w is not heating the water
More than likely the heater element has failed.
This is located at the rear of the washer drum.
It means removing the rear half of the cabinet to access it.
Mar 29, 2010 | Zanussi ZWF1430W Front Load Washer
Zanussi jetstream 1000 turbodry door remained locked this morning. Emptied machine through filter port and cleaned filter. Door opened ok. Machine will now not start any program although the power light...
the drain pump is jammed .........remove the filter at the bottom left of the machine get down and look in the hole and you will likeley find something in there if not you need a new pump
Feb 26, 2010 | Zanussi FJS1225W Front Load Washer
Washing Machine trips circuit breaker when Drying
This will be the dryer heating element needs replacing.
Hope this helps.
Jan 21, 2009 | Zanussi WDA1055W Front Load Washer / Dryer
What is E 40 on Zanussi Turbodry 1200?
E40 indicates the doors not closed properly. Sometimes it can be the lock itself or the main control board
Nov 24, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi Turbodry 1200 spin problem
if this washer is used alot then it will more then likely be the carbon brushes which u will need to take the lid off undue 4screws out where it joins front to the back screws at the back to the bottom and 1screw either side of the bottom where the panels join together behind a little cap which will have an hole in the middle of it to get it out u will then be able to get to the motor to replace the carbon brushes
Nov 22, 2008 | Zanussi ZJD1219 Front Load Washer / Dryer
Zanussi WJS 1397W
possibly a foreign object in pump.
tilt backwards at a good angle and remove pump. i find the easiest way to do this is to undo the 3 screws round the periphery of the pump
Jul 11, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi turbodry w 1042 w
probably short to earth on the dryer elements. to check. take top off, disconnect dryer elements then run on dry program. if the trip stays in, then you have identified the fault
May 16, 2007 | Zanussi FJS1225W Front Load Washer
Manual
Jan 24, 2007 | Zanussi ZJD1219 Front Load Washer / Dryer
It appears that you may have a faulty door interlock or a faulty PCB. pcb is not really a DIY job as some boards require proramming on certain versions. Regards Advisor
Oct 30, 2006 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
