Question about Midland 1001Z 40-Channels Base CB Radio
I have a Midland 1001Z 40-Channels Base CB Radio and a Magnetic-mount CB antenna. 29" stainless steel whip and 6" spring. About 46" high overall. All bought from /www.thesource.ca in Alberta canada. I hooked up a SWR meter to it to match them up. The end problem i had was when i was adjusting the antenna to get it at 2 or below. I cant get it to come down from 3. Not sure what I should do from this point. Can i cut down the antenna or replace it ? should i change it to a single antenna that is a Heavy-duty dual trucker kit with 1.2m (4') 1/4" wave helically-wound antenna, 20-gauge copper wire, factory-tuned ?
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 98 Answers
Try Grounding it better. Its supposed to equal 8.5 ft.(102 inches) but the coil may make that in all.You can clip like 1/8 inch off at time until it goes 2.1 Swr. Thats a good standard. 1.5 SWR is desired. If it don't have a coil with it that may be the problem. You could turn it into a 8.5 ft. antenna by buying a 102" inch whip to screw into the base of your antenna, it depends if it holds or not. You could build you a matcher like this with a solder gun+solder and 2 resistors. Get you a box with 2 female cb antenna inputs. Drill a hole for both Cb antenna inputs into box. Place them into holes screw nuts down snug. Run a copper wire inside to both grounds or a plate somewhat. Run a thick gauge copper wire from center cb ANT INPUT(2) to other input of ANT INPUT(1). Solder 2 100 ohms in parallel from input to Ground. If you could take apart your radio(eliminating the box idea). Just Solder 2 (100 ohm) resistors to your Antenna output then put it back together. 50 OHM MATCH HERE Is the main idea. I've used 75 OHM Tv coax and reduced SWR.
Posted on Apr 04, 2011
Do i need a certain antenna?
The fiberglass provides no ground plane area for the antenna and radio waves. Your Standing waves (aka: SWR or Reflect) are probably very high. I suggest mounting the antenna on the cab of the truck. You "could" try aluminum tape on the cap and mount the sheilded side of the coax to it somehow. Without a ground plane much of the RF Power of you CB will be reflected back to the Final Output Transistor(s) (Final or Finals), overheat it and possibly damage and burn it/them out. If you are just running the CB without an amplifier(Linear or sometimes called a box), a magnetic mount antenna should work fine and be less of a problem than permanently mounted antennas. That's a plus when going into a parking garage. Even if you decice to get an amplifier at a later date, you should be able to use it with the magnetic mount antenna as long as the antenna you but is rated for several hundred watts, you Standing Waves are Low, and the amplifier doesn't put out more power than the antenna is rated for. I hope this helps.
Apr 17, 2014 | Midland 1001Z 40-Channels Base CB Radio
How do you turn up the power on a midland 1001z
You can't "turn it up". You may be able to carefully compress or spread the coil windings near the Final Output Transistor (Q 14 a 2SC 2078) to get a bit more out of it but it isn't a real "Big Time" CB like the Cobra 29's. Sorry.
Feb 13, 2014 | Midland 1001Z 40-Channels Base CB Radio
A Midland 1001z with a 103 whip ant. They are both NEW. When I turned on the radio all I heard was like the power sound but no volume! I even tried a exturnal speaker! Nothing! Any IDEA's????
Is the mic good? If there is a problem with the mic, it will not put the radio into receive mode and you will hear nothing.
Also make sure the radio is not on PA mode, or make sure the squelch isn't too high.
there are also times when it is really quiet on the radio and you won't hear any static. keep this in mind.
Sep 26, 2010 | Midland 1001Z 40-Channels Base CB Radio
I cant be heard when i speak through my midland 1001z cb radio?
hello have you checked the swr on the antenna have you checked the output of the radio with a power metre it should be reading 4watts max if yes problem might be the microphone make sure there are no wires shortening in the mic socket entering the radio and check inside the mic aswell
cheers and goodluck
Jun 26, 2010 | Midland 1001Z 40-Channels Base CB Radio
Is it my CB antenna or something else
First off, Midland makes a fine radio. Make sure your squelch is turned all the way down to receive distant signals (down meaning counter clockwise). The through the glass antennas are not the best thing in the world. I personally use a 102" whip and a 6" spring on a modified mirror mount. It is installed on the tailgate side of the tool box. The TX and RX is amazing. Wilson and K40 make great antennas also.
Jul 07, 2009 | Midland 1001Z 40-Channels Base CB Radio
S it my CB antenna or something else
take a 9 foot wire to the bad radio put the the wire into the center of the ant jack a see if you can hear your buddy glass mount ant are ****.
9 foot whip is best in car/truck 4 foot fiberglass cophased are next 4 foot are next mags are ok but over time and moving around they will mess up you paint
MIdland no sound s/rf dancing
may be u burned yr final transistors...check if yr antenna is well grounded and try just after this to transmit, if the indicator is not stable on the green area when you are in "am" modulation stop to try and bring to the assistance
rgds Stefano
Dec 17, 2008 | Midland 1001Z 40-Channels Base CB Radio
How far can that midland 1001z radio transmit.And recieve.
Running most any regular cb, including this one barefoot (with no kicker), having a good antenna, set up with a good ground plane or a no-goundplane antenna, good coax; basically everything in good working order, you can usually bank on about 4 to 5 miles crisp and clear, and at least 6 to 10 miles fairly clear. Of course the further out you get it will start to fade out.
Some radios do better than others, but those are the general numbers I have seen in my years of experience.
Dean Pitts
Rollin CBs
Mt. Vernon, TX
Apr 27, 2008 | Midland 1001Z 40-Channels Base CB Radio
Midland 1001Z 40-Channels Base CB Radio Logo
115 people viewed this question
Top Midland Radio Communications Experts
AnyMHz.com
AnyMHz.com
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
