Question about Saws
Have a Ryobi Model BTS16 10" Table saw was using
rowdy45176
  • 2176 Answers
SOURCE: Table saw won't turn on.
that reset is breaker and I would think that it should click when reset. I looked at a breakdown and the part number for the breaker is OLSL list 2.16 and they are in stock at Searspartsdirect.com If you have a volt ohms meter I would check the electrical starting at plug end of cord thru the breaker. Make sure you unplug tool before attempting. I would also take a look at the brushes for excessive wear and sawdust buildup. Let me know if I can help more
Posted on Jan 19, 2009
  • 80 Answers
SOURCE: How to change blade on 10" Craftsman table saw?
you need to grab the blade with something.maybe some pliers(if you are not going to refurbish blade) and loosen the nut in the center of the blade. i think it is a left hand thread(cw to loosen) because of the rotation of the blade. if the nut is on the left when looking from the front it is probably left handed. make sure it's unplugged and wear leather gloves so you don't get cut. install in reverse...
Posted on Jan 20, 2009
  • 86 Answers
SOURCE: ryobi bt 3000 table saw belt installation diagram
The BT3000 actually has TWO v-belts! Here's a link at the end of this solution to an exploded diagram. Basically you have a major disassembly, but it really isnt that complicated.
More great info on the BT3000 is available from the web site http://bt3000.com/
I have a BT3100 saw, and it is a good tool, but does require attention in maintenance procedures, but Ryobi did outline the necessary steps in their manuals. The above website also has the owner manual if you need one.
  1. Unplug saw
  2. Remove the blade
  3. Lower mechanism all the way to the bottom
  4. Flip over saw and lay on it's top
  5. Remove the blade guard panel opposite the motor
  6. Unbolt the motor assembly and remove the belt cover
  7. Replace the broken belts
  8. Re-assemble (be careful not to cross-thread the bolts in the aluminum housings!)
http://bt3000.com/Manuals/BT3000-Parts-Manual.pdf
Posted on Mar 22, 2009
SOURCE: saw will not run
I had the same problem several months ago with a craftsman (shut down during a long rip), and the reset switch had tripped but did not actually pop out. I tested everything in the line between the power supply and the motor, and found out that the reset switch was not conducting. I was able to reset it manually before re-installing it into the saw, and it's been fine ever since. I'd test that before you start pulling the motor out, it would be a much easier fix if the switch was just sticking.
Posted on Apr 28, 2009
SOURCE: How do I change the blade on my Ryobi 10" table saw?
The manual is posted on line. Changing the blade does not require turning the saw over, blocks of wood or vice grips. The advice listed above is potentially damaging to your equipment.
http://www.raygirling.com/ryobi/ryobi.htm#settadj
Posted on Sep 24, 2009
How to lower toptable of a ryobi table mitre saw tms-305
http://ryobi.co.za/product/table-and-mitre-saw-combination-1800w-tms-305/
this saw has a 2 inch capacity. if you have say a 3 inch piece you use 2 passes of 1-1/2 each
regards
sir dana
Apr 25, 2017 | Ryobi Saws
My Ryobi table saw won't start, any ideas?
There is an overload protection breaker on the bottom left. Check it and the power switch with a meter to make sure they work.
Sep 29, 2015 | Ryobi Bts10 Table Saws
I am looking for a part for my 10" Ryobi table
http://www.ereplacementparts.com/ryobi-table-saw-parts-c-7931_7954.html
http://www.searspartsdirect.com/
Probably other places too.
Here are the results of a google search for you.
http://www.google.com/search?source=ig&hl=en&rlz=&q=ryobi+table+saw+parts&aq=1&aqi=g10&aql=&oq=ryobi+tabl
Hope this helps!
May 09, 2011 | Saws
Motor for table saw RYOBI RTS20
the link below is about a Recall on this saw. you should look it over
http://www.protoolreviews.com/news/industry/ryobi-rts20-table-saw-recall
this next link is for possible parts for the saw, although i would think you should be able to get the part from Ryobi
Jan 18, 2011 | Saws
Ryobi 10 in Portable Table Saw modl #BTS12S won't turn on
Look for a trip switch on the saw motor
Nov 02, 2009 | Saws
I need an operators manual for my ryobi 9'' band saw (model bs901). Where can I get one?
if this is an older saw you would have to contact Ryobi at 1-800-525-2579 and request one be sent to as a PDF, I can't find it online at the site I use.
Oct 08, 2009 | Ryobi Saws
I am replacing power switch on ryobi table saw BTS20R
Hi, I have got a Ryobi ETS-1525SC Table Saw. Suddently it stop and as far as I can see the machine is ok but the blad is not moving. Could some one help please
Oct 02, 2009 | Saws
Saws Logo
188 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
