Question about Ariston Technologies Dishwashers
I have an old ariston K LS 61 S - yesterday at the end of a cycle i could not get the door open! Tried doing another cycle and even turning off at the mains and back on again Door is firmly closed at the centre where the locking mechanism is
icansurf
  • 72 Answers
SOURCE: Door lock stuck
If the mechanism is jammed, you might have to remove or loosen the entire front panel to reach back to the back side of the lock and work on it.
Posted on Feb 25, 2007
SOURCE: PDW7880G-No power to control panel. Just stopped at the end of drain cycle
Solution Found!!
Checked for power to dishwasher. According to the manual, shutting off the breaker for more that 30 seconds resets the dishwasher. It did!!! The dishwasher works fine now. THANKS!!!
Posted on Feb 20, 2008
  • 1073 Answers
SOURCE: The door will not stay closed, even during cycle
replace the door lock switch part 8182634
Posted on May 03, 2008
SOURCE: maytag dishwasher MDB5600awb
Please help, I have a MDB5601AWW, It will not start. It only makes a litter sound click and lights the green light on. That is.
Thank you for help
Posted on May 09, 2008
SOURCE: subaru door mechanism
okay this how you do it you lift the handle up on the car and you move it back and it should go back only when the handle is up
Posted on Jul 06, 2008
How to unlock the door
Lamp M flashes slowly when the appliance is switched on and
a waiting instructions and at the end of a cycle, indicating that the door can be opened. It flashes quickly when the door should not be opened. A steady light means the appliance has accepted the selected programme.
24967037-ineink0kisfnom0atbkujjcx-3-1.jpg If you correctly use the appliance then defective can be interlock, wiring or board.
If the door is constantly locked then you can access to interlock by removing the top cover of washing machine.
Dado
Aug 17, 2014 | Ariston Technologies Ariston AWD12 Front...
Ariston AWD 121 will not complete cycle
It sounds like the dial is broken. You can call your local appliance store and order the part for cheap. Installation is easy enough to do yourself if you would like. Just make sure the power is disconnected.
Jun 30, 2014 | Washing Machines
First, the machine started to do a strange noise during the cycle. At the end of the cycle, I couldn't open the door because there were too much water in the machine, so it means that the cycle...
Check for a blockage. Or try to buy a washing machine cleaner and put it inside without clothes and run the machine alone. This will help. If it won't then you will need to get a new machine
Nov 11, 2012 | Hotpoint Ariston AWD129 Front Load...
Door will not open after cycle finishes
I had similar problem, but never found the cause, ended up spinning washing again and again until I could open door. Control system replacements are expensive , almost as much as a new machine.
Mar 11, 2017 | Zanussi ZWF14070 Front Load Washer
Hotpoint Aquarius waher dryer
possible blockage ' filter or could aslo be water coming back from the sink if drain hose too low , you may need to raise this....
Nov 13, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Ariston Elixia LI68 Duo dishwasher will not start
Same problem , i fixed by opening the door compleet then cleaning the bottom of the door with a kitchen cleaning paper that may do it afther that disconect the power compleet whait 1 minut connect it al again and it should work , don't ask me why this cleaning action i just found it out
Feb 05, 2009 | Ariston Technologies Dishwashers
Ariston dishwasher
I have the same problem. I found that a termostatic probe switch off the machine, you can disassemble the door and clean the ventilation holes
Aug 31, 2008 | Ariston Technologies Ariston FO98P...
Ariston 6kg washing machine
Do you have the "easy iron" feature on? If so, the clothes will stay in water until you manually rinse it.
Oct 07, 2007 | Ariston Technologies AWD 121
Washing Machine Door will not open
it is poss that you pressure system has not released, and this can keep the door closed. Unplugging it will not cure this fault. It is also poss that you have a blocked filter or waste. Unfortunatly has you are older people I would call an engineer
Jun 23, 2007 | Ariston Technologies AW129NA 16 Lbs Front...
Dishwashers Logo
157 people viewed this question
Top Ariston Technologies Dishwashers Experts
Electro Med Services...
Renee Knafel-Bullock
Are you an Ariston Technologies Dishwasher Expert? Answer questions, earn points and help others
