Question about Video Game Consoles & Games
How do u put the x clamps back on the mother board
  • 22 Answers
Im guessing you're talking about an original 360?
What you want to do is place the X clamp so it is on the bottom side of the board. Attach the sides using a screwdriver to prop it on the 4 pieces.
http://www.x-clamp-fix.com/pics/tutorial/xclamp640.jpg
Posted on Apr 04, 2011
I took out the mother board without labeling it. now i mixup how to put back the cables.
Google the system board type - and look for images of similar mother boards. Probably there are a few where the cables show providing hints where to insert what cable.
Jun 26, 2011 | Computers & Internet
How do I change the inverter board on a ge monogram 36" built in, side by side refridgerator ZISB360DX
it's pretty easy,pull off the old board and put the new board on the same way the old board came off,wires go the same place.are you sure that's your problem,GE has had bad mother board problems and everything that runs on that goes through the board,i've changed over 50 mother boards and have never seen a bad inverter board only bad mother boards but i'm not there to see why you say the inverter board is bad.good luck with your machine and changing the inverter board is easy but it's around 300 dollars,unplug the machine and open the cover and check the mother board it's also on the back,back wall with a few screws holding the cover on and check to see if there's any short marks on the board or the metal frame where the board is mounted,i would say that's your problem but like i say you must of checked it with your meter to know it's the inverter board.good luck
Apr 22, 2011 | GE Refrigerators
My asus a8v deluxe does not boot at all. a while back i flashed the bios with a newer bios version from the asus website which i installed on a floppy disk.during the flash installation it had an error on...
delet the old bios and start fresh, check the battery in mother board ,check the fuse, make sure your metal tower is clamed all the way down on black chip on mother board.if not it will over heat very quickly and shot down and no but not least check your coolent fan and also make sure thats clamped all the way down.
Mar 18, 2011 | ASUS A8V Deluxe Motherboard
Hi we have a GE fridge PIE23NGTFKB and the temp is fine for two days then changes as if the fridge has gone in to defrost mode then comes good in a day or so then starts all over again
if this happens again unplug the unit from the wall to see if this will reset the mother board if not then more than likely its the mother board in back of the frig with a axcess cover on it, unless you see frost on the back panel of the freezer and is does not go away then I would check the defrost heater and or defrost bi-metal clamps on the evap suction line behind the panel of the freezer.
Feb 13, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
There is a continious beeping sound from mainboard; when on. sonds like from the bios or cmos. any ideas Thanks
most likely it is a sound from mother board
- try to reseat the mother board(take out and put it back in)
- then check if still getting a sound/beep
- if not good!
- if yes replacement mother board suggestion
TIP:
- try other mother board on your computer first to check if you can hear a wierd noise
Mar 31, 2010 | Lenovo 3000 J Series 1.80G VBE PC Desktop
I need a CPU mount for a SoYO P45 Dragon motherboard
check for any store in your local area that sells refurbished computer parts there you can buy a clamp that will suite you mother board
Nov 21, 2009 | Computers & Internet
Keep freezing up
There are 9-12 solder balls under your G.P.U's hot spot
that are disconnecting from the mother board (Delamination)
due to insufficient clamping force of the MS X clamp.
The Fix is to Clamp the chip down to the board with screws washers.
Burn it in, ( over heat the G.P.U. only) which reestablish all
connection , this will take care of 99% of most the problems.
Jul 06, 2009 | Microsoft Xbox 360 Console
Pennies
penny trick is when u tape 3 pennies together and put them on bottom of memorychips on the mother board total of twelve pennies for four memory chips on bottom this is done to fix the 3 red lights just a temp fix but i would recommend doing the x-clamp replacement better success
May 25, 2008 | Microsoft Xbox 360 Console
Ribbon cable for keyboard on Toshiba Satellite
check thye pins may be there bent try to straighten them then check if thats the actual port it should fit in cos iv worked some number of laptops it has only a one way drive in thats is things can only go one way.
thanks
May 18, 2008 | Computers & Internet
Video Game Consoles & Games Logo
29 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
