Question about Fellowes Powershred P-55C Shredder
P55C fellowes schredder repair center - Fellowes Powershred P-55C Shredder
NEED TO REPLACE PLASTIC/VYNAL GEARS FOR A P55C FELLOWS SHREDDER
Have you owned it for less than a year? The warranty on all parts is one year from purchase and 3 on the blades.
If its out of warranty then you have to choose between trying to find parts or replacing the whole unit.
You can buy a refurbished one from Fellows for $45.00 at this link.
Refurbished Shredder
I doubt you are going to find parts for your shredder but even if you could I suspect the will cost about half of what the whole refurbished one costs
Oct 16, 2013 | Office Equipment & Supplies
My shredder wont turn on
If you have been using continuously the thermal overloat ha possibly operated. If this is not the case then it is possible the motor has a fault, or. the little LED sensor in the schredder has failed and not allowing sensing of paper. If either of these two faults are cause then a repair shop will be able to confirm if it worth repairing
Apr 20, 2012 | Office Equipment & Supplies
How do u apply the fellowes cd scratch remover in bottle?
from the center out...or outside to the center. do not do circles that just makes the laser follow the scratch and report the error. ..
Dec 05, 2009 | Fellowes FEL99763 CD/DVD Scratch Repair...
Fellowes C-420-c, paper jam light always on
try calling Fellows at 1-800-955-0959 for help and to find nearest service center.
Nov 25, 2009 | Fellowes Powershred 420 Shredder
Only one Shredder roller turns
you have a broken gear.try calling 1-800-955-0959 to see if Fellows makes replacement parts for that model.
Nov 24, 2009 | Fellowes OD1200 Shredder
Broken plastic gear tooth - Fellowes P55-C Shredder
I suggest using Belzona (metal compound). Mix it with its hardner, paste it over the broken gear (dont worry if it gets over a couple of other gears. Let Belzona sink and dry (4-5hours). Get a Dremel drill with a fine blade on it and cut accurately where the teeth are meant to be. Voila, you have fixed your gear.
Sep 13, 2008 | Office Equipment & Supplies
Fellowes Shredder Parent Part # 38605
If this unit is worth it to you, you can build your own gear.
Here is a link to get plastic repair materials to make plastic parts. This site also will have materials for repairing plastics.
Another possibility is to search Ebay for a unit like yours which has other problems. Never can tell... it may be there.
Make sure you ask for the model of the unit in your search (on the NET as well. The serial in this case is not needed.
Jul 02, 2008 | Office Equipment & Supplies
Fellowes 220c-2 repair manual
call Fellowes Customer Service 1-800-945-4545
Oct 16, 2007 | Fellowes 220C-2 Shredder
Fellowes Powershred P-55C Shredder Logo
93 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
