Question about Magellan Roadmate 2036 GPS Receiver With Preloaded maps of United States; Canada and Puerto Rico
The screen is stuck on the map from the last route i was taken....all the functions work and ive tried resetting it and unplunging it and reset to defauts.....but the screen stays the same...frozen
Software to upgrade your version of the software, you can solve the problem. http://www.realmapa.com
Posted on Aug 26, 2012
Screen says there are no detailed maps found that support routing
If your gps receiver says there are no detailed maps found that supports routing, do not panic, it is a minor problem that can be solved by either reseting the gps receiver. If reseting the gps does not solve the problem, then it means you will have to back up your maps, format the gps receiver and restore your maps back on the gps receiver.
Hope this information helped you.
Dec 23, 2010 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi 250W stuck on "Loading Maps..." screen. I know it wasn't a clever thing to do, but I dragged a file (a map i think) into the Nuvi's internal memory via Windows Explorer. Now every PC i have...
Try the reset, and if that fails, download the web updater from the garmin site and try that route.
Master reset will erase all way points or favorites and will restore your unit to the default factory settings.
  1. Start with the unit OFF and unplugged from power
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON
  4. Release the power button when the device powers ON
    • You will see a new message: Do you really want to erase all user data?
  5. Remove your finger from the touchscreen when this message displays
  6. Touch Yes
Bill 39c203c.gif Learn from your failures or you will fail to learn.  Theory: you understand why it should work but it doesn't
Practice: it works but you have no idea how
   ALL That is necessary for the Triumph Of evil is That good men do nothing.
Aug 30, 2009 | Garmin nuvi 250W GPS Receiver
Have ex display route 66 maxi need to update maps also have laptop which is asking for bios password have taken bat out still cant get passed bios pasasword advent laptop
u need to remove the power supply from mother board and battery even in order to reset bios password... try it out, it'll definately work...
Aug 25, 2009 | Computers & Internet
When I power up laptop screen is blank
You may have a burned video adapter.
A trouble shoting setp you can try is attatching an external display and seeing if that works.
Also try the function F5 key combo. I think that is the ASUS mapping to switch display output.
Aug 04, 2009 | ASUS Eee PC 900 Notebook
Map update notice screen
HOLD THE ON OFF SWITCH DOWN AND youPRESS RESET This should reset it back for t
Jun 20, 2009 | Garmin StreetPilot C330 GPS Receiver
Calibrating wont work.. i want to reset it.ive cleaned the screen n taken out the battery...help!!!!
You need a new Touchscreen. FAIRLY EASILY to replace.
http://site.powergamingparts.com/RepairNdsl.html
May 27, 2009 | Nintendo DS Lite Console
Etrex vista will not display any map
I had the same problem for months. i don't know what part of this worked or if it was a fluke that it finally worked. I downloaded the newer firmware for the garmin and installed it ( http://www8.garmin.com/products/webupdater/ ) then tried adding maps, that didn't work, then tried 3-4 times resetting the garmin, and each time tried adding maps and it didn't work - turns out I wasn't really resetting it (I think) it appeared that the successful reset was holding down the clicker key and the pages key while starting up, and keeping them held down for a long time (15 seconds?) - there was no sign that it was resetting except a faint illumination, then when I let go of those 2 keys it went through the setup sequence. the only way I knew it had finally reset was when the page came my pointer was in the middle of the united states. I had repeatedly tried resetting before and the pointer/map page came up to where I was last at, so it hadn't really been resetting. I'm very displeased that it took 5-10 tries to get this to work and this happened on 2 units.
I reloaded the maps after it had properly reset and they actually display and are on the map list!
this is the second etrex unit ive had this problem with, and the first one was just as flaky - taking many reset events (see master and super master reset on other etrex threads at this site)
Mar 15, 2009 | Garmin eTrex Vista GPS Receiver
Gps navigation screen is paralyzed--all other screens are working
hi did you install the software straight to your route 66 maxi using route 66 sync software ? if you did try downloading it to your computer then transfer it on to the memory card using a card reader
Jan 07, 2009 | Route 66 MAXI Car GPS Receiver
Audio turn by turn instructions not functioning -Magellan Roadmate 2000
I am having this same problem. My Magellan was frozen on an old route. I had to completely reset it. This deleted all of my old saved information. Since I did this, it has been mapping correctly, but there is no audio. The volume is turned all the way up. Can you help me fix this problem?
Dec 27, 2007 | Magellan GPS
Digital Tv is stuck on a channel
I have found the solution at last :)
Put the TV in standby and press these buttons in order
Info, Menu, Mute and Power on.
You will then see a hidden menu, on line 12 select reset
Bingo :)
Oct 23, 2007 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Magellan Roadmate 2036 GPS Receiver With Preloaded maps of United States; Canada and Puerto Rico Logo
138 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
