Question about Brother MFC-7340 All-In-One Laser Printer
My Brother MFC7340 Fax Machine will not send faxes it has a busy signal always and a busy signal when someone tries to fax me.
  • 2 more comments
  • lesliejoy Apr 04, 2011
    Hi Shane080
    I turned the machine off for about 45mins but it is still doing the same thing. It is only about 10months old. It is on Fax and has Standard on it. The Dial up signal goes OK but then it goes to a busy signal. I tried 3 fax numbers but still the same outcome. Regards Lesley
    Hi shane080, This fax machine is not connected to a computer, it is only connected to the power plug and the telephone line. Is there anything that needs to be changed in the set up programs? Regards Lesley
  • lesliejoy Apr 07, 2011
    There is no telephone receiver on this machine so it cannot be the receiver is off the hook. I do not know about an answering machine on this unit. If "hook" has been pressed how do I cancel it?
  • Seth Crosby Mar 13, 2013
    I called Canon about this. They had me tweak the transmission start speed (Menu>FAX setting>TX settings>TX start speed). It was too fast. Set it to 4800. Then it was too slow. Clicked it up to 7200 and now it works!! TX Start Speed should not be too fast or too slow.
    Sergeant:
  • 236 Answers
The busy signal that you hear when trying to send is likely from a receiver-off-hook tone.
The busy signal that someone gets when trying to fax you is due to a receiver being off-hook.
Suggest you check the following...
1. that the handset of the external telephone on the fax line is properly placed in its cradle.
2. if "hook" has been used/pressed on the fax machine, that it has been properly cancelled.
3. if there is an answering machine on the same fax line, that it is not off-hook / answering.
Posted on Apr 04, 2011
  • Bill Yee Apr 10, 2011
    Quoting you: "It is on Fax and has Standard on it. The Dial up signal goes OK but then it goes to a busy signal. I tried 3 fax numbers but still the same outcome. Regards Lesley"... Your comments indicate that your Fax is on a dedicated fax line that has nothing else on it. So your machine would automatically answer every call as a fax and you would choose Fax Only as your receive mode. The Standard you mention refers to the resolution. Of all the possible configurations, this is the simplest and should be straight-forward. I am assuming now from your comments that no changes were made to your fax machine when all of a sudden, the problems with the busy signals began. So I can only assume the problems likely stem from something that happened to your dedicated fax line...
    1. the MFC-7340 comes set for Tone dialing service.
    2. your dedicated line was switched to Pulse dialing service (rotary)
    3. dialing using Tones on a Pulse dialing line will not break dial tone which eventually goes ROH
    (Receiver Off Hook) which sounds like a very fast busy - click on the following link to hear it...
    http://www.soundsnap.com/node/50407
    4. you can change the MFC-7340 to do Pulse dialing instead of the default Tone dialing as follows...
  • 668 Answers
You need to reset the memory, since previously you have dialed some number, which is not able to connect. So restart the printer. Unplug the printer for 10 minutes and plug back the power to the printer.
Hope this helps.
Shane
  • Shane Apr 04, 2011
    Please ensure the set up for receiving fax and sending fax is done properly.
    Click the Start button , click All Programs, and then click Windows Fax and Scan.
    To use Fax view, at the bottom of the left pane, click Fax.
    Click the Tools menu, and then click Fax Settings. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
    Click the General tab, and then, under Device name, make sure that the modem is selected.
    Under Send/receive options, make sure that the Allow the device to send faxes check box is selected.
    Make sure that the Allow the device to receive fax calls check box is selected, and then choose how to receive faxes:
    To manually answer phone calls as incoming fax calls using Windows Fax and Scan, click Manually answer, and then click OK.
    To have Windows automatically answer phone calls as incoming fax calls, click Automatically answer after X rings, select the number of rings after which Windows can try to answer phone calls as incoming fax calls, and then click OK.
    Hope this helps.
    If you still face problem let me know.
    Shane
Why do we get busy signal for every fax we send?
Check the lines and check the connection, usually it's a problem from your side, There is a nice troubleshooter in the manual so check it out: Brother Intellifax 1270e manual
Jul 23, 2014 | Brother IntelliFAX 1270E Plain Paper Fax
I have a Brother fax machine. When I dial a number to send a fax, there is a noise on the speaker in addition to the fax dialing and it defaults into a busy signal. What should I do?
The number u are dialing is either busy or someting is wrong with the phone line thus not connecting to the other party. The fax set up may be confiqurated wronlgy.
Regards
Sep 28, 2010 | Brother Office Equipment & Supplies
The fax machine will not faxes, it prints out as busy.
make sure the cable is in the LINE socket not the TEL socket as this will stop connection..
Jul 20, 2010 | Brother IntelliFax-2820 Laser Fax
Trouble faxing
Check the fax line with a regular phone and dial a fax number to listen for fax tones.
May 31, 2009 | Samsung SCX-5115 Fax Machines
Can't recieve a fax.
Unplug power cord. Plug back in. Call your fax machine from cell phone and listen for fax tones.
Sep 17, 2008 | Brother IntelliFAX 3800 Plain Paper Laser...
Not connecting to fax out
Do you have a DSL or other digital phone line?
Jul 10, 2008 | Brother IntelliFax-2820 Laser Fax
Incoming fax
Do you have the manual? Check your smart ring feature.
Sep 05, 2007 | Brother IntelliFAX 2800 Laser Fax
Sending a fax without a manual
Here's the user's manual http://www.brother-usa.com/Data/Documentation/Fax/User/UM_FAX775.pdf
Aug 17, 2007 | Brother IntelliFAX 775 Plain Paper Thermal...
Brother MFC-7340 All-In-One Laser Printer Logo
2,353 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
