Question about Saeco Magic De Luxe Espresso Machine
Saeco magic deluxe - no water flow
Instead of flowing through coffee into cup, the water pours out of machine. I'm assuming there is a problem with tubes or gaskets. Is this fixable at home?
  • kdfurlong Aug 11, 2008
    My machine poured out a little coffee this morning into my cup (about 3 or 4 tablespoons) but then the rest leaked out of the machine elsewhere. I have the descaling set to factory default (we actually have soft water) and descale it whenever it tells me its time. I opened the side door and tried to take out the internal compartment, but it is stuck/locked in place. The water seems to heat OK but just won't flow out of the nozzles.
    I had been using the manual slot for pre-ground coffee a lot lately, so I cleaned out any excess coffee out of the shoot. I thought maybe too many grounds were preventing the machine from releasing the old grounds and thus causing it to back up. This didn't help, however. The water only leaks when you try to make a cup, so its as if the water just can't get through to the right place.
  • babamarkos Oct 23, 2008
    every time i descale it seams the grind need to be adjusted..it made one coffee and the the water did not come out any more and went into the dispenser.. if found the the nozle where the water meets the coffee if you unscrew it has a small glass ball and a spring not sure if this has anything to do with it..
    thanks in advance
  • 20 Answers
Take out the drip tray, take out the dregs container, open the side door, press the button and pull the brew unit out. On the front of it is a small pippe which should have a rubber o-ring on it. This must mate with the coffee dispenser unit which is the two holes the coffee normally comes out of. Check that the dispenser is in the right place. Behind where the coffee comes out is a knurled knob that you unscrew to remove and clean the dispenser. Undo it, remove the dispenser and clean it. Replace it, ensuring that it is pushed right back in the slot when you tighten the knob (don't tighten "too" hard). Is the water clean or "coffee" that comes out? If it is clean, it is likely the o-rings that seal the small tube from the boiler to the brew unit. There is also a nozzle on the boiler outlet that has two o-rings, but if those need changing you need some patience and skill to replace them.
Good luck.
Posted on Aug 16, 2008
  • 515 Answers
How old is your machine?
Do you descale it regulary?
I think it´s your boiler that has to be replaced
Posted on Aug 05, 2008
My saeco magic coffee machine says ventilate.How do I do this?
Hi
If it is just a Magic Delux, open the steam knob, without pushing the steam button. If its a Magic Comfort you have to push the button with the drops on it and it will flow water.
Apr 10, 2010 | Saeco Magic De Luxe Espresso Machine
I have saeco incanto deluxe coffee machine,ventilate msg appears
Check the end of the steam nozzle, make sure it is not blocked. If not then with the knob open for hot water cycle push in on the knob if that works then the tap rod assemble or the steam valve needs to be replaced.
Feb 20, 2010 | Saeco INCANTO DELUXE Espresso Machine
Water pump in Saeco Magic Deluxe
If you haven't cleaned the brew group, or decalcified the unit I would start there. This is something I do every 4 to 6 months (or anytime I notice the flow of coffee to start to slow down). This normally restores the flow to the original flow level. If you have already done these things you may want to give Saeco support a call and see what they suggest. They are extremely helpful, although very difficult to get on the phone as the phone system they use is horrible and hangs up after you hold more than a certain amount of time.
Dec 03, 2009 | Saeco Magic De Luxe Espresso Machine
Poured water into coffee grinder
easiest thing to do is put it outside to dry or use a blow drier to dry it up, it should be ok
Jul 01, 2009 | Saeco Magic De Luxe Espresso Machine
I have a Saeco Magic De Luxe. I am having a problem intermittent
Could be the pump not providing enough pressure to force the water through the coffee. When using beans or preground, can you still hear the pump function?
Jun 30, 2009 | Saeco Magic De Luxe Espresso Machine
Water pump?
If you could brewer coffee or get hot water out of the steam wand then it could be the one way valve on the bottom of the water tank. If you are running the pump output into a glass then it is probably scaled up in the boiler.
Jan 02, 2009 | Saeco Magic De Luxe Espresso Machine
Diverting all of the coffee flow into the bottom tray rather than the cup.
You might want to check and clean the coffee outflow spout ( the adjustable double spout on the outside of the machine) . If it is all plucked up that might be the cause.
Sep 09, 2008 | Saeco Vienna De Luxe Espresso Machine
How do I descale the saeco magic deluxe coffee machine?
Try this:
Standard descaling
Switch off the machine.
Pour a descaling product into the water tank.
Switch the machine on to the programming mode(see below). Place a large container under the steam/hot water dispensing tube and open the steam/hot water knob slowly, turning it counterclockwise.
Turn on the machine by pressing the main switch and let the descaling product flow out of the dispensing tube for approx. 1 min.
Close the knob again.
Turn off the machine with the main switch and let the solution take effect for approx. 5 minutes.
Repeat this procedure two or three times, to allow all of the descaling product in the water tank to flow out of the dispensing tube.
As soon as descaling has been carried out, rinse the tank thoroughly and fill it with fresh water.
Switch on the machine and let fresh water (approx. 2 l) flow out of the steam/hot water dispensing tube in order to rinse away residue.
The machine is now ready for operation.
When the machine is on, the warning light switches off automatically, by pressing the steam selection button for at least 5 seconds.
To enter the programming mode, turn the machine
off with the main switch.
Press steam , espresso coffee and the
main switch at the same time.
Release the buttons.
Hope this will help you.
/Mirran
Aug 16, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco vienna deluxe espresso machine
adjust the water flow look for a knob that turn right to left minus less water plus more water
Jun 08, 2007 | Saeco Vienna Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
357 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
