Question about Scotsman CSW45 15" Ice Maker with 26 lb. Ice Storage Capacity, 44 lb Ice Production per Day, Drain R...
Scotsman CM3 ice machine. Model CME506AS-1H. Relocated to new job site. 1st the full bin sensor was saying full even though empty. Cleaned sensor problem fixed. Now water runs compresor startes but ice ppots don't get cold. RAn thru clean cycle and still no ice. New simptom is the refridgeration lite flashing a code. Try reset to no avail. What next get a service tech?
  • Farley Redfield
    Farley Redfield May 11, 2010
    DOes the light have any sequence to the flashes? counting 1-15 or some such?
How do i get a service manual?
The bin sensor eyes need to be cleaned or replaced. First remove the front cover then remove the white plastic ice deflector shield. Now you should be looking at the evaporator plate look down you will see the water sump tray full of water in that tray is a black plastic grate that when the ice is harvested it drops and hits the tray keeping it from falling in sump tray PULL it OUT. now just behind the sump where the ice falls through opening on the left and right sides is where the ice full bin eyes are you can pull them out side ways there is plenty of wire so you can pull them up to where you can clean them with a soft cotton cloth with scotsman cleaner. Now for a manual goggle scotsman service manuals you can get a PDF file.
Apr 28, 2014 | Scotsman Ice Maker 600LB CM3 30inW...
Scotsman sce275a-1h
Replace the din full sensors this will let the ice machine start up if the sump tray dose not start to fill up with water look at board to see if water full light is on if so replace water sensor that is in water sump tray. if light is not on then check to see if you are getting power to water valve if you are getting voltage to valve then check water filter dose it need to be replaced. now never use any thing other than ice machine cleaner made for ice machines it has to be nickle safe are you will dammage the evaporator plate.
Jan 23, 2014 | Scotsman Ice Machine - 290lb...
clean the ice sensor on either side of the ice platen and just past the water trough. gently pry the sensor on each side out of their plug and work wiring out until you can get to the two led lights and clean scale off. limestone scale builds up and blocks the sensors.
Dec 27, 2012 | Scotsman Ice Maker 600LB CM3 30inW...
Scotsman ice machin model cme506AS-1F BIN FULL AND UNT OFF
Pull and clean bin full sensors or replace them then power unit back up.
Jun 26, 2012 | Scotsman Cooled Modular Contour Cuber Air...
Scotsman ice maker cme1356 remain on harvest
Check bin full sensors make sure that the wires are making good contact on the board and make sure they are working run your hand between them you should see the bin full light come on the board if not replace the bin full sensors. If the light comes on then replace the board.
May 25, 2012 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Scotsman 500 cm3 ice machine
Remove all molex connections and check for corrosion. Clean the connections and retry.
Jul 17, 2008 | Scotsman Ice Maker 600LB CM3 30inW...
Scotsman CSW45 15" Ice Maker with 26 lb. Ice Storage Capacity, 44 lb Ice Production per Day, Drain R... Logo
761 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
