How to repair my vcr I have a faulty tape in the machine and unable to remove it
  • reg_d Apr 10, 2011
    Hi Guru
    I had several tries following your solution but didnt get anywhere so I guess I'll have to take it to an expense repairer and hope he can fix it.
    Thanks anyway
    Yours -- Reg.d@mail .com
    Genius:
  • 1,044 Answers
I hope your vcr is not built in with TV. It is separate from TV. If it is not then you have to call a technician to open the vcr and remove the faulty tape. If it is separate then open the top cover by unscrewing the screws on the side. These can be located very easily. Remove the top cover gently. Look for the gear toothed wheels which load/eject the tape. You can do so by switching the power button on and off. Switch of the power to vcr. Move the toothed wheels by hand to bring the tape up if you do not want the tape to get damaged. When the tape comes up then give it a gentle push so that it can eject itself. If not, repeat the process again. If you see the magnetic tape is stuck or entangled with moving wheel the cut it,remove it gently. Make sure that you do not touch or damage the video head. Once removed, you can fix the top cover.
Posted on Apr 04, 2011
Testimonial: "That sounds like great advice, I'll give it a try and get back to you if it works. Many thanks Reg."
  • Adarsh Saroj Apr 10, 2011
    I have done it number of times even in the DVD players to remove the disc. Unfortunate that you did not succeed. May be my instructions were not that clear. For my information please let me know how the technician removed the tape.
    Regards/Guru 55555
VHS tape is stuck in the machine. How do I remove it?
This is often a frustrating problem but if you feel you can handle it go ahead with the following, otherwise get professional electronics help. If you have tried to eject the tape and tried other obvious ways to extract the tape and nothing has worked then you can remove the top cover and manually remove the tape. It is not that hard to do most of the time. First unplug the power cord from the wall outlet. You do not want to get a short or get shocked or zapped. Just unscrew the screws holding the cover in place and set the cover aside. Look at the tape to see where it is hung up. If you need to push the tape around so you get it off the posts or otherwise free up the tape, then gently do so until you free the tape from the tape transport. Sometimes this is all you need to do to extract the tape. You may be able to push out the tape from the VCR at this point. If you can get all the magnetic video tape back into the cassette but the tape simply will not come out then place the cover back onto the VCR, plug the VCR into the wall outlet, power on and try to eject the tape now. Sometimes this works. If all else fails, take the VCR into a electronics repair shop and have them remove the tape for you. They may tell you the VCR needs repairs also so this does not happen again.
Mar 31, 2011 | Sony SLV-N750 VHS/S-VHS playback VCR
How to remove jammed tape from philips dvdr3320v combi
Remove the top lid from your machine, next see if you can carefully remove the tape "without pulling" if it won't come out, cut the tape with scissors and make sure all tape particles are removed, sometimes by removing the defective tape the vcr will function. Now if it won't work after that point you probably have a mechanical issue which will require a repair shop.
Dec 22, 2010 | Philips DVDR3320 DVD Recorder/VCR
When I put a vcr tape into the machine, I get an Err on the time space. The tape gets jammed and I have to throw the tape away. Why is this doing this and how do I fix it. The machine that I have is the...
The tape gets jammed and wrinkled because the capstan is moving faster than the rollers - the speed control circuit is faulty, the processor detects that and signals it in the screen . There's nothing you can do, the fault is in the IC that governs the speed and it must be replaced, and this can be done only by the repair shop of a dealer - they are the only ones that have the circuit for replacement.
Either take your VCR to one of them or get a new one (it might be cheaper).
Sep 27, 2010 | Sylvania (SRDD495) DVD Player/VCR
Video tape is stuck in vcr. Is there a way for me to remove it?
G'day
When a tape gets jammed in your VCR, it generally relates to
  1. the loading mechanism has a broken part
  2. the tape itself may have a problem, or has chewed in the unit and cannot be rewound back into cassette shell.
  3. the VCr itself is unable to reel the tape back into the cassette shell
Firstly... DO NOT REMOVE THE BACK!!! In the case of 1, you will need to perhaps get a tech to look at it for you if you wish to retieve the tape, and then also have the mechanism to load fixed. First try poking your finger in the front tapeflap(you will NOT be electrocuted!!! it is perfectly safe to do this), and gently rock the tape upand down whilst attempting to eject. This can sometimes assist with getting them out. If you do, check for small child "posted" things inside the machine :) Seen alot of that over the years.
If the tape itself has a problem,it may be possible to rew/ff the tape back into the shell to allow it to eject. Try this before anything else. Worse case, off to see a tech to assist with removal.
If the VCR is unable to reel the tape, thats no ff or REW, and or no takeupof the played tape back into the shell, again, you will need a tech to first remove the jammed tape by reeling it manually back into the shell, and also repair the mechanism.
There is not much use in telling you to take the lid off... there are dangerous voltages inside and also no user serviceable parts. VCR transport are complex,and a layman would not be able to repair it nor remove the tape successfully without damage to the unit, tape of both.
Take it to an expert. Costs will vary depending on what the problem is from min charge to a tape removal/appraisel of the problem to $120-150 to replace the load mechanics. Be prepared for loss of the tape. They cannot often cannot be salvaged if it has become nangled in the unit.
Hope this advice has assisted in your quest for answers. Happy to answer any questions that you may have about this. Please dont forget to rate. Cheers
regards
robotek
Jun 21, 2010 | Quasar VV-2002 20 in. TV/VCR Combo
My vcr does not play the tape
Take the cover off & have a look at the cassette carriage, it may have came out of alignment, ie it is taking the tape at an angle or there maybe a fault with the carriage motor switch. when you put the tape in so far the carraige activates a switch which starts the loading motor to draw the tape in. It could be there is no supply voltage to this switch or the loading motor might be faulty, this is why the VCR says there is no tape as the tape has not been able to load into the machine. A repair centre should be able to fix this fault quite easily.
Jul 07, 2009 | Philips Televison & Video
Re: Model PV-4523S
You can try cleaning it with a VCR tape cleaner to see if the pinch roller have build up on there. It could be that the motor isnt feeding the tape up against the recording heads properly and may need an adjustment. If you can take the top cover off, you should be to see what the problem is by the way the tape is being inserted into the machine.
Jul 29, 2008 | Panasonic PV-V4021 S-VHS VCR
Tape stuck in vcr
Carriage has been set out of alignment due to improper extraction- need to repair or replace the carriage loader...accordianman
Jul 10, 2008 | Symphonic SC319C 19 in. TV/VCR Combo
Error Code F03
What worked for us when we saw F03? Taking the toothbrush out of the VCR! I kept resetting the unit and nothing worked. Finally, I decided to see what would happen if I stuck a tape in. It wouldn't go in because of the toothbrush! I took it out, reset the unit again and it was fixed.
Maybe the error is not F03, but FO3 meaning there is a FOREIGN OBJECT stuck in the VCR.
Feb 13, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
Toshiba M-752 Video Casette Recorder
Take the top cover off, and see if there is an obvious reason for the no-eject, as in tape spooled out and wrapped around something. Next, is the tape drawn back into the tape housing? Under normal operation this is done before eject. A defect in the tape itself, or in the VCR mechanicals can cause a no "pull in" condition. Otherwise, you could carefully try to assist an eject- push eject, lift lightly on the tape. Sometimes the entire carriage mechanism can be removed with tape in place, but often, screws holding this in place are obscured by the tape, and, if carriage is gear driven, proper gear alignment must be reestablished. This can be a tricky problem, getting tape out without damaging anything, especially since late VCRs are made rather fragile to start with.
Aug 14, 2007 | Toshiba W522 VHS VCR
Tape is stuck in the machine, and I really need the tape!
sounds like vcr has dumped its eprom settings,you will have to bring it to sony dealer to have it repaired or you can manually remove tape by useing the loading motor and turning it by hand
Nov 17, 2006 | Sony SLV-SE730 VHS VCR
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Electro Med Services...
