I have toshiba m400 i want to install window xp with bootable window disk i dont have dvd drive i attached a usb dvd drive with this. i am unable boot it from that disc. now tell me how can i install it. thanks a lot.
    Problem Solver:
  • 12 Answers
Here's the instructions on this site: http://www.tomshardware.com/reviews/windows-pocket,1113.html
Posted on Apr 04, 2011
Pendrive install ridata
Bootable USB guide, here we assume that you are using either Vista or Windows 7 to create a bootable USB.
1. Insert your USB (4GB+ preferable) stick to the system and backup all the data from the USB as we are going to format the USB to make it as bootable.
2. Open elevated Command Prompt.
To do this, type in CMD in Start menu search field and hit Ctrl + Shift + Enter.
Alternatively, navigate to Start > All programs >Accessories > right click on Command Prompt and select run as administrator.
3. When the Command Prompt opens, enter the following command:
DISKPART and hit enter.
LIST DISK and hit enter.
Once you enter the LIST DISK command, it will show the disk number of your USB drive.
In the below image my USB drive disk no is Disk 1.
4. In this step you need to enter all the below commands one by one and hit enter.
As these commands are self explanatory, you can easily guess what these commands do.
SELECT DISK 1 (Replace DISK 1 with your disk number)
CLEAN
CREATE PARTITION PRIMARY
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
(Format process may take few seconds)
ASSIGN
EXIT
Don't close the command prompt as we need to execute one more command at the next step. Just minimize it.
5. Insert your Windows DVD in the optical drive and note down the drive letter of the optical drive and USB media. Here I use "D" as my optical (DVD) drive letter and "H" as my USB drive letter.
6. Go back to command prompt and execute the following commands:
D:CD BOOT and hit enter. Where "D" is your DVD drive letter.
CD BOOT and hit enter to see the below message.
BOOTSECT.EXE/NT60 H:
(Where "H" is your USB drive letter)
7. Copy Windows DVD contents to USB.
You are done with your bootable USB.
You can now use this bootable USB as bootable DVD on any computer that comes with USB boot feature (most of the current motherboards support this feature).
Note that this bootable USB guide will not work if you are trying to make a bootable USB on XP computer.
Oct 03, 2013 | Computers & Internet
Tip
How to create a bootable USB using Vista or Windows 7
Having a bootable USB is very essential, especially if you are a Netbook user. Using bootable USB to install an operating system (OS) not only makes the installation faster, but also saves a DVD.Creating or using an USB drive to install Windows operating systems is very easy if you follow the below mentioned steps.
Here we assume that you are using either Vista or Windows 7 to create a bootable USB.
2. Open elevated Command Prompt. To do this, type in CMD in Start menu search field and hit Ctrl + Shift + Enter. Alternatively, navigate to Start > All programs >Accessories > right click on Command Prompt and select run as administrator.
3. When the Command Prompt opens, enter the following command:DISKPART and hit enter.LIST DISK and hit enter.Once you enter the LIST DISK command, it will show the disk number of your USB drive.
4. In this step you need to enter all the below commands one by one and hit enter. As these commands are self explanatory, you can easily guess what these commands do.
SELECT DISK 1 (Replace DISK 1 with your disk number), CLEAN, CREATE PARTITION PRIMARY,SELECT PARTITION 1ACTIVE,FORMAT FS=NTFS(Format process may take few seconds),ASSIGN,EXIT.
D:CD BOOT and hit enter. Where "D" is your DVD drive letter.CD BOOT and hit enter to see the below message.BOOTSECT.EXE/NT60 H:(Where "H" is your USB drive letter)
7. Copy Windows DVD contents to USB.You are done with your bootable USB. You can now use this bootable USB as bootable DVD on any computer that comes with USB boot feature (most of the current motherboards support this feature).Note that this bootable USB guide will not work if you are trying to make a bootable USB on XP computer.
on Dec 18, 2010 | Computers & Internet
Asus n50vc won't install windows 7 from USB device
Try bringing up the boot menu (it will say what key to press on the splash screen) and choosing the usb. if that does not work try moving ports.
Jan 16, 2013 | ASUS N50Vc-B3WM PC Notebook
Remove password bios toshiba portege m400 please!
Here is a guide toremove windows passwordwith Windows Password Recovery Tool Professional from http://www.windowspasswordsrecovery.com/Step1: Download and install Windows Password Recovery Tool.
Step2: Burn CD/DVD/USB Flash Drive. (Namely it is to burn a Windows password reset disk.)
Step3: Set the target computer boot from CD/DVD or USB.
Step4:Remove the forgotten Windows passwordwith the burned CD/DVD/USB. Then log on to Windows without a password.
Of course, you can also finish Windows password remover if you have a password reset disk in advance. That's also an easy solution.
Source: http://www.windowspasswordsrecovery.com/windows-password-remover.htm
Aug 13, 2012 | Toshiba Portege M400 PPM40U01000E Tablet...
My notebook toshiba q10 n250, dont have backup and or Any operating system ( after a format) so i tryed to install windows xp via an usb bootable, but now the bios dont recognize the hard disk (maybe...
You need the install program from Toshiba and should be able to download it from the Toshiba site. The drivers, OS and programs were most likely on the D:\ drive, before it got formatted.
Jun 04, 2011 | Computers & Internet
How do i create a bootable usb flash drive from a windows bootable disc? basically my daughter has messed up her netbook and it now requires a fresh install, i have a windows disc but the netbook has no cd...
I have just done this and USB is OK, there is a link below. http://wiki.eeeuser.com/windowsxpusb
But I assure you it is much easier to get a USB to DVD dongle attach a DVD, Using a SATA DVD, works great. set to Boot from USB-DVD and it will be simple, also download the EEEPC XP disk, it install a special XP for the EEEPC and has all drivers.
There is the torrent links for the ISO, download and burn to DVD If you already have it then it is all moot.
http://www.torrentreactor.to/torrents/download/1585860
http://dl5.torrentreactor.net/download.php?id=1732907&name=Windows+XP+sp3+Lite+for+ASUS+eee+PC
Feb 11, 2010 | ASUS Eee PC 901 Notebook
Installing windows xp on toshiba protege 500
When you power up press F2 or "del" to enter in bios .
then set first boot option to as your dvd drive so then put winxp disk then it boot with it.
Jun 21, 2009 | Toshiba Portege M400-S5032X Tablet PC
Vista to windows xp prof., toshiba satellite l305-s5894
hello , friend its very easy to do that, steps are
1. insert bootable cd/dvd xp prof. cd.
2. But be cautious because the xp profsn doesnt contain the drivers for ata hard disk. so pls find on net the drivers for ata hard disk drivers, also update it in bootable xp profsnl dvd . recreate bootable dvd of xp with advanced bootable xp,
3. or find it from your friend with latest updates requirement. and do from it.
4. Boot from tht cd and start the installation.
5. once it i completed install all video, audio e.tc. drivers.
6. if you dont have that drivers pls download it from toshiba site by entering the toshiba serial no
Mar 25, 2009 | Toshiba Satellite L305-S5894 Notebook
How to install xp 32 bits in compaq presario cq50
2. But be cautious because the xp profsn doesnt contain the drivers for ata hard disk which is for laptop. so pls find on net the drivers for ata hard disk drivers, also update it in bootable xp profsnl dvd . recreate bootable dvd of xp with advanced bootable xp,
Mar 25, 2009 | Compaq Presario Notebook
Computers & Internet Logo
David Payne
David Payne
