Question about Stoves Sterling 1100E Stainless Steel (Electric) Kitchen Range
We have a stoves double oven 707mf. We have turned it off at the wall when we turned it back on instead of coming up with 0's it has come up with flashing 8's and will not allow us to do anything with the cooker. Can you help?
Had some problem. Point a hairdryer at the top vent just below the control panel. There's a circuit board on top with a dodgy heat sensor. With the oven on get it hot enough and it will come back to life. Take out the oven and open the top and point the hair dryer right at it if the vent isn't working.
Posted on May 26, 2011
  • Andy Bereza Dec 16, 2011
    Richard. Same here . . and your strange fix worked for me to reset the oven to normal . . but only temporarily and the fault comes back after a while. Each time the warm air (at RH end of the board). Did you identify the component to to be replaced on the board for a permanent fix?
  • Richard Dec 16, 2011
    For a while that fix worked for us, as long as the oven wasn't turned on... but then we started to wake up to the familiar click click click in the kitchen.... sorry we never did fix it we just got a new oven instead. I was told though by someone who worked at the company that the problem was with a thermal sensor on the board, so that might be a starting point. Good luck.
Same with us today 16 May 2011. If anyone can help please phone 01704530660. Thanks. NOT about Sterling but couldn't find 707MF.
Posted on May 16, 2011
  • samread May 16, 2011
    Comment about Sterling looks silly but I couldn't post until I found a valid product - and there wasn't a 707MF.
I have just had the same problem with my 707MF - Did you manage to resolve?
Posted on Apr 25, 2011
We have a GE electric stove with a JDP 39 oven element which has burned out. How do we get the bottom heating element out to replace it?
UNPLUG the stove or turn off its breaker.
Inside the oven, trace the element back to the rear wall. There should be one screw on each side next to where the element goes through the rear wall. Unscrew that screw on each side and pull the element toward you - it'll come easily, bring its wiring behind it (this is why there must be NO power to the stove!). Detach the wiring from the element... DO NOT allow the wires to pull back through the wall, or you'll have to pull the whole range out to retrieve them.
To install the new element, just reverse that procedure.
Jul 31, 2014 | Ovens
My frigidaire gallery series oven made a popping noise while heating up dinner in oven and now the whole oven is not working
Hello jnjpelli - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart the unit. If the oven does not turned on, then more than likely there seems to be a power supply issue. Also try checking the breaker and the power connections located on the back of the range. If any of these suggestions prove to be ineffective, connect with a professional to accurately pinpoint any potentially more serious issues
Jan 19, 2013 | Frigidaire 30 in. Electric Gallery Series...
I got a GE double wall oven and when I turn the oven on code F1 comes on
Hi
F1 Error indicates a bad control board and the control board (electronic control) should be replaced to solve this issue. Hope this helps...please post back for further assistance.
Daniel
Aug 06, 2011 | GE Built-In 24" Double Electric Wall Oven
The stove top works fine .Both of the ovens stopped working and there is no digital display where the clock is . Where is the fuse located for the ovens
Normally, there is a master switch on the wall near the oven. This is in turn is usually fed from its own fuse/breaker on the consumer unit. I suspect this has bblown.
Jul 18, 2011 | Stoves 720EF Electric Double Oven
I want to remodell my kechen and I want to get the oven out
there is ashut off valve coming out of your floor or wall shut that off the handle shoud be crossway if the valve is staight in line it is on, if you don,t have a shut off behind your stove it might be down stairs, or you might have to shut off the main when that is shut off loosen your line and move it out,[reminder], when you instsall the stove and hook the line back up and you turn your gas back on take some soapy water and check the lines for any leaks thank you.
Dec 21, 2009 | Magic Chef 9112 Gas Double Oven
I have a whirlpool gas oven Model sf385peew 0 and iam changing it from gas to propane how do you adjust the flame and also do we have to do anything to the stove we bought the conversion kit but it dont...
turn the gass off
find the gas valve on the back wall
unscrew the top
and replace the top with the part from the kit
if you have orrifices you will need to replace those
they go straight down the center of the burner
Oct 03, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Cant work oven!
I have the Stoves 720EF manual stored on the BT Digital Vault which might help. If you want a copy of it, supply an email address and I will give it access.
Also someone else has said that if you speak to Stoves nicely they may be able to send an electronic version of the manual instead of the paper copy.
Nov 27, 2008 | Stoves 720EF Electric Double Oven
Maytag double oven with ceramic stovetop. Tried to change the time on the stove. Now display has large and small red numbers displayed and cannot use the oven.
Unplug the machine for about 5 mins. If it's hard to reach the plug, you can turn off the breaker instead. You should be able to reset the clock normally after you turn the power back on.
Mar 10, 2008 | Kitchen Ranges
No power to the oven, is breaker external or somewhere on the oven?
Go to your breaker box or fuze box and look for a dual circuit breaker It should be labeled stove. Turn the breaker off If a fuze box there usually is a black plastic fuze holder labeled stove pull it out. Confirm at the stove a lack of power.
Dec 22, 2006 | Whirlpool RBD245PD Electric Double Oven
Stoves Sterling 1100E Stainless Steel (Electric) Kitchen Range Logo
524 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Ismael Rodriguez...
wayne murphy
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
