Question about HP LASERJET M5035 MFP All-In-One Printer
HP 5035 MFP Faint scanning and copying but printing is fine
SOURCE: copier not working
Dear sir, I have hp all-in one printer, copier, scanner Model. While suppled to DC 18V power supply Printer disply shows First massege "Inisillation" later Shows Error C402. I have contact local repairer who had told me to replace logic card of printer which costing is approx. 2/3 of new one. Kindlyhelp me in this matter & if Possible Let me now can the error C402 is due to logic fault ? Regards, B.A.Thakker.
Posted on Feb 12, 2008
Portenga_Mfg
SOURCE: hp laserjet m1319 mfp series
Are you using the software that shipped with the machine? I use the" HP Scan To" program which allows me to scan it to a slew of file types.
The only downer: I can't put the software on more than 1 computer. Apparently, it recognizes that the printer is hooked up to another machine and won't let me install any drivers on other computers (except the print driver).
Posted on Oct 06, 2008
ziraffa
  • 827 Answers
SOURCE: Hp 1410v won't scan
The all in one solution software you used in XP doen't work with Vista.
But you can still scan and copy by using Windows Photo Gallery.
1. Click on files tab at the top in Window Photo Gallery.
2. Click on import from camera or scanner.
3. Highlight your scanner icon (ie HP 1410v) then click import.
4. New scan window will popup, now you can preview or scan using this basic looking Vista utility.
Hope that helps.
Chris (ziraffa)
Posted on Jan 05, 2009
md_ehsan_1
  • 255 Answers
SOURCE: scanner error 12
uninstall the software of scanner and reinstall it
check your cables for loose contacts
Posted on Jul 04, 2009
  • 23 Answers
SOURCE: Copying and scanning don't work but produce all-black image
please clean the scanning glass and also the feeder.
Open the machine check if any paper has struck anywhere inside.
In most of issues it will work, if this does not works call your technician to troubleshoot the problem
Posted on Jan 13, 2010
WHAT IS LASER WHAT IS SCANNER INSIDE HP LASERJET 5035
The scanner is a small mirror that rotates at high speed, allowing the laser beam to scan, hence the laser whining.
Feb 12, 2015 | HP Office Equipment & Supplies
My HP M3035 is printing, copying & scanning extremely light but only after I changed th toner It prints fine with the old but with the new the print is light as if it were empty
You have a defective cartridge. It just happens sometimes, you should be able to return it where ever you got it for a replacement cartridge or refund.
Sep 03, 2013 | HP LaserJet M3035 MFP Printer
Unable to scan on laserjet m1132 MFP
Hello you have to open the HP LaserJet Scan.
In the HP program group, select Scan to start HP LaserJet Scan
Select a scanning destination
Click Scan.
Here is a user manual in more details:
http://images10.newegg.com/User-Manual/User_Manual_28-115-668.pdf
You need adobe reader to read the content.
Good luck
Dec 31, 2012 | HP LASERJET PRO M1132 MFP
Hp laserjet m1132 refill problem solution
Replace with professionally remanufactured toner... it works better... or increase the resolution if you are copying...
Sep 28, 2012 | HP LASERJET PRO M1132 MFP
Hp 5035 mfp printing black pages only
The DC Controller board is going back and causing the laser beam to run continuously causing the photosensative drum to be in a neutral state which causes the black pages.
May 08, 2012 | HP LaserJet M5035 MFP Printer
I am using auto feed on HP 4345 MFP printer, the issue is I have documents with one side printed but printer is scanning both side and printing. How can I change setting to single side from Duplex scanning...
Mr. Agarwal
you have to turn off the duplex scanning option under copy settings this will solve the issue
You can go to settings and look for Copy setup or copy settings i dont remember well but you get an option of DUPLEX COPY or DUPLEX SCAN you have to turn off this.
DO RATE MY SOLUTION PLEASE
Saleem
Jun 30, 2011 | HP LaserJet 4345mfp Printer
I have refilled my HP LaserJet M1132 MFP toner and the print quality does not look good. It is very faint and if I try to increase the contrast, it is not readable. Please advice.
Nov 19, 2010 | Office Equipment & Supplies
HP Color LaserJet CM1017 MFP - won't scan
Please try installing software components for your MFP device.
Feb 12, 2009 | HP LaserJet CM1017 MFP All-In-One Color...
HP LASERJET M5035 MFP All-In-One Printer Logo
271 people viewed this question
Seeker5211
Seeker5211
