Question about Canon MX300 Office All-In-One Printer
I have a canon mx 300 i recently recycled an ink cartridge, i was told my printer would say there was no ink and i all i had to was press the paper feed button for 5 seconds. only problem is i cannot find the button. where is it?! thanks so much!
  • 4 Answers
Press either an "Ok/Select" button or the Green button.
Posted on Apr 04, 2011
How to set ink level on canon mx-320 after refill?
Apparently the problem is that you are choosing to install (according to Canon), cheap, aftermarket ink cartridges rather than Canon ones. Therefore the machine is not recognizing them. Try this procedure, found on another forum, that was supplied by one of the cheapo ink companies. Who better to know how to fool the machines than them. If they want to sell these ink carts, they better know who to make them work!
U051 Error Correction procedure.
1- Switch off the Canon MX300 and disconnect the power cable.
2- While press and hold the power button, Connect the power cable to electric socket.
3- While pressing the power button, press the "Cancel/Stop" button (red button). (press TWICE che "stop\cancel" button)
4- Now release the power button and the printer turns into a kind of factory mode. Wait for 10 seconds until it says "idle".
5- Press ">" (next button) once "Shipping Mode 3? then Press the "OK" button. Press "OK" again for "without cleaning". A test page will print.
6- Open the cover, like you are about to change the cartridges.
7- Disconnect the power cable again without switch off the printer.
8- Take out the both cartridges.
9- Close the cover.
10- Connect the power cable and turn on the printer.
11- Now just put the cartridges back and the ink level in the canon Pixma MX300 have full again.
Jan 14, 2015 | Canon Black Pixma Mx 320 High Quality...
How do I get to the ink cartridge to change itin a canon MX 300
You must have power applied to the unit when you change ink cartridges. The cartridge holder should move to the left side of the carriage when you lift the cover to gain access to the ink cartridges.
Dec 21, 2014 | Canon Office Equipment & Supplies
Canon printer mx308
This can be caused when you get a recycled / off brand ink cartridge. If this is the case, check out the following link which shows how to deactivate ink level detection: http://www.cartridgesupport.com/canontipsandtricks.pdf
Jun 09, 2013 | Computers & Internet
Canon PIXMA MX300 Office All-In-One Printer and Fax MX 300 printing blank sheets
Do you have ink in the cartridges? Just because the computer says there is ink does not mean there really is ink.
Try making a copy and see if it copies. That will tell you if you have ink. Just go to the canon all in one and place something on it to copy and press copy from the controls panel on the printer.
May 31, 2012 | Office Equipment & Supplies
How do I change ink cartridges on Canon Pixma MX700?
1 Turn on the Canon MX700 printer by pressing and holding down the "Power" button. Open the paper output tray by pulling up on the tray. An arm will unfold from inside the printer and hold the tray open.
2 Apply pressure on the ink cartridge tab and remove the ink cartridge. A flashing light on the outside of the ink tray will indicate what cartridge needs to be replaced.
3 Remove the film, orange tape and protective cap from the replacement cartridge. You can throw away any trash. Do not touch the metal contacts on the new cartridge; this may cause the cartridge not to work.
4 Insert the front end of the replacement cartridge into the ink holder. Make sure you are placing the correct color in the correct spot. There is a sticker on the outside of the holder indicating what color goes where.
5 Apply pressure on the cartridge where it says "Push" until the cartridge snaps into place. The once flashing light should turn a solid red indicating the cartridge was replaced correctly.
6 Close the paper output tray. The Canon MX700 will start cleaning the printer heads. You cannot print during this time. The entire process may take a minute or two.
Please rate & vote , if you like soution..
Thanks
Mar 15, 2011 | Office Equipment & Supplies
I had my black ink refilled and my printer Alarm light is on and the printer reads - check ink and will not work. It is a Canon MX 300. Thanks for any assistance.
Press and hold down the stop/reset button until the printer restart. Then release the button and wait for the printer to initialize. These will reset the cartridge from being detected as refilled one.
Let me know if this works with you.
Please comeback and rate this solution.
Thanks for using Fixya.
Aug 17, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
Canon Mx 300 Printer wont work
Error Code [1401] or CHECK INK U051 = cartridge may not install properly or using non-genuine cartridges, refilled cartridges or faulty cartridges.
May 27, 2010 | Canon MX300 Office All-In-One Printer
I have the machine fax Canon Pixma MX 300. It writes "Recommend new C-CRT". Please, explain me what it means.
If the machine is a color printer it may mean Recommend new Color Cartridge. The color cartridge may be low on ink or defective.
May 18, 2010 | Canon MX300 Office All-In-One Printer
Refilled, full ink cartridges, but...
To Reset the Canon Cartridges Works 100%
Power off the printer
Hold the stop/reset button then press and hold power (for 5 secs)
Hold Power and release the stop/reset button
Press the stop/reset button twice
Relase power button
Wait until the power button lights a steady/still green, press the stop/reset button three times with a 3 sec space between each press.
On the 3rd press the inicator should be orange.
Press the power button to set data
To set data remove cartridges then replace.
leave for 20 or 30 secs
Press the power button again to shut down
Then press power button to power up.
The printer will feed one piece of paper through
then set language and counrty.
Then ink should be reset
Aug 17, 2008 | Canon MX300 Office All-In-One Printer
Printer problem
My Canon MX310 doesn't like recycled ink cartridges, but doesn't do this.
Rjams
Jun 18, 2008 | Canon PIXMA MX310 All-In-One Printer
Canon MX300 Office All-In-One Printer Logo
old marine
old marine
