Question about Brother MFC-465CN InkJet Printer
How do i change from manual receive mode to auto?
  • 4 Answers
You want "Fax/Tel" Mode. To do this follow instructions below.
To set a receive mode follow the instructions below.
a Press Menu.
b Press a or b to choose Initial Setup.
Press OK.
c Press a or b to choose Receive Mode.
Press OK.
d Press a or b to choose Fax Only, Fax/Tel, External TAD or Manual.
Press OK.
e Press Stop/Exit.
The LCD will display the current receive mode.
Posted on Apr 04, 2011
Daylight savings time change casio atomic watch has not changed is there a way to change it manually
An example for G-shock: I searched for casio g-shock manual and got this: http://world.casio.com/wat/download/en/manual/
You enter model from back of watch and it gives you a searchable PDF manual.
For mine, model 2638 (and likely most G-shocks), you press and hold the upper left (Adjust) button until the City Code flashes. You then press the lower left (Mode) to enter DST mode then press the lower right (Receive) as it cycles through On, Off and Auto.
On moves 1 hour forward, Off moves 1 hour back. After you select, you press the upper left button (Adjust) twice and it's set. I would not pick Auto anymore as my watch is still set to the original DST days which were changed in the US years ago and no longer match, I don't believe the DST days used can be changed by the user and I don't believe Auto receive adjusts for DST.
Mar 13, 2011 | Casio Watches
How do you change the number of rings, so that the fax will pick!
go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Apr 28, 2010 | HP OfficeJet J4580 All-In-One Laser...
HOW DO I SET UP TO RECEIVE FAX
Jan 28, 2010 | Office Equipment & Supplies
Recieve mode
Hi slickkitty
Only one press for each display,
When you press the FAX RECEIVE MODE button, the display should change each time you press. eg: AUTO, FAX ONLY
When you see the FAX ONLY, press the SET button and leave it like that. Don't try to do it when the fax rings. Do it when the fax machine is idle.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The following instruction is found in your Fax Manual.
Set the fax machine to FAX ONLY mode by
pressing {RECEIVE MODE} until the
following is displayed.
1 The display will show the number of
rings before the fax machine answers a
call in FAX ONLY mode.
2 Press {+} or {-} to change the ring
setting to 2 and press {SET}.
How to receive calls
Just leave it. When the other party sends a fax,
the fax machine will receive it automatically.
Hope this will help, if it helped you, please give a rating.
Good luck
luciana44
Sep 19, 2009 | Panasonic KX-FHD332 Plain Paper Thermal...
Ricoh fax 120 please let me know how to put ricoh on automatic fax receiving while not in the office also when someone rings i can hear the fax sound from my ricoh
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} - Follow the next instructions to change the reception mode :
1. Press the [F2] key. “ this key is located on the left side of the Control Panel next to the key [12] from the left side and next to the [Memory Trans.] key from the rigt side ”
2. Press the left arrow key to select the reception mode “ this key is located under the Display of the Control Panel”
3. Press the [OK] key when on the display is displayed the mode you want.
note:as you sad you want the machine to reaceive faxes when you are out of the office, so the reception mode [Auto Select] is the most compaible mode for you.
The machine can treat incoming fax
messages and telephone calls in three
ways.
1.Manual Receive
- Use this mode if your line is shared
by a fax machine and a telephone
but you wish to answer all calls
yourself and decide whether they
are fax documents or telephone
calls. You must manually press the
[Start] key to receive a fax.
The machine will ring continuously
until you answer the call, so you
have to be near the machine at all
times. The Manual Receive indicator
is lit when the machine is in this
mode.
2. Auto Receive
- Use this mode if you have a dedicated
fax line. The machine assumes
all calls are fax documents.
It will ring once to alert you of an
incoming call, and then starts receiving.
3. Auto Select
- In this mode, the machine rings a
number of times. You can answer
the call while the machine is ringing.
If you do not answer the call,
the machine automatically changes
to receive fax messages.
Jul 11, 2009 | Ricoh Office Equipment & Supplies
It stopped receving faxes. It will send ok but it will not receive!
It's probably been changed from "auto receive", to "manual receive", or "telephone" mode. Check settings in your manual.
Jun 09, 2009 | Brother IntelliFAX 4100 Laser Fax
Brother Intellifax
Not familar with MNL, does sound like you have the receive mode set to manual. set to auto anser or answer machine. In manual mode the phone will ring until you tell the fax to receive. In auto mode after so may ring which you set, the fax will pick up...
Aug 28, 2008 | Brother IntelliFax-2820 Laser Fax
Turner mode
To the right of the number 6 station preset is an auto/name button. In the display it likely shows something like auto 1 or 2. each press will cycle it through Auto 1 > Auto 2 > Manual. You want the manual setting. See if that works for you.
Mar 22, 2008 | Kenwood KDC-X717 CD Player
Harman kardon avr-147
Hi Javis. This is perfectly normal ! This mode change is done because the receiver auto detects the digital audio signal and sets the receiver's DSP to decode the signal correctly. You can go into the OSD menu to bypass the auto detection of it, but it's not recommended at all ! You're getting the best audio quality by doing so. Thanks ! cheebster.
May 07, 2007 | Harman Kardon AVR 240 Receiver
Canon l80
Most probably you have the machine set to "manual receive." Change the receive mode to "auto" or "Fax" mode.
Apr 23, 2007 | Canon FAXPHONE L80 Laser
Brother MFC-465CN InkJet Printer Logo
111 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
