Question about Kohler Home
I have a Kohler cistern, on the back of the lid it has the following marking:JACOB DELAFON BE 1082. It is currently overfilling and I need to replace a little rubber washer which I presume is under the purple cup that covers the valve. But I am unable to remove the purple cover and I am concerned that if I exert more pressure it will brake. Can you tell me how to remove the cover? Thank you Ray
    Top Expert:
  • Kohler Master
  • 51,280 Answers
You can try to remove it or you can go to a plumber supply shop and get a new level controller
faster easier and gives another 10 years of service
you may have to remove the unit from the cistern to get enough force applied to turn the cap so the job is half done anyway
Posted on Aug 05, 2017
Bob Gemmell
  • 209 Answers
SOURCE: Need to remove top cover of GE WPXQ3090T2WW top load washer
There should be 2 screws holding it on at the rear. Looking from the rear these will be at each top corner. Once these are removed push the lid from the front of the machine towards the rear and it will pop off.
Posted on Sep 13, 2007
SOURCE: Leaks oil looks like from valve cover
You have to remove the spark plugs cables and remove the four nuts that you see when the cables are removed.
When the four nuts are removed, simply raise the valuve cover. When replacing the gasket, make sure you get the gromets as well. Those sometimes get worn or crack since they are more exposed than the value cover gasket. Make sure that you clean the cover from oil and replace the gasket with no use of silicon.
Good Luck.
Posted on Aug 04, 2008
SOURCE: How to replace back cover of MFC-210C?
There are two clips on either side which need to be squeezed together then the cover can be slipped back into position.
Posted on Sep 03, 2008
  • 203 Answers
SOURCE: 2006 V70 low beam bulb replacement
can be fiddly but if you get the old 1 out you should be able to get the new 1 in. tip use a small mirror. joe
Posted on Nov 23, 2008
  • 27 Answers
SOURCE: replace valve cover gaskets on subaru svx
the truth about thse engines is they are hard to work on. if the valve covers are unbolted and still ****, try getting a rectangular peice of wood and putting it on the side of the cover neer the gasget, tap on the other end with a hammmer from all angles to try to break the seal.
this is a common problem with valve covers that havent ever been removed and they heat up, and cool down so many times they practically bake onto the head
Posted on Nov 18, 2009
Our local housing inspector says a toilet fill valve must be anti-siphon. I have Kohler k-9262 fill valves in my bathrooms. Are these anti-siphon models?
the fill valve is under constant mains pressure so it will not siphon out. However if there is a problem you can buy a non-return valve from your local hardware/plumber shop and fit it in the line between the cistern tap and the cistern
Jan 28, 2015 | Kohler Home
Hissing concealed cistern
The float valve needs adjusted or replaced.
Nov 30, 2014 | Kohler Home
When i flush,no water is flushing, nothing happens
I would check to see if the water supply valve is turned on to start.
Is it a new install?
Jun 22, 2014 | Kohler Cimarron 2-PC Elongated Toilet with...
I need a cistern lid for k-11465-0 white, please advise price
You will find it hard to find a tank lid by it's self. You can go through Kohler and get the part and it will run some where around 60 bucks you might get lucking on eBay.
Feb 02, 2011 | Kohler K-11465-0 White Cimarron Comfort...
When I flush the tank only half empties and not enough flushing action is the result as well as the bowl does not adequately fill after the flush.
Hi, if you remove the cistern lid and flush the toilet, look at the float (back left) to see if this is rising freely when the water fills back up. Once the water has stopped filling, check the fill level lines on the large syphon in the middle of cistern. Your model of toilet has an eco flush which will be lowest line to save water, so not as much water will flush out. There is a long plastic screw on the float (back left) which you can turn to adjust the water level to the higher line on syphon (1.6 gallon flush) and turn it slowley till the water level reaches that mark. flush a couple of times to see it is filling back up to the set amount.
Jan 14, 2011 | Kohler Cimarron 2-PC Elongated Toilet with...
How to remove lid on Kohler k-1833a cistern
Follow the instructions on p.12 of the following pdf:
http://www.geberit.com.au/web/appl/au/wcmsau.nsf/files/usr-pdf-Geberit_Outlet%20Valves.pdf/$file/Geberit_Outlet%20Valves.pdf
Basically, push down the 'full-flush' (big) side of the flush button and look at the side of the remaining (small) side of the button. There is a little slot that allows you to pull the small button out. You can then pull out the big side of the button which exposes a screw that allows you to pull the lid off.
Hope that helps.
Jan 12, 2010 | Kohler - Toilet - One-piece - Gabrielle -...
Need instructions and Switch for twyford close coupled cistern
i presume with lid of u can flush toilet by pusshing switch with finger if so buttons must be spot on when replacing lid can be adjusted inside systern any probs get back
May 07, 2009 | Toto CST414M-51 Aquia Dual Flush Close...
Home Logo
132 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
