Problems with dell optiplex sx 270 shutting down again n again
  • furqan Apr 04, 2011
    am using win xp on that pc ..
    every time i start the pc its started well in bios .. but when i load windows to go in .. its hanged .. sometimes hanged most of the time shuted down ...
    cant go in safe mode ...
    removed every thing extra ...
    cleaned up fans and processor things
    am using win xp ...
    whenever i tried to go in bios is good enough
    but when i tried to boot , its hanged on win xp logo ... and some times its not appeared and pc shuts down before its came ...
    i removed everything external ..
    cant go in safe mood
    cleaned up all fans ,processor etc things
    Problem Solver:
  • 19 Answers
What Operating System are you running - if Windows what version XP, vista, 7? When is it shutting down, after you get into Windows (or other OS) or when trying to boot up? Are there any error messages? New machine or old machine - if old has anything changed? How long does the system stay working before it shutsdown? Is it getting too hot, fans blocked etc?
Lets start by working out if it is the hardware (Dell and devices connected) or the software (Windows etc) It is difficult to know without more details of the problem but here are my best suggestions
Try safe mode - running windows try in safe mode (F8 when starting windows), check error logs
Test the hardware - I would start by disconnecting all external devices, USB disk and other devices. If possible also remove any extra boards you have added to the machine. Even the mouse, USB sticks, anything plugged in (but leave the keyboard). Try this, do you get the same problem.
Test the OS - If you have a live CD such as Ubuntu (can be downloaded from here: http://www.ubuntu.com/desktop/get-ubuntu/download ) then try booting the system from this and see if you still get a problem
Can you run a virus checker on it, how long does the machine stay running. You can try downloading from here from another machine - http://www.avg.com/us-en/avg-rescue-cd-download and making a CD, run the rescue anti virus.
Posted on Apr 04, 2011
  • 1 more comment
    avg link is not working
  • Daniel Phillips Apr 04, 2011
    It could be hardware failure of some kind. Most likely hardware component to fail is hard disk. When it boots up can you hear anything sounding wrong around the disk. I would consider using something like a live CD to boot up the system and then you can at least back up all of your data. See link above for ubuntu or also there is knoppix. You can boot off these without any change yo your system. In fact it will work fine as a system for email, office and browsing internet.
    You will of course need to get to another machine to download and burn CD's, but it will give you some good tools to work with if you haven't got a ERD and Windows CD
    Other suggestions:
    1. It could be a virus. If the CPU is running at 100% some program could be bringing the system down. Check with the livecd virus checker as mention above (AVG)
    2. If you have a Emergency Repair Disk you can boot from your installation CD and try running repair with the ERD. or does the Dell have recover boot facility, normally a function key at boot (F12 or 11 are often used) try google for it.
    hope some of this helps
    , I just tried it, it works fine maybe try again or tryhttp://www.avg.com/ and go from there
My Dell optiplex gx 270 tower's chipset heats up and system shuts down and my friend's gx270 mother board is burnt due to same reasons
check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU make sure its securely seated and has thermal grease might be getting to hot
another possible reason could be a memory dump you might be running to many programs at the one time putting to much strain on the CPU central processing unit
hope this helps
May 06, 2012 | Dell OPTIPLEX GX270 (Y1057) Motherboard
Trying to fit new 1gb memory stick in dell optiplex sx 270 but the system will not acccept it and not boot up error codes of ab yellow but cd green all it does is beep when fitted yet i refit the 256mb...
Hello.
Memory is not interchangeable. Depends on your system, as to what memory to use. An error is telling you the memory is not correct for that PC.
Your Dell Optiplex sx 270 uses DDR PC2700 and DDR PC3200 memory.
Hope this helps.
Dec 20, 2009 | Dell OptiPlex SX270 PC Desktop
I recently bought an old dell optiplex sx 270. I
You are limited in the choices for video card The Optiplex GX270 only has a 160W power supply Not only that but because of the slim case, you're most likely limited to low profile video cards. That means the choices will be extremely limited & not very good. Even after the upgrade, you'll most likely have to stick with older games. follow this link to buy low profile video cards http://www.directron.com/lowprofile.html
Nov 28, 2009 | Dell Computer Refurbished OPTIPLEX SX270...
Power switch dell optiplex sx 270
You problem is most likely caused by faulty capacitors on the motherboard. Most PCs of your age suffered from this. It was a manufacturing defect. Call Dell to see if they will replace it for free. This is a picture of two blown caps so you can id them on your MBmoz-screenshot.png
Aug 17, 2009 | Dell OptiPlex SX270 PC Desktop
Dell Optiplex GX 270 crashing on the Internet
Hi
Download a "stress" testing programme called Prime95 and read instructions / run it through. I assume that ALL the ram matches perfectly. If this tester crashes PC alot, remove one ram stick at a time, may actually narrow the offender down. Also bear in mind that a programme could also be crashing PC so try using control Alt Del and go into "processes" and shut down ONE at a time / retest. This will take time but will narrow down the offender. You actually only need to run Prime 95 for a short time.....till it crashes PC. Eventually once you have stability the PC should run with no probs overnight!!
Aug 12, 2009 | Dell Optiplex GX270
Hou do i reset bios on a dell optiplex sx270
  1. Boot up the computer into the setup (depending on your bios, to get into the bios you need to hit the DEL key during boot up.)
  2. Press 'ALT' and 'F' at the same time
  3. Turn 'NUM LOCK', 'SCROLL LOCK' and 'CAPS LOCK' on. (Make sure the lights on the keyboard are on.)
  4. Press 'ALT' and 'P' at the same time. The bios should now be reset to the factory settings.
Apr 02, 2009 | Dell Computer Refurbished OPTIPLEX SX270...
Is dell optiplex gx 270 apligable for optiplex 270
i don't see any reason that you can't as long as you use the 260 drivers.
Nov 16, 2008 | Computers & Internet
My computer will not power on
brand and model of the computer would be good.... as well there is a switch on the back of the computer on the power supply. toggle it to the other position and try again
Robert
Sep 08, 2008 | Dell OptiPlex SX270 PC Desktop
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
