Question about Kenmore 26882 Top Load Washer
Been reading on the fixya site. I have a kenmore 80 series top load washer that will fill, drain, agitate but, with a heavy load, won't spin. Presently i can fool the machine most of the time by starting the cycle with no load in it, then once it starts agitating I add less than a full load and most of the time it finishes the cycle normally. I read mention of a failing motor coupling being a possible reason.
    Top Expert:
  • Kenmore Master
  • 34,089 Answers
You can verify a failing motor coupling by looking for little bits of broken plastic underneath.
Posted on Jul 27, 2017
Lumpy816
  • 246 Answers
SOURCE: Kenmore 80 series not agitating
Most likely you have a bad motor coupler. If you open the console and remove the two brass clips, this will let the front, sides and top all come off as you tilt it forward. At the botom center, you will find two metal clips holding the pump on. Remove. You will find 2 screws holding similar clips holding the motor on. Removed. On the back of the motor, is your coupler. Replace. Then re-assemble.
Posted on Jun 13, 2008
  • 1028 Answers
SOURCE: Kenmore 80 Series Top Load Washer not agitating
if it will pump out ckd motor to gearcase coupling probably broke
Posted on Sep 03, 2008
SOURCE: Kenmore 80 series won't spin
If it agitates and drains. leaving your clothes clean but soaking wet. It is most likely the transmission/gearbox. the motor is working otherwise it would not agitate. it is stuck in agitate mode and cannot "shift" into spin mode. new transmission will cost 140-170 and takes 2 or so hours to replace depending on skill level. total repair cost parts+labor $300ish you may want to ante up for a new machine at this point. if you cant to the labor yourself.
part# should be this: tho double check using your own model#
Part # AP3096209
Posted on Dec 09, 2008
onthejob5130
  • 640 Answers
SOURCE: Kenmore 80 series top load washing machine won't agitate or spin
defective motor coupling,,replace..onthejob
Posted on Jan 24, 2009
  • 23 Answers
SOURCE: Kenmore Series 80 top loading washer that doesn't spin or agitate
Unplug machine, remove water pump and motor, behind the motor is a coupler, take broken parts to your local appliance parts store. Costs 16 bucks, replace the broken parts with new ones, reassemble machine. Never ever do a blanket/comforter in your machine again!!
Posted on Apr 01, 2009
I have a top loading Kenmore series 80 washer. The cycle starts, agitates, but won't drain and go into a spin mode. It just stops after the agitate is done and remain full of water. It won't...
This is usually a door closed switch that is either a bad Lid switch It is number 11 on the diagram on this page http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11024032301/0582/0153200/K0403014/00001?blt=06&prst=&shdMod=
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Leave a comment if you need more help.
Thanks for using Fixya.
Aug 12, 2011 | Kenmore 24032\24036 Top Load Washer
I have a series 80 top loader. It filled and
Screws holding the lid switch was broken. Had to replace lid switch.
Jun 11, 2009 | Kenmore 24902 Top Load Washer
Mar 31, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 26882 Top Load Washer Logo
Sal DeAngelo
fordexpert
Mike Carew
