Question about Fisher and Paykel GWL11 Top Load Washer
Hi I have below problem with my F&P top load washer Mdl GWC11 HK ; Washer stops and beeps for attention after each filling up cycle with the wash temp red and green LED lighted up and blinking. The cycle resumes after wash temp selected on cold wash and pause/start button depressed. My machine does not come with hot wash facility. Any help will be most appreciated. Thank you very much.
  • revod Apr 05, 2011
    Hi Jahn27
    Thank you very much for your reply and informations. My thermistor reads 7500 ohms at approx 25 degree C. Likely is spoilt? How to get into diagnostic code mode? My machine is model GWC11 EXCELLENCE.
    Thank You
    Your solution indeed is helpful and informative. Thank You once again.
    President:
  • 1,554 Answers
The flashing of the cold(green) and hot(red) LEDs indicates a user fault which means no water is entering the machine. This could mean either the hot and cold water faucets are not turned on, no water in the water supply line, the inlet chamber thermistor is faulty,or one of the valves is not working. Make sure water is running in the water supply lines and the faucets are turned on.
Since the machine works on cold wash, the problem is either the hot water valve is not working or the inlet chamber thermistor is out of range. It is likely that the thermistor seal is leaking and/or the thermistor is shorted. The machine control 'thinks" the water is too hot and does not activate the water valve if the thermistor is shorted. Swap the hot and cold water valve wires and the fill hoses in order to check the hot water valve. Cold water should fill in when a cold wash is selected if the hot water valve is working and the thermistor is therefore shorted. Verify this by measuring the resistance of the thermistor which is normally 10,000 ohms at 77degrees Fahrenheit (25 degrees centigrade) and goes down as the temperature increases. Replace the thermistor if shorted or the hot water valve if cold water does not come in when a cold wash is selected and the valves wires and the fill hoses are swapped.
Let us know if you need further advice. Please accept the solution should you find it helpful or informative. Accepting the solution will not stop you from communicating with the expert. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Posted on Apr 04, 2011
  • Jahn27
    Jahn27 Apr 05, 2011
    The machine is equipped with self-diagnostics that automatically flashes a fault code through the Wash Progress LEDs when a problem is encountered. The code is flashed as a combination of flashing Wash Progress LEDs. Indicate clearly which among the LEDs are flashing, if there's any, to determine the fault code and the appropriate action needed to be undertaken to address the problem. Regarding the thermistor, it looks like it needs to be replaced.
I have may tag wash model nu mav5920eww i just hooked it up tried reg wash it filled with water then would not continue to wash went to pause mode
Maytag & Whirlpool washer diagnostic - Fills with water then ...
? 3:03
https://www.youtube.com/watch?v=71zySSScDPE
Jul 11, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your trusty Maytag Washer that has some of the ...washer diagnostic - Fills with water then cycle stops - LAT8014AAE .... Not agitating Maytag 2 belts top load washers - Duration: 26:55. by theapplianceman 23,820 views. 26:55.Washing Machine Keeps Filling With Water and Will Not Agitate ...
Maytag top loading washing machine stopped working & filled with
Dec 02, 2015 | Maytag MAV5920E Top Load Washer
Fisher and Paykel GWL11 Top Load Washer starts but drum won't turn, it twitches and beeps then turns off with solid beeps
Hi ken
Can you turn the bowl & agitator by hand.
If it can't turn by hand, Your seal & bearings need replacing.
Feb 01, 2013 | Fisher and Paykel GWL11 Top Load Washer
Hi I have a Fisher & Paykel MW612 top load washing machine. It will start to fill normally on warm wash then the hot stops coming in and the cold fills intermittantly then the whole ting stops and...
Gary - LEDS 00110010 as you have not mentioned the last LED which will be red if on is 00110011
Ok - your code is 50 indictes a faulty hot water valve - question - have connected the hoses correctly - as per your descriptions - it should always be cold 1st then hot water- cold - then hot etc until it fills.
Pays to check this as the fault code is totally opposite to what your saying..
May 01, 2011 | Fisher and Paykel GWL11 Top Load Washer
FL code washer not draining
“FL” (Over Fill) flashes
The washer will beep every 10 seconds with no time-out. The
pump will cycle one half minute on, one half minute off, until
the overfill switch is reset or power is discontinued to the unit.
Press STOP/CANCEL to clear the display. Shut off the water
faucets to the inlet hoses if water continues to flow.
Here is the complete manual.
Jan 08, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Washer not filling or agitating, during wash & rinse cycles
HI, this will occur if the timer mechanism has become unstable. you will need to replace this defective timer control module asap, if possible.
Jul 25, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 22082
OL on my washing machine
May 17, 2008 | Kenmore 22062 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
57 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
