Question about Smith 23-1001C OXY/ACETYLENE LITTLE TORCH KIT
Hi there, despite brand new torch, brand new regulators and gas tanks, I cannot get a decent hot flame on my oxyacetylene torch, and what flame I can get, goes out within seconds of heating a crucible.....what can I do?
  • 407 Answers
Hi:
If your flame goes out check the following:a) check your acetylene and oxygen pressure, for this kind of job acetylene should be at 4 psi and oxygen at 10.b) Check you're using the right type of nozzle for the job and this nozzle is clean.
Posted on Oct 06, 2011
BBQ does not get hot enough to cook properly. All gas jets are clean as BBQ is almost new
blue flame? if flame is not blue, then air gap needs adjusting. if blue flame and burner control is on high, then could be your regulator. (assuming tank if full)
Apr 17, 2015 | Grilling
Tip
Gas Grill Won't get as hot as it used to? Read on:
Hello. Are you frustrated because your gas grill doesn't get hot enough lately. The problem you are having indicates that you have to go through a procedure called "RESETTING THE REGULATOR". Follow these easy steps:
1. Turn the burners on for one full minute and then off.
2. Next, remove the regulator and the hose from the tank.
3. Then reconnect the tank to the regulator and hose.
4. And very slowly open the tank.
5. Last step is to fire up the burners and start cooking with you new hot flame.
The problem began the first time you opened the valve on the tank too quickly. In the future, always turn the tank valve on s-l-o-w-l-y to prevent this problem.. Joe
on Mar 19, 2010 | Grilling
Torch will only light when oxygen tank is off. Gas is coming out with either valve open. When oxygen tank is on, flame goes out. Thank you for any assistance, knowledge you may provide. Tim O'Brien
Is the flame you are getting a carbonising flame? ie. is there a lot of soot in the flame? It sounds like your oxygen regulator is faulty and not regulating, blowing out your flame as soon as you open the oxygen bottle. The acetylene side seems to be ok but have the oxygen regulator overhauled.
Mar 08, 2011 | Firepower FPW03842600 Cutskill Heavy Duty...
Burner flames don't get hot, like not enough gas.
Try this, Turn off the tank. Disconnect it. Reconnect it. Turn tank valve back on very slowly and then see if you get bigger flame size.
May 15, 2010 | Weber Genesis Silver B Grill
Low flame
Try putting on a new regulator
Nov 23, 2009 | Weber Q Grill
The gas flow cannot be raised and a slight breeze puts out the fl
The new gas grills have a safety device built into the gas hose that can cause this problem until you get familiar with it. The flame on a gas grill should be blue. If you have a yellow flame it could be caused by a couple of different problems. First of all the burner might be worn out. If you have an older grill then you should inspect the burner to make sure that there are no cracks or holes and that all the burner holes are the same size. If you have a newer grill or burner, or your burner appears to be fine then the problem might be with the regulator. The regulator is a round metal object near the connector to your gas supply. Sometimes regulators get stuck. This can reduce the gas flow, make a yellow flame and keep your grill from getting hot. To solve a stuck regulator, turn off the fuel supply to your grill. Disconnect the main connector and open the grills control value. This will eliminate any pressure on the regulator. Sometimes this will reset the regulator, but sometimes they stay stuck. Take a small hard object like the handle of a screwdriver and give the regulator a gentle tap. Now you can reconnect everything and see how your grill works now. If you still have a yellow flame your propane tank might be low, the regulator may need replacing or you could have a blockage in the venturi tubes. So check your fuel level by pouring hot, not boiling water down the side of the tank. Feel along the side where you poured the water. The propane level is where the tank feels cold. If you have plenty of fuel, locate the venturi tubes. The venturi tubes are located along fuel lines right behind the control valves. These allow air to mix with the fuel before reaching the burners so they have a small open space. If that space is blocked it will restrict the fuel flow to the burner. Make sure it is clear of obstruction. If you have done all this and still have a yellow flame you may need to look at replacing
May 29, 2009 | Brinkmann 810-8410-S Stainless Steel...
Grill with a full tank of gas will not get hot
Low flame, low temperature, yellow flame: This has become the biggest problem with many grills these days and it's almost always because of the regulator (the funny UFO shaped thing on the gas hose). Regulators seem to be stickier these days and when they stick you don't get enough gas to generate a good grilling temperature. To get your regulator unstuck you need to release the pressure on it. Follow these steps exactly:
  1. Turn off the gas at the propane tank
  2. Disconnect the gas line from the tank
  3. Open the grill lid
  4. Turn all control valves to high
  5. Wait for about a minute
  6. Turn all control valves to off
  7. Reconnect the gas line to the tank
  8. SLOWLY turn on the gas at the tank
  9. Light the grill normally
  10. Your grill should now heat normally
To keep the regulator from sticking again make sure that you turn off the control valves first, then turn off the tank valve. Always open your tank valve slowly. If this doesn't work give it a second try. If you still have low flame then you probably have a faulty regulator that will need to be replaced.
May 24, 2009 | Char-Broil Patio Caddie 4654870 (LP) Grill
Low flame
this is a problem with the regulator. It is not allowing enough pressure to maintain the burners when all are lit on hi. You can get these regulators at most major retailers or directly from th emanufacturer.
Hope this helps you out.
Jun 15, 2008 | Brinkmann 810-2300-B Grill
Smith 23-1001C OXY/ACETYLENE LITTLE TORCH KIT Logo
140 people viewed this question
Top Smith Welding Tools Experts
Bill Boyd
Are you a Smith Welding Tool Expert? Answer questions, earn points and help others
