Question about Kitchen Appliances - Others
The Swan electric urn 26 litres SWU26L. 1) Does it have a thermostat or simmerstat? 2) Does it have a single element, or multiple elements? I need to know if a 2nd or 3rd element might be activated when the water temperature drops on adding cold water. 3) What happens when you draw off hot water? Does the element automatically turn on again, or does it only respond to a drop in temperature? Or does the element only activate on a fixed time basis, e.g. for 15 seconds every 90 seconds, irrespective of water temperature?
  • 63 Answers
SOURCE: Problems with Breville SK500XL Stainless Steel Cordless Electric Kettle
you need to change out the heating element.For electric kettle, alway remember to fill up water before you turn on the kettle.never poure water while the element was hot.hope it help.
Posted on Aug 13, 2007
  • 17 Answers
SOURCE: Red light's on... but no hot water!
OK, inside the unit there are three items, the heating element, thermostat, and thermal fuse.What has happened is the element got too hot and the thermal fuse opened.There is no reset button.In some cases you may run across a defective heating element or thermostat but its not common.The fix would probably be replacement of the thermostat and thermal fuse.For this, you would have to contact a small appliance repair center in your area.
Posted on Nov 07, 2007
SOURCE: hot temperature
If you turn the unit around and look indise the back of it, there is a black knob that you turn to adjust the temperature. It is kind of hard to see unless you turn the machine full around.
Posted on Jun 19, 2008
MNTECH
  • 1543 Answers
SOURCE: Bradford White Water Heater Model: M165R6DS13
Immediately turn off power to heater. One of two things has happened. Either: A. The electrical contacts in one of the thermostats has welded together, necessitating replacement of the thermostat(s). (in this case I would recommend replacing both upper and lower thermos) or B. The lower element has burnt through, and because there is 120 volts to the lower element at all times (it normally only heats when the thermos complete the circuit to give it a path to the other "hot", putting a full 240 volts on it) a section of the element will continue to heat up to the point where the break allows the current to complete it's path to neutral ground via the water in the tank. It can continue to heat until the high limit safety thermo trips out. (the red reset button on the upper thermostat)
If either condition exists, the high limit safety thermo should trip out power to the heater before boiling water, and thus steam, is produced. Even if the safety thermo should fail to cut power, the pressure / temperature relief valve should open, releasing excessive pressure. If that should also fail to open, due to corrosion or such, the water heater will create steam and can actually result in explosion, and possible injury or death!
Several years ago I came across one that was boiling and when I turned on a hot water faucet to relieve the pressure it filled the entire basement with steam. (I still shutter to think if I didn't catch that fast enough I or someone else could have been killed)
The most likely cause of your extra hot water is actually the lower element. After you turn off power to the heater, turn off the water supply to the heater, open a hot water faucet to allow air to enter the tank and drain the tank. Remove the lower element. A bad element is usually visually apparent. If it looks good, you would have to test it with an ohm meter. (should be about 20 ohms if it is good) Install new element, turn on water and fill until water flows steadily from the hot water faucet you left open. Now you can turn the faucet off and turn power back on to heater.
Posted on Feb 15, 2009
  • 408 Answers
SOURCE: Rheem Hot Water Cylider Thermostat keeps tripping
Sounds like you have a faulty thermostat.  This is the unit that detects the water temperature, and if it is not where it is set, will kick the switch to allow electricity to flow to the elements you replaced. The thermostats are relatively cheap and if you have the knowledge to change the elements, changing these thermostats should not be a problem.
Posted on Mar 07, 2009
Fisher and Paykel Paprika Oven Top Elements Full hot!!
No controller. The switch for each element (called a simmerstat) is what controls the heat. It is a common fault and will be fixed if you instal new simmerstat for each faulty element.
Mar 17, 2012 | Fisher and Paykel Ovens
I have a Simpson electric oven with stove top elements, and one of the burners will only cook at the highest level, I cant figure out how to change it, any suggestions?
You need to change the "Simmerstat", take the model number to your local electrical parts supplier/parts counter at your local stove retail shop that sells Simpson stoves and ask for one for that model, make sure you get the right one for the position as some control a single element and some control dual elements.
*** TURN OFF THE WALL SWITCH AND ENSURE NO POWER IS APPLIED TO THE STOVE BEFORE PROCEEDING ****
Remove the upper back panel of the stove. Swap wire for wire of the old simmerstat to the new one, remove the knob from the old Simmerstat, undo the nut securing the simmerstat in the oven control panel and discard, fit new one, secure, fit knob, fit back panel, turn on wall switch and test.
Some countrys/states require registered electricians perform this task on electrical appliances so you must ensure you can do this legally before you start and take the relevant safety precautions and don't electrocute yourself.
Apr 13, 2011 | Ovens
I have a GSW Series 5 water heater (electric). I think the heating elements are bad or going bad. The heater is about 12 years old. Its a 40 gallon heater, and I've noticed the amount of hot water is less...
It may be one of 2 elements not working, a thermostat problem, scale build up in tank, to name a few possibilities. You'll need to shut off power to water heater before doing anything to it, and perform a few tests, and check a few things to determine which one is the cause. After power is off, you remove cover(s) on side of tank and peel back the insulation to get access to element(s). Keep in mind that should you need to change one of the elements, or both (assuming it has 2 otherwise you wouldn't have any hot water at all if only 1 element and not working.) This is where it would be good to have a voltage meter ( or multimeter ) and know how to use it. Is that possible? Before you reply, please shut off power and remove cover(s) to be sure whether single or dual element. If it's single, it may just be thermostat adjustment, or faulty, or scale build up around element. Keep in mind that water to tank will need to be shut off and tank drained down below element before removing/replacing. Get back to me with info on single or dual element. Thanks
Jan 10, 2011 | Fasco GSW Hot Water Heater Exhaust Draft...
Themostat is bad
If water heater thermostat is bad, buy a generic thermostat at hardware store and install it according to instructions shown on link below:
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
I usually replace both upper and lower thermostats for about $28.
Lowes sells thermostats and elements.
If your water heater is a single-element/ single-thermostat, you can buy any thermostat with red reset button.
Technically a single-element thermostat has 1 less screw, but either thermostat will work.
If your water heater is 120V or 240V, the same thermostat will work of either voltage.
This is true because the thermostat is a simple bi-metal heat-reading device that does not operate on electric current.
That being said, you might want to test parts before replacing anything, in case problem is element.
To do comprehensive electric water heater troubleshoot:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Image below shows generic thermostat with reset button. Each of these will work for single-element or dual-element tanks with either 120V or 240V. Wires connect just as they did on old thermostat. Tighten wires very tight. Press in reset button to make sure ECO is set. Put insulation and cover back over thermostat when finished.
Dec 22, 2010 | RELIANCE ELECTRIC WATER HEATER
I awoke to no hot water, my heater is three yrs old and i just changed my upper and lower element and upper thermostat, still no hot water then i checked to see if i was getting power and i am, is there...
Your water heater has 2 elements so its 240Volts.
1) If breaker is delivering power on one leg of the 240Volt circuit, then water heater can appear to have electricity, but tank is receiving 120V. Both 120Volt legs are needed to complete the 240V circuit. Double check for 240Volts.
2) Review electric Load.
Water heater label shows wattage of tank.
If tank is 4500Watts for example, you installed 3500 or 4500 watt elements.
With 5500 Watt elements you need 30 amp breaker and orange-colored 10 gauge wire
With 4500 Watt elements you can get by on 20 amp breaker and 12 gauge wire up to 75 feet away.
3) Check ECO red reset button on upper thermostat. If reset is tripped, then ECO is reading high temperatures. Suspects at this point are defective upper thermostat, shorted wire or bad lower element.
4) Also note that insulation and cover must be re-installed over thermostat. Thermostat reads temperature through wall of tank. If outside air circulates around thermostat, that can cause a mis-read and cause tank to overheat and ECO trips.
If you don't want to test the heater, replace both thermostats for about $25. Return the upper thermostat for a refund. Then see of problem persists.
Here's what I would do.
1. Check breaker for 240
2. Check water heater for 240 across 1 and 3 screws on upper thermostat
3. Note wiring and breaker size.
4. Note label on side of tank.
5. Look at end of new element to see wattage printed on each element. Look for sings of high heat and burning. Tighten screws on elements.
6. Check ECO reset button. Look for high-heat and burning. Tighten screws on thermostat.
7. Test upper thermostat as follows:
http://waterheatertimer.org/images/Electric-diagram-water-800.jpg
Test left-side #1 screw to right-side middle #4 screw. Test should read 240V at all times. If not, then ECO is tripped, thermostat is bad, or electricity is OFF
8) Water heater is cold so upper element should be ON. Test upper thermostat.
Test right-side #3 screw to left-side bottom #2 screw and it should read 240V
Test right-side #3 screw to right-side bottom #4 screw and it should read 0 volts
8. If upper thermostat checks out. Test upper element for 240 across both screws. If upper element does not read 240 when water is cold, then element is bad or there is a shorted wire between element and upper thermostat.
How to test element:
http://waterheatertimer.org/How-to-test-water-heater-element.html
9. Do a full troubleshoot on electric water heater
Dec 07, 2010 | General Electric GE SmartWater Household...
Water is not hot, doesn't last long. Thermostats turn elements on when turned up. Elements show 230 when on.
Lower element can be burned out and still read 230V across screws
1) We know thermostats are working because elements test 230V.
2) We know upper element is working because tank has some hot water.
If upper element is burned out, tank will have no hot water.
http://waterheatertimer.org/How-it-works.html
3) Here's how to test lower element:
4)Here's how to replace element
Rheem element is 4500Watt bolt-in type
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
5) Rheem manual says: Heaters furnished with standard 240 volt AC, single phase non-simultaneous wiring, and 4500 watt upper and lower heating elements.
http://waterheatertimer.org/pdf/Rheem-spec-sheet.pdf
geno_3245_94.jpgRheem 4500Watt element
Nov 21, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
What cause the water heater to take more than an hour to heated up and unable to last longer. Usually its take about 15 min. to heat up and can last longer.
'Rheem 81VP15S point of use' is a single-element, 15 gallon, 120V electric.
Other 'point-of-use' sizes range from 2-1/2 to 6 gallon to 20 gallon.
Electric water heaters have 2 parts: thermostat and element. One is not functioning correctly. Most likely the element caused by sediment build-up.
How to determine if tank has element or thermostat problem:
Do not turn off water going into tank. Put hose on drain valve. Open drain valve. Does water come out like open spigot? If water does not flow, then heater is likely clogged with sediment.
Solution 1: If water flows out like a spigot, the thermostat is probably bad. Read: How to replace thermostat.
Solution 2: Water does not flow, so element is surrounded by sediment build-up and cannot heat water. You need to clean out tank with shop vac, and put in new element ... plan full day and 3 trips to hardware store. Simply draining tank will not remove sediment. Sediment is chunky and will not come out voluntarily.
Buy element before starting:
-Turn off electricity
-Open cover on side of tank, remove insulation (these have to be put back for proper operation of thermostat)
-The are 2 electrical parts >>the element and the thermostat which is located above element
-Element wattage is printed on element and also shows on label on side of tank
-I think Rheem element is held in place with 4 hex bolts
-Take photo of element to hardware store so you have part on hand before removing old element
-If element is 1-1/2' diameter hex type, you need inexpensive element wrench from hardware store + the element
Drain tank and clean sediment:
-Read: To open drain on water heater so water comes out
-Read: How to clean sediment out of water heater
Sep 29, 2010 | Rheem 81VP15S Point-of-Use Electric Water...
I replaced the heating elements(2) and switiches(2) on my Rudd electric hot water heater. Model PES 40-2. The switghes came with several wiring diagrams.(universal) Can I get a diagram specific to my...
Residential water heaters USUALLY follow same diagram unless water heater is wired for other purpose. Multiple diagrams on instructions show available options. Take photo of wiring before removing wires on any electrical device.
Upper element.
Black wire from top of heater connects to #1 top left screw.
Red wire from top connects to #3 top right screw.
Blue wire from upper element connects to #4 middle screw on right side
Red wire from lower element connects to #4 middle screw on right side
Yellow wire from upper element connects to #2 lower left screw
Black wire from lower thermostat connects to #4 lower right screw
Upper element: Yellow and Blue wires connect to either screw
Lower element: Red wire from top connects to either screw
Lower thermostat: Black wire from top connects to top screw
Short wire between lower thermostat and lower element
http://waterheatertimer.org/images/Water-heater-wiring-w-numbe.jpg
http://waterheatertimer.org/images/Thermostats-numbered-divided-500.jpg
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html
Sep 18, 2010 | Whirlpool Water Heaters
Luke warm and weak coffee
Your problem is 1 of 2 things. Thermostat or Keep warm element. You have to take the pot apart to test. Parts are at repairshop.com or eBay under Farberware coffeepot parts. Good luck Ron
Jul 25, 2010 | Faberware Farberware FSU236 12-36 Cup Urn...
Kitchen Appliances - Others Logo
110 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
