Question about Yamaha SW201 Subwoofer
An object got inside the through the airhole and is making a bad noise when music is played. How can i get the object out?
  • 1,606 Answers
Disconnect the cables to the subwoofer (including the power plug) and lay the unit on its back. Remove the speaker cover. Remove the screws from the rim of the speaker. Carefully lift the speaker out of the cabinet; handling it only by the rim. If you have someone to hold the speaker at this time (it is attached by wires inside), that is the best way to make sure it is not accidentally damaged. Now you can look inside and retrieve the foreign object. Caution: the electronics inside include capacitors, which can hold a charge even with the unit unplugged. Don't touch any bare leads inside if you can avoid doing so; if you must touch them to retrieve the object, use only your right hand, preferably while wearing a glove.
Posted on Apr 04, 2011
    President:
  • 1,851 Answers
Depending on where the object stacked you can remove the cover of the speaker and unscrew the screws of the speaker or unscrew the perimetric screws of the amplifier section (the metal surface at the back side of the subwoofer). Afterwords you have to locate the object and remove it. Keep in mind that both the woofer and the amplifier section, have some centimeters cable free so don't force them in order not to get apart.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Turning the heat on makes lot of noise
If the blower motor is noisy, the bearing may be getting bad inside the blower. This will require replacement of the blower motor unit. In some cases, foreign objects can fall into the motor casing assembly also making a noise. The motor will need to be removed for inspection
Jan 14, 2016 | 2007 Nissan Sentra 2.0 SL Sedan
Ac makes whining noise on a 2004 Pontiac grand prix
Is the whining noise coming from the engine compartment where the compressor is located or is the noise coming from inside the car? If the noise if coming from inside the car it could be your blower. When a blower wears down the bushing is the first thing to wear down and it begins to have play. That makes the blower/fan vibrate making a loud whining noise. Replacing the blower could solve that whining noise.
If the noise if coming from the AC compressor, it also could be a bad bearing within the compressor.
Feb 23, 2015 | Pontiac Cars & Trucks
I have a superscan tv vcr dvd combo and the dvd player makes a horrible screeching noise when i try to open it and play a dvd. Any ideas on how to fix this?
either some foreign object is also inside or a problem with the mechanism---someone would have to peek inside with it in operation to see (or in this case listen) to see where it sound is coming from.
Mar 19, 2012 | Sylvania Televison & Video
When inserting a cd into the cd player of our 2008 pontiac vibe, the cd makes a grinding noise and then does not play.
make a visual check in the cd port if there is a coin or any object inside the cd cartherage if there is remove the player then try to pull it out
Aug 31, 2011 | Car Audio & Video
My 19 in magnavox tv dvd combo makes a rattling noise after i put a dvd in and try to play it
Sounds like you have something in it or the gear drive is bad. Open the door and look inside with a light. If you do not see any loose objects then I think you have a bad drive gear which would not be feasible to repair given the price of a new 19 in tv and dvd player...
May 05, 2011 | Televison & Video
Static and noise from right side speaker?
interfearence from something in house
May 01, 2010 | Yamaha Portable Keyboard
When playing a tape there is a clicking noise, its very fast (think running past a chain link fence and holding a stick against it) the tape will play, and will pop out fine, but the clicking noise is...
Something is inside the cassette well. Or one of the reels is slipping. Reach in and manually rotate each reel hub to see if you can feel any reason for a click.
Nov 07, 2009 | Aiwa NSX-AJ20 CD Shelf System
When i play music there is crackling and popping noises inside the speakers
Check to make sure it isn't the speakers with earphones. If it doesn't make the sound you have a bad speaker or a bad amplifier.
Aug 30, 2009 | Acer Audio Players & Recorders
I lost the manual.
I have an Idog and he won't play music from my nano. He will play music when I press his noise and that is it. Please help.
Oct 11, 2008 | Hasbro I-DOG AMP'D
Compaq armada m700 making loud noises
Could be hard drive, bad speakers, or even a bad sound chip on the motherboard. what kind of noise exactly is it??
Does it make the noise while playing music or anything else??
Dec 23, 2007 | Compaq Armada M700 Notebook
Yamaha SW201 Subwoofer Logo
148 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
