Question about Sony Ericsson W380i Cellular Phone
Battry is lasting only for 2 to 3 hours..phone gets hanged and it gets hot...i'l b glad if any one helps me out ..:)
    Novelist:
  • 100 Answers
Hi the problem may be because of two reasons fist check that the battery of ur cell has been used for more than one or two years generally u should try replacing ur battery after 1&1/2 years of ur use if not the electrolytes in the cell will be used up and ur cell not not be charged for more than one year if it has not been more than one year then check the pin of ur mobile for any rust marks of any sort of dust take a piece if clean cloth and take a small pinch of solution(e.x. colin,etc) and wipe the pin thoroughly with the cloth then try connecting ur charger and see whether the battery lasts long or not if the problem still persists contact ur sony ericcson service centre for help was this useful if yes pls rate my solution or provide ur problem in brief to get a more clear solution
with warm regards- bonefirediv.
Posted on Apr 04, 2011
Hi sir my mobile phone is GT-15801 and its batry finish in some hours after full charged
Hi
SIR simply your phone battry are not working or not properly charged . Some tips i will give you I hope this tips will help you.
(1). Please do not select the maximum volume.
(2). Please do not put your phone on vibration mode.
(3). select no light from the day hour.
Thanks you.
Mar 27, 2011 | Samsung Cell Phones
FOR HOW LONG CAN THE BATTRY LAST BEFORE YOU CHANGE IT
How Long Does the Nokia E65 battery REALLY last?
Ever wonder how long the phone battery actually lasts? For the first use of my Nokia E65, I charged the phone for 24 hours after receiving it (still not sure if this is necessary), then took it off the charger Saturday afternoon. The battery low warning first sounded 54 hours later. This was after
•Calls: Around 15 calls made and about 3 calls received, with almost 40 minutes call duration in total.
•Data: 726kb data sent and 3.96mb downloaded
•WIFI: About 20 minutes of WIFI use
•Applications: Use of Skype and Gmail application as well as a bit of Nokia Maps and Google Maps
The battery eventually gave up after 2 more hourse of standby. The Nokia website says the following about the Nokia E65 battery:
•BP-4L 1500 mAh Li-Po standard battery
•Talk time (maximum): GSM up to 11 hours; WCDMA up to 4h 40 min
•Standby time (maximum): GSM up to 18 days; WCDMA up to 20 days;WLAN idle up to 170 hours
If you are wanting to make comparisons with the Nokia E71 battery life, this is what the Nokia website claims for the Nokia E71. The Nokia E65 and E71 both use the same battery - BP-4L 1500 mAh Li-Po battery but E71 is slightly more demanding on the battery life.
•Talk time:- GSM up to 10 h 30 min- WCDMA up to 4 h 30 min
•Standby time:- GSM up to 17 days- WCDMA up to 20 days- WLAN idle up to 166 hours
If you are willing to help, maybe you can do the same experiment for your Nokia E65. Use the call logs and the data counter under "Connectivity" and measure how long your Nokia E63 battery lasts with "normal" usage. Report your findings in the comments below and someone just as curious as you googling battery life E65 will also benefit from your efforts.
Your mobile habits may not be as demanding as me but I hope this helped you in your battery life calculations for the Nokia E65.
To charge a battery from empty to full, it took 2 hours and 40 minutes
....... If you are willing to help, maybe you can do the same experiment ... It lasts me about 40 hours before I get a battery low warning .... I got my Nokia E65
Jan 05, 2011 | Nokia e65 Cellular Phone
Battry low 2hours
The problem is either the battery is weak or the phones terminal head consumes battery.
To solve the battery problem, all you have to do is to replace the battery with a new one, to confirm if it is the battery, first try to use the battery when fully charged in another phone, to see if it works lesser than 2 hours or above 2 hours. If it works for 2 hours then it is the battery, and if it lasts beyond 2hours then it means the battery is okay.
For the battery terminal head, you will have to open the phone up with the appropriate screwdriver, then you get a soldering iron to melt off the lead on the terminal head, then you replace it with a new one. The terminal head is the metallic object that connects the battery to the phone, that helps the phone receive power from the battery.
After checking and solving the problem, your phone should be in good shape.
Take care and good luck
NB: if you are not familiar with such technical activities, i will strongly advice you seek technical assistance from a professional close to you in order for you not to damage any part on the panel, as erevy part inside the phone are very fragile and require very careful and thorough process.
Oct 19, 2010 | Samsung SGH-J600 Cellular Phone
Mere pas motorola RAZR-V3i cell hai uska har time battry problem
Please give me the details to the problem of your phone in English, i will be glad to help.
Regards.
Jul 30, 2010 | Motorola Mobility RAZR V3i Cellular Phone
Samsung digimax d73 camera battries
yeah thats how most of those batteries are. have you tried regular batteries or rechargable batteries? try them both
Oct 09, 2009 | Cameras
LG viewty ku990 - no battery life and phone gets really hot
Hi
I dont know if this will help you, but it helped me. I had the same problem, with phone not holding charge and getting really hot both during and after complete charge.
I needed my memorycard from my LG to my other phone, so I took it out, and off course the phone needed to be charged so I charged it, and... it did not get hot at all, and when it was finished, the charge lasted a day and a half!! Now the problem is I cant use the memorycard anymore in my Viewty :S Win/Loose situation i guess....
Dec 26, 2008 | LG KU990 Viewty
Software hang
there is two options 1.  Trun off your mobile and remove your battry again turn if on this may fix it.
2. The other option is more possible to solve it you have to make master reset your mobile it is 100% chances after this your wlakman will start working.
 Remember to safe your all contects and messages all other thing before master reset.
Hope this will help you.
Nov 22, 2008 | Sony Ericsson W550i Cellular Phone
The phone became dead, recharging led does not light up.
On following the steps as stated in my problem text. I kept the phone idle for 2 hours, then I pressed the "ON" button, the screen lighted up and then went "off" again. I again pressed the "ON" button, the screen lightened up and the windows setup completeded in 2-3 minutes. The phone started to work. I think the phone got hanged since the battry went too low. Now it is working OK. I will always keep the battry charged.
I thank you and all your team mates for all the assistance you have extended in solving my problem. I am grateful that your site gives ample knowledge to sort such problems by the user.
Once again thanks a lot,
Regards
John
Sep 06, 2008 | HTC P3300 Smartphone
V800;bad!!!
try buying a new battry then charge it for sumthin lyk 16 hours
Apr 17, 2008 | Sony Ericsson V800
Sony Ericsson W380i Cellular Phone Logo
37 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
