Question about US Night Vision Thermal-Eye 250D Thermal Imaging Digital Monocular w/ 75mm EF Lens 32616041
Turn on unit, can hear it fire up but no image on screen. wondering if it is an issue with batteries. But lens is cracked and has a small portion along the edge missing on the inside.
    Master:
  • 577 Answers
First let us get some clarification on this thermal eye 250D. Did you drop the unit? Was it bouncing around inside a vehicle, box, while be transported? How bad is the whinning? I think I know what the problem is with thermal imaging system. It destroyed!! Need to call the manufacture and ask them what to do about this broke thermal imaging devise. As well as you know, these thing are not cheap!
You also need to get some clarification on what it will cost to repair this thermal imaging system.
Sorry. stewbison
Posted on Aug 15, 2011
The screen will not show the image. it looks as if the screen is cracked, but there is no crack on the screen. also the zoom will not go in or out. the camera turns on, you can hear it and the lights on...
firts resolve the lens issue
1.- Clean the lens surface with a soft cloth (clean the cilinder body of lens)
2.- Turn OFF the camera.
3.- Gently Push the lens
4.- Gently PULL the lens while you turn ON the camera
Check if the lens go in and out. If the lens don`t move try again step 2 to 4
If the lens move, and the Screen continue NOT image (screen is white) you need replace the lens sensor
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 22, 2011 | Kodak EasyShare Z650 Digital Camera
Hi, i HAVE A 2003 HONDA ACCORD COUPE. MY TOUCH SCREEN WAS SAYING DVD DISK ERROR SO I UNPLUGGED THE BATTERY AND NOW IT IS SAYING CHECK DISK. PLEASE HELP HOW DO I GET MY TOUCH SCREEN BACK UP.
Dvd disk error and check disk error both are same error.The name is different.In both cases the lens in the dvd unit needs to be checked.The lens is either moved from its position or getting blocked by any dust or any dirty stuff got stuck up on the thin lens glass internally.
In some cases the lens is cracked so the lens assembly needs replacement.But first try cleaning the lens with a dry tissue.You can also try blowing air from air blower first.Blow air in the unit where the disk is inserted/placed.Then check.If still same then the unit needs to be removed out to disassemble to clean the lens manually and also this will help to know if lens is cracked or faulty.
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Jun 11, 2010 | Car Audio & Video
Lens cap is off battery is fully charged it will
possible ccd issue.screen indicators for sure is ok, and viewfinder would show same black screen.this model is included in a recall by sony because of a defect in the ccd imaging sensor years back.but sad to say the program (and even the extension for it) is no longer available for all affected camcorder models. now it only includes the dsct1 and dscf717 dig cams.i.m sorry this unit would need replacement of the ccd imaging sensor.hope this info helps.thanks.
Mar 28, 2010 | Sony Handycam CCD-TRV318 Camcorder
Image through nikon f80 dark and cloudy
I'm unfamiliar with the F80 but on models like the f65 and f75 the viewfinder screen has an lcd overlay and when the battery is exhausted or removed the viewfinder goes dark and blurry.
Looking at a picture of the f80 it looks like it's just an update on my f75 so it strongly suggests that you just need to insert a fresh battery. The lcd does draw power from the battery even with the camera turned off.
I hope that you found my answer useful, once you've tried another battery to confirm what I've suggested I'd appreciate it if you return the favour by rating my answer.
Jul 20, 2009 | Nikon F801S 35mm Film Camera
Nikon Coolpix 3100 dead w/ lens extended
I'm curious if the Battery you replaced the first battery you had in it was also bad. That is rare but possible. Another Issue maybe that the door isn't closing all the way creating a cood electrical connection for the batteries inside. It maybe as simmple as applying outward pressure to the battery door. You may need to have the door replaced, unless you can either bend up the metal contacts to assist in the connection ro use something like a small papeclip and some super glue to bridge the contacts.
Dec 08, 2008 | Nikon Coolpix 4600 Digital Camera
Mitsubishi WT-46805
Most probable cause is a cracked or bad solder joint on th blue CRT drive board which is the small board attached to the bottom of the blue CRT
Oct 17, 2008 | Mitsubishi WT-46805 46" Rear Projection...
Philips Rear Projection Issue with Color Alignment.
this seems to be convergence problem in your tv .............
Aug 23, 2008 | Televison & Video
Image problem
It appears to be a problem with the CCD sensor in some models and Sony is recalling those units for free repair until Sept 30 2008. Humidity or heat is affecting the CCD where a portion of the screen or the entire screen image is gone. Sound still will work. Check the sony site.
Dana
Mar 18, 2008 | Sony Handycam DCR-TRV27 Mini DV Digital...
CRACKED
The Stress of impact on the imaging forming unit that is directly behind the projection lens has a flat glass surface. If it is cracked the stress cracks would project with any image because they are on the same plane as the image
Nov 22, 2007 | BenQ MP610 Multimedia Projector
Optics Logo
87 people viewed this question
Top US Night Vision Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an US Night Vision Optic Expert? Answer questions, earn points and help others
