Question about Nokia N73 Cellular Phone
My phone is say that no memory card is - Nokia N73 Cellular Phone
Is your memory card 8 or more GBs? Certain phones have Operating System restrictions on the amount of memory that can be expandable.
Posted on Apr 04, 2011
Memory card no dedect,and no files in displade.
Hi,when a memory card does not detect on phone, it simply because the the memory card you inserted into the phone is not properly fixed or the memory card you inserted into the phone is damaged,that's when if doesn't detect the memory card on the phone.
You can insert the memory card inside a card reader or a friends phone that uses the same memory card type to confirm if the memory card is not damaged yet.
I guess that will solve the problem.
Take care.
Oct 11, 2010 | Sony Ericsson G502 Cellular Phone
Continues to tell me to insert it when it's there
The reason the phone is not reading the memory card is either the phones memory card slot is faulty or the memory card is not in good conditions.
To test if it is the phone, try a well tested memory card in the phone to see if it reads it, if it does not then it is the memory card slot.
to solve that, try to open the phone and clean with spirit and drey it with the heat from a bulb, or you can replace the slot.
To test if it is the memory card, try the memory card another phone that the memory card is working fine.
if it does not read the memory card, then the fault is from the memory card, and the solution is simply to replace the memory card.
Make sure the memory card is not above 16GB.
Take care
Jun 14, 2010 | Samsung SCH-U450 Cell Phone
How to copy message from memory card to phone memory in nokia n72
open the folder, mark the messages, set destionation as phone memory, then copy them
Jan 06, 2010 | Nokia N72 Cellular Phone
I forgot my lock code how can i get it
A locked memory card can restrict you from accessing the essential features and functions of your cell phonemag-glass_10x10.gif. Without access to your numbers, pictures, or ringers, you could be left with a very empty cellular experience. With a simple memory card reader, you can unlock your Nokia N73 memory card in mere minutes.
  1. Step 1 Turn on your Nokia cell phone.
  2. Step 2 Remove the memory card from your phone by sliding off the back panel and prying the memory card out of its slot. Place the memory card into your memory card reader.
  3. Step 3 Create this directory on your memory card reader: E:\System\Recogs.
  4. Step 4 Type the code: thc-nokia-unlock.mdl into your new directory on the memory card reader.
  5. Step 5 Take the memory card out of the memory card reader and replace it in your cell phone. Wait around two to three minutes for the directory program to load from the memory card into your phone.
  6. Step 6 Take the battery out of your phone next, which is found under the back panel and near the memory card. Next, remove the memory card again and replace the battery.
  7. Step 7 Turn your phone on again. Your new unlock code for your phone will be "12345."
Nov 17, 2009 | Nokia N73 Cellular Phone
Phone memory full
Solution 1: Set to save the files into SD card rather than into Phone memory. For example, set song folder and picture folder to a location on memory card. Refer to the phone manual for detailed steps.
Solution 2: use a computer and card reader to manually store songs into SD card. Then set the phone to folder into sd card to get the songs. Clear phone memory afterward.
Jul 31, 2009 | Samsung Cell Phones
N73 memory card locked
You need a memory card reader to do this.
Create this directory on your memory card reader: E:\System\Recogs. (Note: Here "E:" drive is your Removable drive of the Card, may be F,G,H...) Type the code: thc-nokia-unlock.mdl into your new directory on the memory card reader.
If i was helpful, kindly do Rate!
Jul 23, 2009 | Nokia N73 Cellular Phone
Memory card isshowing corrupt
That means that memory card is faulty and you must replace the memory card.
Test the memory card on a computer using a card reader and test a different card inside the phone.
If the phone returns same error with all memory cards, then the phone memory card slot is faulty, otherwise just replace memory card.
Jul 11, 2009 | Nokia N70 Cellular Phone
All of my files have gone :O
That means that the phone is not detecting the memory card.
this happens either when memory card is faulty, or when there is a problem on memory card slot contacts in phone (eg:dirt, broken contact).
Test the memory card on a computer with card reader.
If memory ccard does not work on PC, then the card is faulty, data may be lost. In that case test phone with new memory card.
If memory card is OK , try blowing into memory card slot in phone and reinsert memory card in phone after backing up your data.
If the phone does not work with more memory cards, then the phone memory card slot is defective.
Regards.
Jul 11, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
FORMATTING A 1MB MEMORY CARD FOR SAMSUNG D900i
The memory card is pre-formatted. If a memory card needs formatting the phone will request that you format the memory card (the menu for this will appear on the phone). You can't re-format it. Memory status
You can check the total amount of memory for media items and the amount of memory currently in use in each media box.
Your phone is preset to use FAT16-formatted memory cards.
If you insert a FAT32-formatted memory card, the phone will ask you to reformat the
memory card. If you do not, you will not be able to access the card from the phone. If a folder on a memory card has sub folders which exceed the maximum folder depth supported by your phone’s file system, you may not open or delete the maximum depth sub folders on the phone.
Frequent erasing and writing will shorten a memory card’s lifespan.
• Do not remove a memory card from the phone or turn off the phone while data is being accessed or transferred. This could result in loss of data and/or damage to the card or phone.
• Do not subject memory cards to strong shocks.
• Do not touch memory card terminals with your fingers or metal objects. If dirty, wipe the card with a soft cloth.
• Keep memory cards away from small children or pets.
• Do not expose memory cards in a place subject to electrostatic discharge and/or electrical noise.
Apr 04, 2008 | Nokia 6288 Cellular Phone
Nokia N73 Cellular Phone Logo
49 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
