Question about Intel Motherboard
I have a asus presarrio cpu andthe motherboard is p48t i want to upgrade it but theres no available that will fit the casing
    Problem Solver:
  • 12 Answers
Which form factor do you have?
Posted on Apr 04, 2011
Where can I get instructions to put unidentified tower together?
You have all the pieces .. motherboard .. cpu .. ram .... heatsink/cpu fan?
Place the cpu into the motherboard socket. Note that it only fits one way. Check the pins on the cpu against the holes in the socket. Hold it in place with the securing catch/lever that you will see on the side.
Smear some heatsink/cpu paste onto the top of the cpu. The heatsink paste is basically a 'heat resistant glue'
Put the cpu cooling fan onto the cpu and screw it into position. Or, it may have a securing lever to hold it in place.
Put the RAM into the ram slots. They only fit one way. Make sure they are firmly in place.
Put the motherboard into the casing. Align what holes you can and use the screws that come with the casing to secure the motherboard.
Connect the casing power supply to the motherboard. Note that it only fits one way.
Connect the cpu cooling fan to the motherboard connector. It only fits one way ..
Next, look at the leads that are just lying loose .. the small female 2 pin connectors will be marked 'PWR' ..'LED'..'RESTART' ... There maybe 8 of them.
On the motherboard identify the block of male 2 pin connectors. The female connectors must connect to them. You'll need good eyes and probably a flashlight, as the writing on the motherboard is small..
If you are connecting a sata hard drive, connect to the motherboard connection that says 0. Connect your dvd drive to '1' Again, notice that sata leads can only fit one way.
Then connect any video or sound cards to the motherboard (if any).
Just look on the motherboard for anywhere the connecting wires will attach. You won't go far wrong.
The casing won't come with instructions of 'what to do' as such. If there were instructions there it would relate to pin/hard drive connections.
What you CAN do is a google search. If, for example, your motherboard is an ASUS 123456 .. search for 'ASUS 123456 motherboard connections'. Or log onto the motherboard manufacturer's website ..
Here's a couple of links that may help:
How to Build Computer The Complete Guide
How to build PC step by step comprehensive guide
Feb 19, 2016 | Computers & Internet
Unknown cpu detected asus.Bios update is required to unleash its full power.
You will get this message when you install a CPU that is not supported by the mainboard BIOS. Many older mainboards have sockets that will support much more powerful CPUs than they were originally manufactured for. In some cases, the BIOS may be upgradeable to support the new CPU, in others, the CPU may draw too much power or the mainboard chipsets will not support the CPU capabilities. If your CPU is on the list of compatible CPUs...you may need to upgrade the BIOS to support it. You will need to install a CPU that the mainboard will run with to do the BIOS upgrade prior to installing the new CPU, however.
Jan 03, 2014 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
What motherboard is in asus k50i-rbbgr05 and whats the best cpu upgrade for it if any currently Pentium duo core t4400
Hello here is the asus home page:
http://www.asus.com/Notebooks_Ultrabooks/K50IJ/#support_Download
Try to contact the asus support before upgrading the cpu.
Your laptop will probably not support a bigger cpu, because there is a limit here.
The cpu from another model will probably fit the socket, but the pc will not boot at all.
This depends on how the mainboard is build, cache size and so on.
Its also very expensive to buy a cpu for a laptop.
This can easy cost the same as a new laptop.
The mainboard is build by asus or intel.
It would be easyer to by a laptop with a bigger cpu.
They do exist as quad core.
Good luck
Jun 12, 2013 | Computers & Internet
P5S800-VM/S
The best you can fit is an AGP 8X type card. They are difficult to find now, so the prices of decent cards are going up. Your computer is about 3 generations behind, You would get better graphics performance by buying a new motherboard, CPU and memory bundle. It would be cheaper in the long run, as you could then upgrade the graphics card in the future and then upgrade the CPU as well. You can still keep the case and other computer peripherals you already use. But if you want an AGP card look on the Auction sites.
May 10, 2013 | ASUS P5S800-VM Motherboard
Is it possible to use intel duel core E5400 processor with MSI B75MA-P45 Motherboard? or any other motherboard support DDR3?
Hello here is the cpu list, for the asus board:
http://www.asus.com/Motherboard/P5QLCM/#support_CPU
Here is the msi site:
http://www.msi.com/product/mb/B75MA-P45.html#/?div=Basic
Your current cpu will not fit on the msi board, because it is a different socket.
The asus board has socket LGA 775, and the msi board has socket 1155.
You have to buy a new cpu for the msi board, to make it work.
Here is the cpu list:
http://www.msi.com/product/mb/B75MA-P45.html#/?div=CPUSupport
If you want to keep the socket 775, you probably have to find a used mainboard, because this socket type is phased out.
Some online stores still have this mainboard type available, but a new mainboard will have the DDR3 ram socket.
Good luck
Feb 13, 2013 | EliteGroup 945GZT-M (V1.0) Motherboard
Is there a current motherboard that will fit in a Sony Vaio pcv-RZ22g case to replace an old Asus P4S533 motherboard?
Desktop computer cases have mountings that suit the majority of motherboards.
You most like need a new switch mode power supply as the existion one won't have the correct power connectors and won't supply enough power.
Jan 22, 2013 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
Uatx motherboard in mini atx case
Probably however if you upgrade the motherboard you will have to upgrade the CPU, and the memory, possibly the hard drive if the old board is IDE and the new is sata. Also you would have to upgrade the power supply if it's so old it may not have sata power connectors.
Dec 24, 2012 | Compaq Evo Workstation W6000 PC Desktop
I have a Pentium 4 1.7Ghz 478 socket 400mhz CPU in my Ps4800d-x motherboard. I want to upgrade to a faster processor. There are 3.2Ghz & 3.4Ghz available. But is there a maximum size I can install?
Open the link provided. These are the CPU's the motherboard can run.
http://www.asus.com/product.aspx?P_ID=tElmFMz0YPEK37pl&content=specifications
P4-3.40 GHz (800 FSB, L2 cache:1MB, rev.G1) is the fastest CPU listed. The 1MB cache makes this CPU the fastest of the bunch. You may need to flash the bios in order to run this CPU. Click the Go button to the right of the CPU listed to update you're bios if bios version No# 1006.002 is not installed.
Cheers'
Mike
Mar 31, 2010 | ASUS P4S800D-X Motherboard
Asrock p4i65g motherboard
Your current motherboard is an mATX form factor. I recommend staying with that form factor for your new motherboard if staying with your current case. When upgrading to the new board you choose don't forget that you may need to upgrade the power supply unit also. You should upgrade to either a socket AM2+ board with dual core amd cpu or socket 775 board with Intel Duo Core2 cpu.
May 02, 2008 | Intel Motherboard
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
