Question about Samsung HC-P4363W 43 in. TV/DVD Combo
All lines of convergence is wrong who I can restart adjusments?
  • Samsung Master
  • 3,459 Answers
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
SOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs thall lines of convergence is - 578ba6c.jpgnged.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 15, 2011
I have slightly double images on screen on my Mitsu. WS 65809
just go to convergence adjusment , and try to todo that , some times this tv u need todo little tunup
Aug 26, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Convergence
After replacing the stks you need to perform convergence adjusment procedure.
If Stk keeps burning out then replace convergence board.
Sep 03, 2008 | Sony KP-46WT500 46" Rear Projection...
Convergence is good only in the center. Also adjustable only in the center From the center out the picture is distorted and bowed.
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 20, 2010 | RCA P52937 52" Rear Projection Television
Convergence is out, magic focus not useful. Help? There are adjustments on the lenses but how would you adjust with the back removed? . Yes, I know something about electronics, CRT's, and even lasers. I...
Unless the CRT gnomes got in there and messed with the FACTORY SET focus adjusment then don't touch them. you'll only make it worse, you need to have the convergence board rebuilt and it should work fine.
Jan 02, 2010 | Hitachi 53UWX10B 53" Rear Projection...
Convergence problem
Are you trying to adjust it in the customer menu?
There is a hidden tech menu where you adjust and SAVE THE ADJUSTMENTS.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} TOSHIBA CONVERGENCE ADJUSTMENTS
MUTE,
MUTE & HOLD ----THEN MENU ON TV SET
“S” SHOULD SHOW
MENU AGAIN
7 FOR GRID, 3 FOR EACH COLOR
7 AGAIN TO SAVE AND EXIT
NAVIGATE WITH 2, 4, 6 AND 8 BUTTONS
If it does not save you have a problem with either the convergence output chips or the part of the set that stores the adjusments.
If this helped you rate this solution as I do this here for free.
SD TECH
Dec 10, 2009 | Toshiba 57H83 57" Rear Projection HDTV
Model# AV48WP30 Picture show double vision. Colors cant be adjus
you need to replace the convergence ICs and associated resistors you can get the repair kit at the following link for your model which contains the two ICs and all the feed resistors plus step by step instructions with detailed photos how to do the repair. Heres the link to the kit for your model.
http://servicemanuals.vstore.ca/product_info.php/pName/av48wp30-convergence-repair-kit/cName/convergence-repair-kits
Mar 05, 2009 | JVC AV-48WP30 48" Rear Projection...
52 inch rca hdtv has red blue green lines through the top of it the picture is curved and its 3d looking
It seems convergence problem in your tv.
Let me know model number to help you out in better way.
Sep 27, 2008 | Televison & Video
Light blue banded on screen projects the image double
change the stk you have problem with convergence & change the resistor burned near stk R =2.2 ohms adjusment convergence wiht menu
Sep 12, 2008 | Televison & Video
Red,Blue,Green Image
YOu have convergence issues. Ok first question. IN your setup menu do you have the convergence option/ if you DO not then it can be a specail fusable link. fl231 if you do. next question do the picture bow in at the middle. if you do then it possibly a convergence power supply issue. next if you go into setup convergence does the crosshairs adjust up or down left to right on both blue and red. I if so then theres is a chance that it can be a convergence adjusment or a amplifer problem AS always THIS SET CAN GENERATE LEATHAL 380 VOLTS EVEN WITH SET UPLUGED SO BE CAREFULL.
Jun 20, 2008 | RCA HD52W59 HDTV Projection Television
Convergence Problem w/Proscan PS56670
IN THAT CASE YOU NEED TO REPLACE THE CONVERGENCE STK'S AND SOME TV'S NEED A INTERNAL ADJUSMENT AFTER REPLACE THE CONVERGENCE.
Aug 30, 2006 | Proscan PS56670 56" Rear Projection...
Samsung HC-P4363W 43 in. TV/DVD Combo Logo
191 people viewed this question
Jerry Greenberg
Jerry Greenberg
