Show horizontal line.i replaced the ic checked all resistance & fuses but still fault is there
  • 1,238 Answers
Good day sir
if you already replace a new vertical I.C. there's a problem with the supply of your I.C. 24v dc.
I give you some steps for D.I.Y. troubleshooting
first,remove the cover of your TV loosening all screw at the back
secondly,look for the part number of the vertical I.C
thirdly,click this site to identify the pin connection of the I.C to determine the supply.
http://www.alldatasheet.com/
next,type the part number of I.C.then go down and click the view P.D.F...after that,click download to view... adobe reader is needed to download and see files.its free
fourthly,after you see the pin configuration, check the supply voltage of I.C 24vdc..if the supply is too low or totally dead,check the print line of PCB to find where the supply came from its usually found on secondary of fly-back..check all resistor and diode near to the secondary of fly-back
and finally if done all process replace a new spare parts if you found the defective one
thank you and good luck
Posted on Apr 04, 2011
Sony 29 crt flat tv dabble picture and sifted horizontally
Main system chorma IC fault. Horizontal rolling is the fault. Replace that IC. Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences of the author of that site.
Sep 22, 2016 | Sony Televison & Video
How do I restore missing video?
Video processor IC [Chroma IC] fault. Replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 14, 2015 | Televison & Video
I have a sharp tv. the problem is when i turn on the unit it shows a single horizontal line then immediately relays clicks then turns to stand by mode. i already change the vertical ic.
Vertical scan output failure. That is the reason for this horizontal line, right across the center of the screen. Check and replace damaged component/s at it vertical scan output section circuit. Check the solder terminals of the vertical scan output IC; for any loose solder points. Contact any service technician, if you're not handy in electronics.
Line, faults & possible causes to TV screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 01, 2014 | Sharp Televison & Video
My sony tv model no. kv-ha21m80 is on standby mode & its LED is blinking four times that means it has some problem in vertical section.But when I tried to check voltages of its vertical IC AN5522
Disconnect Vertical supply and so that your Horizontal system run check all voltages before connecting vertical again ...should the protection come in again when vertical connected ...replace Vertical Ic and safety resistor in line
Apr 21, 2012 | Televison & Video
Nec pf-68v21 pwr led flashing red green after horizontal output
check the supply at horizontal driver trans former ,if voltage is correct at ho/driver trasistor ...then check allthe fusible resistances from power supply,,,if tv is taking h/oscillation for awhile ,,give more screen control in lot,,, & see for a horizontal line ,,,before tv becomes off,,, if so vertical ic problem...
Mar 16, 2010 | Televison & Video
My 15 year old Toshiba Televisiononly shows a narrow horizontal band in the middle of the screen. Sound OK.
Hiii fairley,
You aren't specsificly dercribe yor tv set.
For common TV horizontal problem ;i.e : White line accross the horizontal screen, horizontal band,etc..it's can solved by replacing the IC Vertical/Transistor, and olso to replace the cap nearest the IC.
For common TV Vertical Problem :i.e : White line at the center of the screen (top to bottom),Vertical band,etc...It's can cure by Replacing the Horizontal IC/Transistor,and offcurse the cap's.
Tha's what all I know....
Hope can help you to solved the problem.
Thank's
h3liax
Jun 22, 2009 | Toshiba 32A33 32" TV
Stationary horizontal lines
This is a flyback issue and it would need to be replaced. Aslo check the horizontal IC's for faults.
May 25, 2009 | Philips CCA132AT 13 in. Combo
Convergence lines are SLANTED. Red line is above horizontal center on left side on screen and below horizontal center on the right side of screen. Also left of Vertical center at the top of the screen and...
did you check the six 3.5 pico fuses that are next to the ICs? They will often be open ( blown) when the ICs fail. Also check the two 5 amp IC protectors on the G board as those protect the two ICs so its possible they have blown also a 5 amp pico can be substituted for the two IC protectors.
Apr 26, 2009 | Sony KP-46WT500 46" Rear Projection...
Blown 4 amp fuse twice
ok appaloosa! is the fuse blowned again? if blow you have fault unregulated power section, you have defective parts like.. leak degausing or defective diodes or capacitor and or regulator IC. 2nd. defective horizontal output. if not blow the fuse u have fault oscillation!
Sep 14, 2007 | Pioneer SD-P55A3-K 55" Rear Projection...
Horizontal White Line
Sounds like something is getting hot causing voltage loss or drive pulse loss to the vertical IC. Maybe you have a bad solder joint. Try tapping the circuit board around the vertical section. A capacitor could be heating and opening up. Stargazer Also you might try using circuit cooler spray and make the problem show up.
Apr 19, 2007 | Sansui TVS2750 27"
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
