Question about Kitchen Ranges
I have a Carrier AC Optima Plus D EQR. It suddenly started showing temperature in Fahrenheit from Celcius. I was told by the service center that its an issue related with PCB which requires a change. It seems like a trick for making more money. Can you please confirm if the PCB needs attention to be changed or maybe some other part to be replaced? Regards, Rajat.
  • 409 Answers
SOURCE: gas stove DCS
sounds like the thermal fuse may have gone on it.
is it just the stove or does the cooktop work funny too?
a technician shouldn't cost you more than $80.00 to diagnose. part is farily inexpensive too + labour to install.
Posted on Sep 13, 2008
erpaalai
  • 999 Answers
SOURCE: The oven setting was accidently changed to
Press and hold Custom Broil till it beeps then press off/cancel to exit.
Eric
Posted on Jul 04, 2009
SOURCE: Have a Carrier Window AC (1.5ton), Model:
carrier 1.5 tr outdoor unit wiring connection please.
Posted on Jul 21, 2009
  • 382 Answers
SOURCE: how to change the temperature from fahrenheit tot
just push and hold button and it should ask you what you want to do if that does not work refer to manual or call a toyota dealer and ask
Posted on Dec 22, 2009
Testimonial: "thank you for the prompt reaction"
SOURCE: Switch from Celsius to Fahrenheit Temperature setting
Press cancel and bake buttons simultaneously for 3-5 seconds until C appears then use up/down buttons to change to Fahrenheit. Hope this helps!
Posted on Mar 10, 2010
How do you change from celcius to Fahrenheit?
To convert temperatures in degrees Celsius to Fahrenheit, multiply by 1.8 (or 9/5) and add 32.
Temperature Conversion Celsius to Fahrenheit ' F to C or C to F ' The ...
https://www.almanac.com/content/temperature-conversion
but the easiest way is to use a conversion website, or a conversion app on smartphone
celcius to Fahrenheit Google Search
Jun 09, 2018 | Cars & Trucks
Tip
Refrigerator Tip!
Don't set your refrigerator's temperature too low. The colder it gets the more it costs to run. Set the refrigerator's temperature to between 38 and 42 degrees Fahrenheit (3 to 6 degrees Celcius) and your freezer to between 0 and 5 degrees Fahrenheit (-17 to -15 degrees Celcius).
on Aug 17, 2010 | Refrigerators
My kitchenaid works fine however I have hit something and when I press the bake button it shows 180 degrees instead of 350 all of a sudden. How do I reset it? I tried shutting off the breaker but that...
you neglected to mention the model this is , but most of the ovens made by them , when switched to bake , 1st show the temp you adjust then after thrirty seconds or so show the actual temp of oven (this number will change) the set temp function can be adjusted to anything in the ovens heat range 100-450) using the arrow keys anytime in the bake cycle , just touching a arrow key will change display to set temp screen , from actual temp display
Mar 07, 2015 | KitchenAid Ovens
How to switch from fahrenheit to celcius?
Best to just keep a conversion chart nearby...or label your gauge with Celcius...
Aug 23, 2014 | 1991 Buick Park Avenue
Change celcius fahrenheit
The easiest way of changing temperature from celsius to fahrenheit is getting it converted online.Check this link out: http://www.onlineconversions.org/
Jan 01, 2014 | Refrigerators
I purchased a 52 bottle kitchen aid wine cooler. No matter where I set the thermostat, it is always 45 degrees and readouts are sideways "T's" instead of numbers.
You will need Adobe Acrobat Reader to view these documents. The Adobe Acrobat Reader is available as a free download. arrow_results_summary.gif Get Adobe Acrobat Reader Click Here=> KUWA244PBS Parts List
and here=> KUWA244PBS User and Care Guide
If you should need the service manual you will need to cant me here=> HERE Reason is Whirlpool does not allow me to publish the SM here.
The beverage center and wine cellars have a temperature display for each zone. 12 volts
AC is supplied to the display board from a transformer in the unit compartment. The displays are only temperature displays and have nothing to do with any cooling function. A thermistor is used to sense temperature for each zone. The thermistor for the bottom zone is located inside the lower portion of the separator. The thermistor for the top zone on the wine cellar, (mid zone on beverage
center), is located in the upper portion of the separator. The thermistor for the beverage center upper zone is located on the inside of the 2-piece evaporator cover. It is on the right-hand side.
The mid temperature for the bottom zones on either unit are 60? Fahrenheit plus or minus 5 degrees. The mid temperature for the mid zone on the beverage center and the top zone
on the wine cellar is 45? Fahrenheit plus or minus 5 degrees. The mid temperature for the
top zone on the beverage center is 38? Fahrenheit plus or minus 5 degrees. I think at tis time you should check each section with a pocket size digital thermometer to cofirm tha the mechanical thermostat is within calibration. Click Here=> 4344690 Temperature Control
Click here for a=> KUWA244PBS Beverage Center Wiring Diagram
I believe the problem may be in the PCB transformer shown at the bottom right corner of the wiring diagram. It is possible o change the transformer but I have not been able to find the board that powers the LED temperature readouts. If needed let me know and I will call Whirlpool mfor you, Thanks, Sea Breeze
Oct 09, 2011 | KitchenAid KUWA244PBS Wine Cooler
The temp reading is in celcius how do i change to fahrenheit?
From Celcius the formula is Deg. C divided by 5 multiply by 9 and plus 32.
From Fahrenheit the formula is Deg F minus 32 divide by 9 multiply by 5.
Feb 23, 2011 | 1996 Buick Park Avenue
What is the formula for 32degree celcius to fahrenheit?
the formula to convert degree Celsius to Fahrenheit is
Tf = (9/5)*Tc+32; Tc = temperature in degrees Celsius, Tf = temperature in degrees Fahrenheit
to convert 32degree Celsius to Fahrenheit is
Tf = (9/5)*32+32 = 89.6°F
Jan 21, 2011 | Office Equipment & Supplies
Trying to convert minus c to minus f in cal plus
Here are the formulas for conversion.
Let T_C be the temperature on the Celsius scale and T_F the temperature on the Fahrenheit scale.
0 _C correspond to 32 _F
100 _C correspond to 212 _F
Generally
  1. T_C =(5/9)*(T_F -32) ; for T_F=212 _F , T_C = 5/9*(180)= 100 _C
  2. T_F= (9/5)T_C + 32 ; for T_C=100_C, T_F = (9/5)*100+32 = 212_F
Problem for you : Find the temperature which has the same value on both scales.
Jan 10, 2010 | Texas Instruments TI-84 Plus Calculator
Kitchen Ranges Logo
176 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
