Question about Bonavita Ellie
I need the hardware (nuts and bolts) for the jamie crib model number 040157751X
What size screws and bolts are required for Jardine crib model DA832BC? I've misplaced them.
I suggest you measure the holes the screws have to go through. Where nuts and bolts are used the hole will be slightly bigger to give clearance and similarly where a hole is threaded for a bolt or setscrew, sometimes called a machine screw.
If the hole is 5.5mm or thereabouts the bolt will be a 5mm and if it is 6.5mm the bolt will be 6mm and so forth.
Common sizes of bolts for furniture and appliances are 4, 5, 6, 8 and 10mm and your local hardware store should be able to provide you with small quantities of those you need though there will be a limited number of different lengths available. It is usual practice to buy a little longer than you need and shorten them to suit by using a hacksaw and cleaning with a file or grinder or a dedicated shear.
There are three sorts of nuts in common use and although plain nuts are commonly used with plain and/or locking washers, anything that moves or if kids are around a stiff-nut such as a Nyloc nut should be used.
If the end of a bolt is exposed and might snag the clothes or flesh of a passerby it is customary to fit a domed nut to cover the sharp exposed end.
Self-tapping and wood screws are a different matter. If you need information about these then please come back and ask again.
Feb 04, 2015 | Baby Gear
I am missing all of the screws for the crib. We recently moved and lost all the screws for the crib.
Lowes carries most bolts and barrel nuts. Local small hardware stores may have longer bolts if needed. I sometimes use a bolt specialty business for unique bolts. Most cribs use either a metric set or SAE. If you are replacing the complete set choose whichever is easiest to find. If they bed has glued in threaded nuts go with the matching bolts style, metric or SAE.
Jan 15, 2013 | Delta Eclipse Dark Cherry Finish 4-in-1...
I need replacement parts for my crib.
any hardware store will have the parts you need; just take a sample bolt and, nut to them and, they will find them for you. these are not a special part exclusive only to your crib.
Jul 22, 2010 | Storkcraft Baby Baby Gear
Missing bolts and barrel nuts
First try to find the Instructions online. These will usually tell you what you need. Then call Products America with this information. 1-800-205-9642. I just ordered what I needed for $20.
Jun 24, 2009 | Fisher Price Baby Gear
I need the instructions for the cosco heritage collection crib model number da0504kmc1w
This site has instructions for the cribs listed below. The 1st two listed seem to be generic cribs with a metal mattress support. It worked for my used crib.
www.milliondollarbaby.com/help.milliondollarbaby.com/
*For cribs with snap-in spring hangers hooks & metal mattress support.w/ spring hanger hdware.
*For cribs w/ bolt-in metal hdware for metal mattress support w/ metal hdware.
For cribs with Safety Glide nylon(rodless) hardware
Sleigh Convertible 3001 Crib
Sleigh Convertible 3091 Crib - Safety Glide
Jenny Lind Crib
Ashley/Alexandria Crib (1 piece headboard) +Day bed info.
Ashley/Alexandria Crib (3-piece headboard) +Day bed info
Lauren Crib ) +Day bed info
Emily Crib (One piece headboard) ) +Day bed info
Emily Crib (Four-piece headboard) ) +Day bed info
Mini Emily Crib
Anastasia Crib
Bridget Crib
Valerie Crib ) +Day bed info
Bailey Crib ) +Day bed info
Ellie Crib Day bed and full bed info
Kalani Crib Day bed and full bed info
Bordeaux Crib Day bed and full bed info
Annabelle Mini Crib
Italian Cribs-Metal Barrel Nut
Italian Cribs-Nylon Nut
Canopy cribs with snap-in spring hanger hardware
Canopy cribs with metal bolt-in hardware
May 17, 2009 | Baby Gear
Need instructions ofr converting crib to a toddler bed.
Jenny Lind Crib
Mini Emily Crib
Anastasia Crib
Bridget Crib
Annabelle Mini Crib
May 16, 2009 | Bassett New Haven 3 N 1 Crib
I am having difficulty in fixing my stork craft crib as I dont have any bolts and nuts. I bought it second hand and all the bolts were missing. model number is 65718 and manufacturing date is August 22,...
take the numbers with you or even the part that has the numbers to a hardware store... they should be able to determine what you need. i would suggest buying aircraft type nuts.... they will not loosen on their own which is abit safer. they are not alot more expensive and considering what it is you are putting together they are worth it.
Robert
Apr 15, 2009 | Baby Gear
Assembling Instructions model 01720-1
Jenny Lind Crib
Mini Emily Crib
Anastasia Crib
Bridget Crib
Annabelle Mini Crib
Dec 13, 2008 | Simmons Mattress Matino - Natural Maple...
Missing parts (pali spa crib set)
Here is Pali toll free number 877-725-4772 It helped me when I had missing screws
Sep 04, 2007 | Pali Sabrina Crib
Bonavita Ellie Logo
65 people viewed this question
Top Bonavita Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Bonavita Baby Gear Expert? Answer questions, earn points and help others
