Hi i've inserted the 32gig flash in my pc then copied stuff on it ,but it copying to slow so i stopped it and try 2 format it .....while formatting i stopped it and the it don't want 2 pickup anymore and shows that windows don't have driver for this device when i try 2 update it...thanx lester
  • 27,725 Answers
Click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options update driver disable uninstall scan for hardware changes
select properties you should see options in the general tab to troubleshoot policies volumes driver and details under the driver tab you will have the options to check the driver details update driver rollback driver or uninstall
hope this helps
Posted on Apr 04, 2011
I am not able to remove disc protection
format it useing nokia 6120c,6220,and c5-00 phone.. or view this site= http://www.makeuseof.com/tag/format-write-protected-usb-flash-drive/
Oct 07, 2014 | Electronics - Others
Cannot see pc MOV or JPG files on flash drive in Canon SX230
Thanks very much for responding to my problem.
It seems Canon will not allow edited pictures or video to transfer from PC to their digital cameras for viewing.
steps to my problem:1. my canon SX230 created all the parts for my WMV video in MOV format originally.
2. created a movie (WMV format) in Windows Live Movie Maker. Works well and plays on my PC (windows 7).
3. after WMV completed - converted to HD MOV format in 2 different file convert programs and with 2 different HD MOV resolution settings on Both programs. WMV resolution is 1920x1080 (HD). ALL 4 MOV videos play well on my PC in 2 different programs.
Steps getting Canon to see video in playback mode.1. copy MOV video from PC to Flash drive in my card reader in same folder as my original JPG & MOV files, then inserted into camera - does not recognize file.
2. copy MOV file from PC to camera with USB cable. Windows error message. Wrong format - would not copy.
3. Formatted flash drive in camera. Took picture to create DCIM folder, JPG image, and CANONMSC folder with M0104.CTG file .Deleted CANONMSC folder. Copied my MOV video from PC to camera (USB cable). this time copy successful. However camera does nor recognize file.
5. tried again except deleted M0104.CTG file but not the CANONMSC folder. no luck.
It seems Canon will not recognize any file that has not originated in the camera AND has not been altered. Upon researching answers on the NET - many other users of Canon cameras have the same problem with no luck.
Apr 23, 2012 | Cameras
I bought a new sealed 32gig G3 flash drive in south africa 2 weeks ago,when I inserted in my pc it requested that it be formatted,I try to do that but I got error message that windows unable to format...
Hello, one of the tools that provide better results is the following:
http://www.softpedia.com/get/S...
You could also try zero formatting your drive first and once finished, do a normal formatting job. Best way is to visit the flash drive's manufacturer and see if they provide a zero level formatting tool. If they do not, you can use the following:
http://hddguru.com/software/HD...
Run the tool from link above, and once finished zero formatting you can do a normal formatting. Zero level formatting will practically set your flash drive to factory settings. My advice is, to run the zero levelling format and once finished, run the Hp formatting tool
Apr 10, 2012 | Computers & Internet
My olympus vn-8100 flashed system error and stopped working
Ok, try this, works for me:
- Remove the batteries- Insert its again- Connect the recorder via usb to pc- Copy one by one each archive you need to recover, after copy delete them from the recorder- Copy SYSTEM, RECORDER AND MANUALS FOLDER to pc- Format from the pc the recorder (i use a mac - disk utility) yes it is, ERASE!- Copy again the folders: SYSTEM-RECORDER-MANUALS- Unplug the recorder, remove the batteries, insert again- Turn on the recorder, it will display a different error, format the recoder, it will restore and reset the systems files.- It works for me!-
Jan 10, 2012 | Olympus VN8100PC Voice Recorder
In my Nokia 5130c-2 mobile I've a 8GB Micro SD memory card. When I try to enter into Memory Card it tells Unknown File Format in Memory Card. Format Memory Card Yes/No? Every thing was going fine...
Put the SD card in a stand alone card reader, and copy the data off it to your computer. Next, format the SD card, and put it back in your phone.
May 06, 2011 | SanDisk 2GB microSD Memory Card
When i put my r4 into my ds its just says cant find menu?
hi it sounds like a software problem. follow the following instructions. Please can you try and reformat the 2gb micro sd card in your pc and copy firmware from the CD back onto the 2gb micro sd card following the instructions below. be warned that formating will remove even the games from the card so make sure you have a backup of the games saved to your computer. any saved games will also be erased.
To format the 2gb micro sd card
1. Insert sd card into usb stick and into usb port.
2. Close autoplay screen if it appears.
3. Right click on removeable drive. (Eg D, E, F or J etc) that appeared on screen in computer window.
4. Left click on format in menu and when format window appears, tick quick format box and select ok. This will erase all content on the sd card and remove any corrupt firmware.
To reload firmware
1. Insert cd into pc cd/dvd drive.
2. Open cd drive on screen and copy and paste the files and folders from the system/english 1.18 folder on the cd to the removeable drive that the usb and micro sd card are in. The folders that you will copy are "_system_" and "moonshl" and the files will be "menu.dat" and "mshl.nds".
3. Once copied, check removeable drive to ensure files and folders have copied over.
4. Remove usb stick from pc and insert sd card back into R4. R4 menu should appear on DS screen.
this normaly sorts this out. paul
Jul 07, 2009 | Nintendo DS Lite Console
Transcend 2gb pen drive file copying problem
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format pen drive
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jun 27, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Write Protected USB
hi Not only your pendirve your computer system is also affected by virus . please check your pendrive with any other computer .before you connected open your pendrive format your pendrive with any other computer. if it will not work you have go for any new pendirve. bye
Jun 16, 2009 | Disney High School Musical Mix Stick 2.0...
Formating 64gb pen drive
some memory cards / items do not work with FAT32, you should try to re-format using your PC to FAT16 format.
Dec 31, 2008 | Electronics - Others
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
