Question about Dell 1600n All-In-One Laser Printer
Dell 1600n scanner, not seeing my computer
Have tried adding new device at scanner icon on taskbar...entering IP of printer...still doesn't detect my computer...all other systems are fine.
  • Anonymous Aug 15, 2008
    Have the same problem
  • amelia564 May 06, 2009
    Port disabled when I try to scan from Dell Scan Center/PaperPort - or User ID required from printer (no user id exists) - no scanner listed under cameras and scanners - printer works from computer, but can't scan.
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Scanner icon? this printer is or is not listed in your control panel, under printers?
Posted on Aug 19, 2008
6ya staff
SOURCE:
The scanner is locked
There's a physical locking-mechanism that is designed to keep the movable parts of the scanner locked into place, while the scanner is being transported. On most scanners, it's either a few screws, or a lever. From the manufacturer's web-site: http://support.dell.com enter '1600' and do a search, and download the Quick Start document, to read the specifics.
Jul 20, 2010 | Dell 1600n All-In-One Laser Printer
How to unlock the scanner on Dell 1600n printer
Read the instruction thouroghly, they will tell you in there.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Nov 13, 2009 | Dell 1600n All-In-One Laser Printer
Dell 1600n I replaced the toner and can't get the "replace toner"
After you clear out the print que (double click on the printer icon on your desktop), power down the printer, wait 20 seconds and power it back up. The "replace toner" should clear after the sensor detects toner in the hopper AND the new chip in the toner cartridge registers with the "brain" of the printer. Hope that helps!
Aug 12, 2009 | Dell 1600n All-In-One Laser Printer
Dell 1600n will not connect
One of the most common problems when networking is adding the correct subnet address. To check your computers.
Click on start
click on run
type in the box "cmd" (no quotes)
click in the black dos box and type
ipconfig
This will tell you the ip address and subnet of your computer.
The ip address need to be different for the computer and the printer but the subnet address needs to be the same
Mar 06, 2009 | Dell 1600n All-In-One Laser Printer
Dell 1600n printer driver for Windows 2003 Server
I had a similar problem deploying these printers, however i found using the XP drivers in 2003 does work fine. Not sure why dell doesnt have an installer for this printer in 2003 server, but here you go.
ftp://ftp.us.dell.com/printer/R165289.EXE
extract that file, note its destination directory. do not attempt to run the setup.exe, it will fail saying your operating system is not supported.
instead navigate to (if you didnt change the path) C:DelldriversR165289p0nPrinterPCLWINXP
this folder contains the driver you need to install manually.
one stange thing about these lexmark based network printers is the need to select 'local printer' during install, uncheck automatically search for my device, and then create a new TCP/IP port. Use the IP address provided by the network configuration print out you can access on the front panel of the printer. now just make sure to select 'lexmark network card' as the type of network interface. it should now ask you for your printer type, click have disk, and point to the driver folder mentioned earlier.
hope this helps. thanks alot dell.
Oct 30, 2008 | Dell 1600n All-In-One Laser Printer
Printer will not print. Displays no paper.
Is the page stop at the back of the tray set correctly? If you have the stop a "click" off, rather then seeing letter size, it will see universal or A4 and say no paper, because it's looking for letter size. If it is on the network, just open a browser and go to the IP address of the printer, or print out a configuration report. That will tell you what size the drawer is reading.
Jun 16, 2008 | Dell 1600n All-In-One Laser Printer
DELL 1600N
If it makes verticle lines only when using the document feeder it is most likely a dirty glass strip over the scanner light bar. If it makes verticle lines in all modes (printing, flat bed scanning/copying, receiving faxes) it could be the fuser or a dirty glass over the laser where ever the laser images to a drum roller (usually a larger green roller). It is possible that this green drum roller is inside the toner - if so - replacing the toner cartridge could fix it. Maybe you could try an old used toner to see of the problem changes - if so - it is very likely that a new toner would fix your print quality issue.
Jan 09, 2008 | Dell 1600n All-In-One Laser Printer
Windows Vista can't find networkd Dell 1600n
Make sure you're using the drivers for Vista, which can be found on support.dell.com. You'll want to use the choice for Vista 32-bit.
Also, try turning off your firewall, as it may be blocking the network data.
Dec 15, 2007 | Dell 1600n All-In-One Laser Printer
Dell 1600n All-In-One Laser Printer Logo
452 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
