Question about Whirlpool Washing Machines
Water keep run and it overflows,dosnt start - Whirlpool Washing Machines
  • 1,536 Answers
The water level control isn't working. First, I'll describe how it's supposed to work, then give you the troubleshooting steps for a top-loading machine.
There is a port on the side of the outer tub somewhere below the low water level point. A plastic hose (usually transparent) runs from this port to the water level switch. As the water rises, it compresses the air inside the tube. This air exerts pressure on a diaphragm which operates the level switch. The trip point for the switch is set by a cam connected to the level selector knob.
Failure points: broken or leaky hose, clogged tub port, ruptured diaphragm, stuck or broken switch.
First, unplug the machine. Remove screws on the back of the control panel if it appears they hold it to the back panel of the machine. Remove screws from the front trim at the bottom of the control panel. Now you should be able to tilt the panel forward to get at the backside of the water level control.
Inspect the hose connection on the back of the water level control and repair if it appears it could be leaky (for example, hardened and loose or cracked).
You can test the switch by detaching the hose and blowing into the port if the switch is set to the lowest level setting. You should be able to trip it with moderate air pressure, not much more than you use to blow a balloon (literally several inches of water, to use a common pressure measurement scale). The best test is to attach an ohmmeter or continuity tester to the switch leads to verify operation - one terminal is common and goes to power, one terminal is normally closed and goes to the water valves, and the remaining terminal goes to the timer. However, if you can hear or feel the switch click when you blow into the port, it is probably good.
Next, gently tug on the hose where it goes down into the machine. It should be attached at the other end! Try firing some compressed air (about 5-10 psi) into the hose to blow out any clogs. Reassemble and test the machine. If it still overflows, you'll have to open the top to inspect the tub connection.
Note: I once worked on a machine that was clogged with a bacterial film inside the port. The customer used well water with only basic particle filtration. There was also bacterial buildup in the hose inlet screens, so I advised the customer to add an anti-bacterial filter to the plumbing to prevent a recurrence of the problem, and suggested doing a no-clothes soak with bleach to clear out the rest of the little beasties.
Posted on Apr 04, 2011
Waterboss 93000 water softener
It most likely is due to a plugged eductor/injector assembly which pulls the salt brine out of the tank to regenerate softener. If it is plugged no brine will be pulled from salt tank during regen but it will keep filling the salt tank and eventually overflow with each cycle. Or there could be a leak in the valve causing the tank to overflow.
Here is the owners manual for your model.
http://www.waterboss.com/media/WB_Softener_V1_Manual.pdf
See page 23
RJ
May 05, 2014 | Water Dispensing & Filtration
Why does the Water valve keep running water when bowl is full?
Because the shut off point is above the overflow tube. You will need to either adjust the arm or bend the float end of the arm downward to make the arm end swing higher to reach the shut off point prior to water overflowing into the tube.
Apr 27, 2014 | Korky Waterwise Toilet Fill Valve 528Z
Sounds like the water tank keeps filling
2 possibilities.1. The water level is set higher the the overflow tube. This will cause the water to run into the overflow continuously. You should be able to see this. 2. The large seal - bottom center of the tank - is leaking. This will cause the water level to slowly drop after a fill. The water tank will start to run again after flushing - BUT NOT CONTINUOUSLY. You should see if there is a small amount of water flowing from the rim to the bowl 15 seconds after the water has stopped running after a flush.
Aug 09, 2012 | TOTO ST743S#01 Drake Toilet Tank, Cotton
06 impala bleed air out of cooling system
Put heater on high heat to circulate water in those hoses and heater core. Then start the car after removing the radiator cap and filling with coolant to the top. When the radiator opens you will see the liquid level go down- add more coolant and keep adding till it stays full. Meanwhile fill the overflow to recommended level. When radiator level goes down no more, put radiator cap back on and let engine and coolant cool. If any more water is needed the vacuum created by the shrinking water will draw it in from the overflow.
Jan 11, 2012 | 2006 Chevrolet Impala
The fridge keeps leaking water underneath,the freezer part keeps iceing up down the bottom under the draws,the water is the main problem.
Water in the drain overflowing can be the reason for the water spilling,it can be the defrost overflow or the leak from the evaporator tubing's to the drain. So drain off and check perhaps more condensation is the result of the overflow.
The icing can be related to water formation from the food or leak from the evaporator, high frosting can blow the water inside the freezer.
So set the freezer temp a little lower so that the freezer shuts off than to make it run continuously.
Sep 30, 2010 | Samsung Refrigerators
When starting a load of wash the water keeps on running and overflowes
pressure switch or water valve. turn unit on then stop it if water keeps going the water valve! if not the pressur switch
Jun 23, 2010 | Washing Machines
Dishwasher overflows
Sounds like you've got a problem with the water intake valve(s). If it takes on water without water running in the sink, that is where I would look. If it happens when you use the sink, then I would also check your drain hose placement
Jun 22, 2009 | Dishwashers
Is there a manual. The water keeps running.
the fill valve shut off level setting is too high. water in the tank is overflowing in the overflow tube. adjust fill valve to shut off at lower tank level
May 12, 2009 | Jacuzzi Bath Era BK37 959 White toilet...
Water keeps running will not shut off causes and overflow
If it only overflows while the washer is running, check the pressure switch, or water level switch. The hose may have come loose, or could have a hole in it somewhere. Otherwise the switch may be stuck or may need to be replaced.
If it's overflowing when the washer is off (i.e. in the middle of the night when there is no laundry in it), then check the water valve.
Mar 26, 2008 | Hotpoint VBXR1090B Top Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
