MPOTHERBOARD PROPERLY START BUT NO DISPLAY....WHAT IS PROBLEM ....PLS HELP ME FOR THIS PARTICULARS PROBLEM
    Problem Solver:
  • 19 Answers
Simple stuff first - power and connections to monitor good?
Any work inside the machine you should disconnect power first and preferable earth yourself when you are touching the boards.
Video card (where the monitor is connected) is seated correctly. Take out and put back in.
Try another monitor and cable to ensure these are working.
Check you have the 12v cable connected to the motherboard from the PSU. It is an additional cable that is required on some motherboards and can prevent display.
Does the motherboard make any beeps? Just one is good, more is not.
If you only get one beep and you have checked all above, then maybe a problem with video card - is it a separate card - see inside in slots where your monitor cables are plugged in. Could be loose, need reseating.
Best of luck
Posted on Apr 04, 2011
Unable to transfer particurlars on photo to CD or UBS
All the "particulars" are stored within the Picassa software. Since you are coping the pictures and not Picassa itself this data will be lost. The data is stored in Picassa - not the photos.
Nov 24, 2013 | Computers & Internet
The application failed to initialize properly (0xc0150002). click ok to terminate the application. yahoomessenger.exe - application error. the application failed to initialize properly(0xc0150002). click...
I'm having the same problem, not quite sure whether it is happending due to upgrade to IE 8 or Windows Installer 4.5 installation. Cleanup and re-install of Yahoo Messenger 10 won't help. The YahooMessenger.exe fails to initialize right during the installation process.
May 14, 2010 | Yahoo Messenger
Power supply problem in a pmp 3000 behringer miker I have + - 56 rail voltage but no 12 v ? to supply the pre amp when you turn on the unit the mixer lights up briefly then dies,this is a switch mode...
I am not familiar with the particulars of your specific model, but with switch mode supplies in gereral, look for defective filter caps on the output side or a defective Zener Diode. If you can post a few photos of the power supply section, I may be able to guide you to the likely parts. Dan
Jun 08, 2009 | Behringer EUROPOWER EP2500 Amplifier
My honda 85 headache
derin, 1st thing you should do is install a new thermostat. Engines are designed to run at a certain temperature, removing the thermostat will cause the engine to NOT run efficiently. Performance and fuel economy as well as emissions will be affected in a negative way. It's possible that your radiator is plugged up with rust and corrosion. Flush out the system.or bring it to a shop to have it professionally done. A good shop can test the flow to determine if that's a problem. Hondas have a bleeder valve to allow air to be removed from the system. If the system wasn't bled properly after the thermostat was removed, that also could be part or all of the problem. Good Luck countrycurt0
Aug 28, 2008 | 1985 Honda Accord
I have a dell alatitude D505 and am unable to change the display resolution. it is on the default 640 X 480 I have XP with service pack 2 regards
It is possible that the VGA display drivers are not properly installed. Pls check your Device manager and verify that no yellow or red marks on the Display Device.
To my knowledge, there were 2 versions used in this laptop, Extreme Graphics 855GM and Graphics Technology 830M. Pls check which your laptop may be using and download appropriate driver from here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 14, 2008 | Computers & Internet
Desktop motherboard
You probably couldnt repair the display part of your motherboard. You can however add a (PCI or AGP) video card to get a display.
Nov 14, 2007 | Computers & Internet
Problem with GA-8IK1100, AGP vga card can not display properly
Hi, is this a new card? I installed a simalar one in my computer [ a used card] only to find I had intermittent display. I found out later the card had been overclocked. A new card cured the problem. If this is a new card then return it for a warranty claim. Regards mistyman
Sep 03, 2007 | Gigabyte GA-8IK1100 Motherboard
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
