Question about ASUS Computers & Internet
My ASUS Eee PC 1005P won't turn on. This had been working up until 4 days ago when I left Australia to Bali. When I pressed the power button the power light would come on but there would be no fan sound/screen message. I removed the charger and battery and pressed the power button for around 30 seconds, before putting the battery back in and replugging the charger. When I do this sometimes the power light comes on and sometimes it doesn't. Any suggestions?
    Scholar:
  • 92 Answers
Try turning it on with the battery without the charger. Then try turning it on with the charger without the battery. If it still doesn't turn on either way, it's already a problem with the laptop's motherboard. If your laptop is still in warranty, you should have it serviced. Otherwise you need to bring it to a repair technician.
Posted on Apr 04, 2011
    Novelist:
  • 153 Answers
You did the basic troubleshooting step, which is correct. I would suspect this is a problem with your computer power supply or motherboard. But most of the time, it's always the power supply. However, before concluding that, you can isolate the issue by doing the things below.
*Remove all the USB devices connected to your laptop, turn on the laptop and see if it will turn on.
*Open your laptop and remove the hard drive, turn on the laptop and see if it will successfully turn on
*Remove the memory, turn on the laptop and see if it will turn on
*Remove the CPU, turn on the laptop and see if it will turn on
*If all else fail, you should replace the power supply
*After replacing the power supply and still having problem, you should replace the motherboard as well
How do i reset my asus transformer tablet tf101 i have a blank screen will not turn on
Perform a soft or hard reset on your Asus Eee Pad Transformer Android tablet if it is not functioning correctly. Here's how.
Soft Reset
You would want to soft reset the device in the event that it has become frozen or unresponsive. To do so, press and hold the Power button on the top-left side of the device for about 10 seconds until the device powers off.
Hard Reset
A hard reset (also known as a factory reset) will clear all data and settings from the memory of the device and set it back to factory default settings. You can perform hard reset on the Asus Eee Pad using the Android OS menus or the hardware buttons.
Method 1 1. Power the Eee Pad off.
2. Press and hold the Volume Down button on the left side of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
The Asus Eee Pad will complete the hard reset process and reboot into a factory default state.
Method 2 1. Open the Settings app.
2. Select Privacy.
3. Choose Factory data reset.
4. Select Erase tablet.
5. Select Erase everything.
Dec 31, 2014 | ASUS Eee Pad Transformer TF101A1 Tablet...
Why won't my eee pc 1005p switch on or charge
check power output of the ac adapter with a DVM to insure you see 12 volts DC.
Check that the receptacle on the eee pc is not broken.
Aug 10, 2014 | ASUS US EEE PC 1005PE / 1005P
Hi guys I really need help with this !!!. my netbook(asus Eee pc 1005p) just randomly stopped working one day. When I turn it on nothing happens all the light flash once and then it turns off. Please help...
Does the battery indicator on the laptop light up when the charger is plugged in? I have had a few laptops where the chargers had the light on but they weren't actually charging the laptops. Drop me an email with more info or reply on here and I will try my best to help.
mal.odonnell.1974@gmail.com
Sep 12, 2013 | ASUS US EEE PC 1005PE / 1005P
Hit power surge
it may be due to the damage of power source...i think so...replace your battery..so that it can work...all the best
Sep 12, 2013 | ASUS Computers & Internet
EEE PC 1005P won't charge, can it be a motherboard problem?
honestly you've done everything correctly that i could think of. one last thing you could try to root out a problem with the os. is boot the computer from hirens boot disk and load the portable Windows. see if the battery is detected in hirens. then youll know if its a Windows problem or not.
personally i feel the board is the issue but it doesn't hurt to check the complete os.
Feb 26, 2017 | Computers & Internet
A/c adapter voltage seashell
Yes the power adapter output is 19 volts.
These are available from these WEB sites.
http://www.fast-battery.com/replacement-for-asus-eee-pc-1005p-ac-adapter-p-90130.html?&gclid=CMPzo7b5vK4CFUcmpAodS06hLQ
http://www.ebay.com.au/sch/Laptop-Accessories-/31530/i.html?_nkw=asus+eee+pc+1005p
Feb 25, 2012 | ASUS Eee PC 900a
Asus Eee 1005HA hangs on boot
This works for my Asus Eee PC
1. Shut down and remove the battery.
2. Press the power button 10 times, next 1 minute pressing down.
3. Remove the memory and at the motherboard you'll see a clrrst (clear reset cmos..)
4. Short these 2 tiny pads by placing a tiny screw driver for 5 seconds, plug the power adapter and turn-on the switch, next wait at least for 3 seconds. Remove the power adapter.
5. Place back the battery and turn-on. You'll see the same screen (Logo of Asus) then patiently wait for at least 10 minutes or more. That's it.Good luck.
Feb 16, 2012 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Computers & Internet Logo
1,409 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
