Question about Zyxel ES-105A (ES105A)
I have the Zyxel ES-105A connected in the following way: LAN cable from modum connected to port 1, LAN cable from port 2 connected to my laptop which I use to log in to my modum and LAN cable from port 3 connected to my SLING Catcher which needs open internet to provide me my Internet TV. But after logging in I don't get open internet, so my SLING Catcher is not working. Please advice.
  • 28 Answers
If your modem is not also a router you can only connect one device to it. You should have a router instead of a switch. Otherwise check the settings on your modem to be sure the ports are open that are needed for the Sling Catcher.
Posted on Nov 05, 2013
2 Suggested Answers
apadgett01
  • 10 Answers
SOURCE: Hi there I am working
How long did you leave it powered off for? It should be powered off for at least 30 seconds for the connection to actual die out.
If not, try click start, run, type in cmd and press enter. Then if your IP is 192.168.0.1 for example type telnet 192.168.0.1 and press enter. Log in through the command line and try enter restart, reload, or reboot. One of these should power cycle through the command line which will kill any "ghost" or active sessions.
Please let me know if this helps.
Thanks,
Adam
Posted on Nov 28, 2008
How to get zyxel nbg 416n routher to connect the netgear Prosafe 16-port 10/100 desktop switch for inhome ethernet net woke.
Plug a straight through Ethernet cable from a LAN port on the router to any port on the switch. That's all it takes. Granted most network equipment today has logic to switch the pin outs so any Ethernet cable should work.
Dec 17, 2012 | Zyxel Computers & Internet
Tip
Using Zyxel P-600 from two PCs
to use Zyxel router/modem from two pcs for internet usage : it has two ports 1 is USB 2nd is Rj-45 connector LAN port
connect it with one pc via USB cable and connect 2nd via LAN port using Cross cable then its one DSL connection from two PCs.
i am using it and it working good.
on Apr 20, 2010 | Computers & Internet
I have the Zyxel ngg-416n wireless router. when i connect it to my cable system and the the router to my mac, the computer doesn't 'see' the network connection. so i can't load the...
Not really familiar with MAC but make sure you're plugging the ethernet cable into a lan port on the router and not the WAN/uplink port.
Also check to see if your lan connection isn't disabled on the computer.
For starters
Aug 27, 2011 | Zyxel Communications NBG416N 11N 150N Wlan...
Ce este zyxel es-105a si la ce se foloseste
Este un Ethernet Switch cu 5 porturi si foloseste la conectarea mai multor calculatoare cu a crestere sporita a bandei de download pentru internet.
Jan 06, 2011 | Computers & Internet
Ethernet to router connectivity issue
The correct way to do the connection is by plugging the Desktop to one of the Ethernet ports and any wireless device over the wireless network.
Dec 01, 2009 | Zyxel P660HW-D1 Router
Correct port from main pc
It doesn't really matter. All ports should do, ports 4 and 5 will just be given priority in some cases - but I'm guessing that you're still using default settings so that's not relevant.
Mar 18, 2009 | Zyxel ES-105A (ES105A)
What do I need to use the P310?
You need a ADSL modem or cable modem with an Ethernet port to use the P310. The P310 has two Ethernet ports: LAN port and WAN port. You should connect the computer to the LAN port and connect the external modem to the WAN port. If the ISP uses PPPoE or RoadRunner Authentication you need the user account to enter in the P310.
Feb 19, 2006 | Zyxel Prestige 310 (AM406100) Router
Computers & Internet Logo
129 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
