Question about Briggs & Stratton Briggs Stratton Lawnmower Lawn Mower Short Block
Briggs and Stration Lawn Mowner Engine 3.5 hp. will not start. Pulled Spark Plug and shows no gasoline. Is it carborator, plugged gas line or ?
  • 79 Answers
SOURCE: 190cc 3in1 briggs and stratton mower wont start...
Take the carburator apart and clean it. Also, clean needle and seat. Please let me know if this helps.
Posted on Apr 25, 2009
  • 59 Answers
SOURCE: My lawn mower briggs & stratton engine 650 series will not start
check the fly wheel and coil it may have rust on it if so sand it off
Posted on Jun 26, 2009
  • 93 Answers
SOURCE: BRIGGS/STRATION 675 SERIES, 190CC SELF PROPELLED
Rust on the Flywheel and Magneto wire brush off., Pluged Fuel Filter or Bad Gas.
Posted on Sep 14, 2009
  • 143 Answers
SOURCE: Briggs & Stratton Modle# 100000 will not stay started.
your engine is only running on the fuel you are pumping in, the carb. is not lifting the fuel on its own, maybe because of water in the bowl or dirty jets. You must take the bowl of and clean it out and depending on the type of carb. it might need a new diaphragm. Stephen.
Posted on Apr 25, 2010
Testimonial: "very helpful. will follow instructions. Thank you"
  • 3 Answers
SOURCE: Lawn-Boy Insight Series 21-Inch 190cc 650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower: my engine will only stay running for about 3 secon...
Maybe the engine is running with the fuel from the primer bulb (about few seconds), the carburator is not working and need to be removed checked and cleaned, the most common fail is a jet clogged.
Posted on Dec 16, 2010
LAWNMOWER STRING WONT PULL
Unplug the spark plug.
Try to turn the blade by hand, be sure to use a heavy glove to protect your hand from the sharp edge.
If the blade turns, then move it back and forth to free it up.
If it won't turn, take the spark plug out and try to turn the blade .
If it won't turn, you may need the engine overhauled.
If it will turn, put a level teaspoon of light oil in the spark plug hole, and turn the blade a few times.
Now try the pull rope.
If it works, put a level teaspoon of fresh gasoline in the spark plug hole and install the spark plug.
It should start
Be blessed.
Feb 17, 2013 | Briggs & Stratton LawnBoy 20Inch 65 HP Gas...
17.5 hp briggs and stratton mower - mowing fine - stopped to gas up - will not start back up - back fires a few times while turning motor over
sounds like you may have a broken valve spring. Do a compression test as you crank it. If the valve spring is broken, you will get nearly zero compression, it will turn over very easily and this would explain a couple of backfires.
Sep 04, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Not getting any spark
Clean the Plug and replace the Seafoam gas with fresh. Althiough the Seafoam is a cleaning agent, it cuts back on the gasolines octane and it can slightly foul plugs.
Aug 07, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
Briggs stratton model 100000 sart problem ?
If you are having problems starting your mower you should check 3 things, air, fuel and spark.
Fuel: check to make sure you are full of good quality fuel, try to start the engine several times then take out the spark plug and it should look wet. If its not wet then you aren't getting fuel into the engine.
Air: remove and clean the air filter with clean gasoline if its made of foam. If its made of paper then you should buy a new one from a local auto parts or hardware store.
Spark: disconnect the spark plug wire from the spark plug and hold the wire close to the engine block. Try to start the engine and watch for a spark to jump between the end of the wire and the engine block. If it doesn't then either the wire is bad or the ignition coil is bad.
Reply to this solution when you find the problem and I can tell you how to solve it.
Jun 08, 2011 | Briggs & Stratton Lawn-Boy Insight Series...
I have a two year old Craftsman 650 series mower with a Briggs and Stratton engine. Rear drive, rear bag, electric start. Before the mowing season started, I replaced the spark plug with the proper plug...
Well you have done everything that there is to do. What did you set the gap between the new coil and the flywheel?
You may want to try the old plug to see if the new plug is bad. Would not be the first time that I have seen a new plug that was bad. Do you have a spark plug checker? It will show any spark as it jumps a gap.
Apr 25, 2011 | Poulan Pro 22inch 625 Series Briggs ...
Lawn mower won't start
to check for firing remove the spark plug insert it in the plug boot and pull the rope while watching to see if the plug sparks be carefull not to touch the plug electrode while pulling the rope or it will shock you. If you don't have a spark, try a different plug. If still no spark the coil could be bad.
Jun 25, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Lawn mower will not start
check gas tank with light is there dirt in tank? did you change fuel filter? is there spark at the spark plug? try a 2 second spurt of starting fluid in carburetor and crank does it fire?if it does then you most likely need to clean carburetor with carburetor cleaning spray, flush fuel lines with spray and swap fuel filter.
Apr 23, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs  Stratton Lawnmower Lawn Mower Short Block Logo
66 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
