Question about Konica Minolta bizhub 200 Printer
Bizhub 164 service call no c3451 please help me out, and please let me know where is thermostat located in bizhub164 in details... thank you
  • 4 more comments
  • neemesh Nov 23, 2011
    bizhub 164 service call no c3451
  • R. BASKAR Jun 10, 2013
    Sir, I have Konica Minolta 164 Xerox Machine, Problem for No print coming, please arrange service
  • mohammed faizel
    mohammed faizel Dec 12, 2013
    c3451 error
  • owais malik
    owais malik Mar 06, 2014
    shutdown the machine then press and hold stop/reset key and then on the machine
  • Luis Magimba
    Luis Magimba Apr 29, 2014
    Solved, thanks
  • Bavel Segar
    Bavel Segar May 08, 2014
    thanks a lot....
    Problem Solver:
  • 18 Answers
The left side bush of upper heat roller has been displaced. Put the bush at the slot and fix it with gum like feviquick. Keep Pressing the stop Key and switch on the machine.
Posted on Mar 20, 2014
Bizhubman
  • 108 Answers
SOURCE: bizhub 250 All-In-One Laser Printer: Error code C3451 wont reset using Utility key at s...
• The Fusing Roller Thermistor does not detect
the required temperature within 30 sec. after a
warmup cycle has begun; therefore, the copier
does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
You may have a bad fuser section. Another reset method is a small button located on the right side of the machine under on the scanner section. Locate your network port, then to the left of the port is a small cover that can be removed, behind that cover on the left is a small black button, use a paper clip or ball point pen and press the button, this will do a machine reset. When the operation panel abort starts to load hit the number 3 button, you should see a small back circle in the top right of the operation panel. This will give you the option to do a trouble reset.
If this does not work you will need a technician to come out and replace the fuser section, make sure they bring one with them so they don't have to reschedule and come back.
Posted on May 19, 2010
DocuSystems
  • 10 Answers
SOURCE: i have code c3451
Power off using left side rocker switch.
Power on while holding utility counter
Press trouble reset.
Cycle power (rocker)
If it comes back immediately you need to replace the fuser.
Posted on Aug 05, 2009
pineworks
  • 4041 Answers
SOURCE: konika minolta bizhub 350 Error c3451
Hi there.
Try this It could do the trick for you.
The error code c3451 refers to a copier warm up error; the machine had not reached the correct temp within a specific time.
I bet it happened when you first switched on one morning.
Easy to reset and fault usually goes away.
To Reset switch machine off using the switch inside the front door, not the one on the control panel.
Whilst holding the UTILITY key down on the control panel switch the machine back on keeping the UTILITY key held down. Eventually a Trouble reset key will be displayed in the LCD screen, touch this, OK will be displayed then power the machine off and then back on.
This will reset the error code, if the code reoccurs then there will be a problem with the fuser unit in the machine, and this will requir
e replacing.
Hope it did work for you.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 28, 2010
  • 60 Answers
SOURCE: Error Code C3451 in konica Minolta Bizhub C200.
You will need to replace the thermostat and the best solution is to call a technician.
Posted on Feb 22, 2011
  • 60 Answers
SOURCE: HOW DO I SOLVE ERROR CODE C3451 IN KONIKA MINOLTA
You will need to replace the thermostat and the best solution is to ask a technician to do that.
My xerox machine model is Konica Minolta Bizhub 164. machine trouble service call (C3451) showing on display. what should i do?
C3451 Description Warming-up failure
- The surface temperature of the fusing roller does not reach a given level even after the lapse of a given period of time during a warm-up cycle. Remedy 1 Check the fusing unit for correct installation. 2 Check the open/close operation of the right door. 3 Check the fusing unit, DCPU and PRCB for proper connection and correct or change as necessary. 4 Change fusing unit. 5 Change PRCB. 6 Change DCPU.
Jan 12, 2015 | Xerox Office Equipment & Supplies
Fusing warm up problem.To reset press Utility Stop00Stop01 ,enter in the service mode select Trouble reset.If do not work you have need to remove and repair the fusing unit.
Jul 13, 2014 | Konica Minolta bizhub 200 Printer
164 service c3451
Press "STOP" button on control panel and then the machine ON, keep the button pressed until you see the default or main menu on screen, then release the button and your machine is ready.
May 28, 2014 | Konica Minolta bizhub 200 Printer
Sir, My Konica Minolta bizhub 164 shows an error code c3451. How can i solve this problem.
Pressing stop button switch on the machine. It happens due to low voltage or damaged fuser bush.
Feb 13, 2014 | Konica Minolta bizhub Office Equipment &...
Konica Minolta bizhub164 C3451
If the code comes back do not reset, you are messing with the Fuser the Hot part. Continuing to reset without a technician looking at and or replacing it, the fuser can catch on fire and that would ruin a perfectly good day.
Turn ON the power switch with the Back/Stop/Reset key held down.
Jan 14, 2014 | Konica Minolta bizhub 200 Printer
How do I clear error message C-2558 for the Konica Minolta bizhub C253
tis error means abnormal tonder density in the balck image unit take the blacke image unit out and shake it while holding it level and put it back in the machine to reset the error code leave the machine on and open then close the front door
Nov 12, 2009 | Konica Minolta bizhub C250 All-In-One...
Error C3451 ! Anyone? Pretty Please.
This is an indication of a reoccurring error or faulty part. You MUST place a service call.
Oct 03, 2007 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta bizhub 200 Printer Logo
3,626 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
