Question about Euro-Pro Kitchen Appliances - Others
My fryer went nuts, it was on and working fine, the beeper went off and I went to check on my food and the unit was off. I unplugged it and plugged it in 4-5 times and nothing, tried it again in the morning and till will not power on. There are no burnt marks anywhere near the plug or where it attaches to the back of the unit and I pulled the heating element and no problems there either. Please advise.
    President:
  • 3,433 Answers
Hello;
Thermal safety switches are-common in heating type appliances. If this unit is so protected, a reset should be somewhere on the unit. Another component is a fusible link. This is basically a enclosed fuse that that will blow if a short or excessive current draw is present for an unusual length of time. The reset will kick everything back to normal instantly. The fusible link is generally inside the unit on the power in wire. This link should be replaced with its like. It will require soldering on replacement. This fryer is probably an expensive unit , so the cost of replacement opposed to repair should be weighed. Good Luck to you. Thanks for seeking your answers through Fix-ya. _Ned_
Posted on Apr 04, 2011
Unit is not turning on or calling for heat, why?
sounds like the elements have opened check with an OHM meter
Mar 23, 2017 | Cecilware EL2X15 Deep Fryer
The beeper on my HP Officejet 6210 All-in-one unit is on all the time on or off with power button. The only time the beeper stops is when it is unplugged from the wall outlet. I got an auto reply to try to...
I want you to try NVM (Non Volatile Memory) reset for this printer. Perform the printer is connected directly to wall outlet with now Surge protectors.
Steps:
  1. Remove the ink cartridges.
  2. Disconnect the power cable from back of the printer while its ON.
  3. Press and Hold OK and CANCEL button, while holding the button insert the power cable and continue holding it for 20 seconds
  4. Printer will turn OFF.
  5. Turn ON the printer and insert cartridge when it prompts.
Regards,
Rizwan.
Jan 20, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Feezer COLD food compartment not cooling. It
the heat element or the thermostat IN YOUR FREEZER PART need to be check...they might went bad and when you defrost the unit it is working fine but only for period of time....:(
Dec 30, 2009 | Amana Easy Reach Plus ABL2037FESL...
2.0 cabrio low oil warning beeper goes off periodacally
sounds like there is a short in the wiring to the oil pressure sender unit.
Jul 28, 2009 | 1996 Volkswagen Jetta
Intermittent reminder beeper won't shut off
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes. Then let us know if the hard reset does not fix it.
May 24, 2009 | GE Advantium 120 Convection/Microwave Oven
Euro-Pro fryer doesn't return to temp after cold food drop.
If your timer is connected to the t'stat, you may have an expensive project on your hands. However, in the meantime, I would just get an egg timer or a digital countdown timer and use it since it seems to operate fine without the timer.
Feb 06, 2009 | Euro-Pro F1066 Deep Fryer
Pilot won't light
you have one of two things going on here either a thermocouple or a pilot safty valve failing. If you hold in the g/v button and the pilot will stay on but then go off when you let the button go you have a bad thermocouple. The 2nd is another option possibly installed on your fryer which is a pilot safty device it will have a large red button usually accessible from the outside or behind the front cover. Also you need to make sure you have gas present to the unit as well.
May 30, 2008 | Pitco Frialator SG14 Deep Fryer
Deep Fryer doesn't get up to a proper temp.
9 TIMES OUT OF 10 THE TEMPATURE DIAL ON ANY DEEP FAT FRYER IS NOT FULLY ACCURATE TO MAKE SURE YOUR FOOD IS PROPERABLY COOKED YOU WOULD HAVE TO LEAVE IT THAT BIT LONGER
Jan 09, 2008 | Rival CF275 Deep Fryer
Cuts off
Like most of the problems listed on FixYa about this Deep Fryer ours worked fine the last time we used it, but we could not get the power light to come on again. I found that there is s SAFETY Micro-switch on the heating element control unit. This switch prevents the heating element from being turned on when it is not in the Fryer Pan. The accuator lever for the switch is located under the guide slides on the heating element control unit. It is a metal lever which is moved as you mount the heating element control unit on the fryer pan. You have to look closely under one of the guide ledges on the heating control unit to see it . The problem is that over time the adjustment of the lever changes as it flexes under use. I simply readjusted the lever by forming it with a pair of long-nosed pliers. CAUTION !!!!!!! You can bend the lever so far that the switch is closed all the time defeating the Safety Switch and create a hazard in that the unit will heat as soon as you plug it in whether inserted in the Fryer Pan or lying out on any surface. This might burn someone or cause a fire. Good Luck
X-IBM
Dec 16, 2007 | GE 168997 Deep Fryer
My deep fryer just stop working?
If you own a Presto ProFry, call customer service at 800-877-0441. They can help you with this problem, and give you advice.
Sep 29, 2007 | Presto 05464 ProFry Deep Fryer
Kitchen Appliances - Others Logo
143 people viewed this question
Top Euro-Pro Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Gerry Harvey
Gerry Harvey
Clarice Bornschein
Level 1 Expert
Are you an Euro-Pro Kitchen Appliances - Other Expert? Answer questions, earn points and help others
