We installed a Daikin heat pump in June 1996 Model FVY453CBV1 in Dunedin NZ. It stopped and a repairer said the compressor unit is rusted through & recommeneded a new heat pump. I am looking at whether there are alternative solutions and want to check whether it is economical to replace the compressors, or alternatively whether a new external unit can be purchased. Do heat pumps have a life in years? Is it risky to marry a new external unit to the existing internal unit? I appreciate your help Kevin Helm
  • 40 Answers
Don't waste your time and money repairing a 15 year old unit you will just create more
headaches for yourself, And a new outdoor unit would not be compatable with your
old indoor head there have been to many changes over the years.
replace the whole thing you have had your monies worth out nof it.
lay it to rest in peace
Posted on Apr 04, 2011
Green light flashing On Daikin fvy453cbv1
how many blinks, look up daikin error reset or daikin factory reset to clear the codes and get into secret service test mode.
Jan 03, 2015 | Heating & Cooling
Can I run a daikin mini split heat pump 3MXS24JVJU with a generaton
It depends on the SIZE of the generator. If your generator is designed to supply 240-volt A/C and handle the FLA (Full Load Amps) rating of your Indoor and Outdoor units, then, YES, of course you can run it with a generator.
Aug 26, 2014 | Cfm Daikin R410a Split System Air...
What does external protection devices activated mean? ( EO code)
these are saftey swithes that are used say if your out door unit fan quits the compressor will run hot and shut off or if your indoor unit is stoped up the unit will run low pressure wich will shut off by the low pressure switch usually if its dirty or low on freon it will come on and off three times or so and will shut its self off.
Jul 20, 2014 | Daikin FDXS12DVJURXS12DVJU Slim Duct...
Code u 4 - Daikin model Rxymq48mvju
U4 Is a communication error between indoor and outdoor units.
usually means one of the PC boards is faulty. If unit has been freshly installed check wiring between indoor and outdoor 1,2,3 are the same colours on both boards.
May 04, 2013 | Daikin RXYMQ48MVJU, VRV-S Air Cooled Eight...
Daikin FVY125 U4
This is a communication issue between the indoor and outdoor units.
This fault can be caused a issue with the interconnecting wiring such as an induced voltage on the Communication cable or even if a Drain Pump has been installed incorrectly external to the Daikin Unit.
Ensure that the Outdoor unit has power to it and that the Main PCB has a Green Flashing (HAP) LED on it to show that it is powered up.
Jan 15, 2012 | Heating & Cooling
I have been given a 2005 model sewing machine without foot control or power cord. How much and nearest supplier? Allison Dunedin New Zealand
I would suggest you contact Elna NZ, they should be able to advise price and availability or direct you to a local dealer.
Elna Australasia
icon_mail.gif A division of Janome New Zealand Ltd
Unit 5/325 Ti Rakau Drive
East Tamaki
Auckland
New Zealand
icon_mobile.gif +64 9 271 4148
icon_printer.gif +64 9 271 4149
icon_mail_back.gif john.sherman@elnaaustralasia.com
Jul 09, 2011 | Elna 2005 Mechanical Sewing Machine
WHAT IS THE AREA CODE FOR NZ
64 is the country code for New Zealand.
The area codes for the different areas of New Zealand are:
Auckland 9 Invercargill 3 Rotorua 7 Christchurch 3 Napier 6 Tauranga 7 Dunedin 3 Nelson 3 Timaru 3 Hamilton 7 New Plymouth 6 Wellington 4 Howick 9 Palmeston North 6 Westport 3
To dial out of the United States, dial 011 + 64 + *area code* + *phone number*
Mar 30, 2011 | Lands Phones
I have a Daikin Ducted Air con system which shuts itself off when-ever the temp is over 33 degrees celcius. An error code E5 comes up which means that either the Compressor is over heating or there is a...
E5 Outdoor activation of compressor over heatprotection or motor lock.
Dear friend! Replacing spares for defective will not solve problem. But, you must know why it happened?
In your unit,Condenser unit was completely dust blocked. First clean it. And also replace running capacitor. If recently replaced, ignore it. Check motor for bearings. It's mechanism locked due to bearing worn out or weaken capacitor. Ask repairman to check with amps meter for fan and also with compressor. And also loose wiring if any. Compare with unit specified amps.Hope problem would solve now.
Jan 07, 2011 | Cfm Daikin R410a Split System Air...
Heating & Cooling Logo
178 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
