Question about Holmes Products HM6600 3 Gallon Humidifier
The Humidifier HM6600 does not working. It only runs for 5 seconds after I turn it on. It's almost new!! What shall I do???
    Brigadier General:
  • 4,736 Answers
Since the unit is "almost new", contact the customer support phone number in your Owners Manual. This way, it's covered under the warranty.
Posted on Apr 04, 2011
Honeywell humidifier short cycles
It's not uncommon for duct work in an older home to Bang as the furnace cycles due to age. The humidifier banging while turning on and of is mostlikely the solenoid valve; if the solenoid is bad it is actually to your benefit to replace the entire humidifier as the solenoids are very expensive, 50%+ of a new humidifier. Plus you get the 5 year parts warranty on the new unit instead of just one year on the solenoid. If you don't want to replace the entire unit you can replace the Humidistat, and that should fix the on/off cycling, however a new humidistat is included with a new unit, which again is more cost effective. They are easy enough to replace as a do it yourselfer, especially when replacing an existing unit. I hope this helps you.
Dec 29, 2012 | Honeywell HE360A1027 Whole House...
What happens if the humidifier runs out of water? Humidifier is new and working fine. I Does the humidifier shut off automatically when it runs out of water?
The humidifier has a float valve in it much like a toilet tank does. If the water gets to low, the float valve should allow more water to enter the tank automatically. When it reaches the proper level, the float valve stops the water. The water line (either copper or plastic) coming into the humidifier should have a shutoff valve on it. Make sure that it is turned on.
Feb 02, 2011 | Holmes Products HM4600-U 11 Gallon...
I replaced the water panel on our aprilaire 600 humidifier. I adjusted the thermostat to call for heat to test it. When the dial (non-digital control panel for the humidifier) is turned to test/reset,...
Thank you for contacting us with regards to your model 600 Humidifier. The Change Water Panel indicator should flash when the control knob is set to the Test/Reset mode. The flashing indicates that the timer has been successfully reset. However, the humidifier should operate for the first 60 seconds of Test mode as long as your furnace is running. If your humidifier does not turn on, contact your installer. The humidifier may require service.
We appreciate the opportunity to be of assistance.
Sincerely,
Brett Phillips
Technical Support
Research Products Corporation
Nov 01, 2010 | Aprilaire 600 Humidifier
Our aprilaire humidifier is only 4 years old and it does not seem to be working. We have static in the house and when I did test mode it never drained water like it was supposed to. Any ideas what I can do...
Hope this helps, check and see if humidistat is set to 35% humidity and that bypass damper on humidifier is in the open position or winter position.(humidistat is usually located on cold air return duct near furnace). Next, replace humidifier media pad, remember to replace media pad (filter) annually, you also may want to clean any lime deposit out of humidifier housing with a solution of warm water and white vinegar before installing your new media filter.Remember to turn power off at side of furnace when cleaning humidifier and replacing media. Before installing new media turn power back on to furnace, set humidistat to the on position, turn furnace thermostat above room temp., and inspect humidifier to see if water is running from top,(you may want to have a bucket under humidifier when checking for water), if you see water running, turn power back off to furnace, properly install new media filter, reconnect humidifier cover & set humidistat to 35%. If you do not see water present, check water supply valve to humidifier and make sure its turned on. If water supply valve is open, then check water supply tubing for blockage.And the last things to check is to make sure all registers through out your home are open and not blocked by any objects, also make sure furnace filter is cleaned, if none of this works refer to installation manual to see if humidifier was sized and installed properly, Good luck.
Mar 03, 2010 | Aprilaire 600 Humidifier
Trane furnace humidifier not working
If there is water and power to humidifier you need a new solenoid valve or humidistat.
Jan 16, 2010 | Honeywell Power Humidifier: Furnace...
Aprilaire humdiifier not working
Does your humidistat have any dip switches or a small jumper wire? if it does try switching positions of the jumper or change dip switch. hope this helps
Jan 29, 2009 | Aprilaire 700 Humidifier
AprilAire 760 not running after installing new circuit board
I called the service company that put in my new furnace (FAmily Heating and Cooling in Detroit, very highly recommend these people)
Anyway they sent out a second service tech who determined that I would be better off having the humidifier wired to go on whenever the furnace fan was running instead of using the humidifier signal from the circuit board on the furnace. After he changed the wiring the unit runs fine. It is pretty likely that the circuit board was bad also.
Nov 27, 2008 | Aprilaire 700 Humidifier
Honeywell 360a humidifier
yes water should turn off solinoid is bad
Oct 24, 2008 | Honeywell HE360A1027 Whole House...
HM5081TG Reset Light won't turn off
Reset the unit once it is refilled by pushing the power button and holding it down for 5 seconds before releasing. This should reset your unit to factory settings.
Oct 21, 2007 | Holmes Products HM5080-U2 Humidifier
Holmes Products HM6600 3 Gallon Humidifier Logo
117 people viewed this question
Top Holmes Products Humidifiers Experts
cwradio73
Ben Eng
Level 1 Expert
Tom Chichester
Are you a Holmes Products Humidifier Expert? Answer questions, earn points and help others
