Question about Echo 30.1CC Chainsaw With a 14 In.bar and Chain
I have Echo CS-3450 chain saw. the throttle cable has become diconnected from the throttle at the carburator. How do I reconnect it? Is there a picture out there showing what it is supposed to look like when connected? thanks
3 Suggested Answers
  • 520 Answers
SOURCE: I have an Echo CS-3450
the trigger is connected to the carb with a linkage rod. it has probably come off. usually you will need to disassemble the saw to get to it. not a easy job. some times best to take it to a shop
Posted on Feb 12, 2011
  • 2239 Answers
SOURCE: I have an Echo CS-3450 16" Chain saw that starts
This is classic fuel starvation, it needs to run a little rich when free running, when it goes under load it needs the extra fuel to keep it going, if you have replaced the fuel filter, and the fuel hoses are good ( no leaks, or cracks in the pipe, give the pipe a tug to see if fuel squirts out ) then there is dirt in the main fuel screen under the pump diaphram, remove the carb, remove the alloy pump cover, normally held with a single screw, under here will be a gasket, and a pump diaphram, in that order, pressed into the carb is a very fine screen, this should be replaced, or at least cleaned, check the condition of the diaphram, this should be supple not hardened, rebuild and try again, the H screw on the side of the carb controls fuel to the main jet, if need be increase ( screw out ) 1/4 turn.Somewhere from the tank will be a breather, this allows air into the tank to stop a vacume occuring, to check this slacken the filer cap when the machine starts to die, if it picks up again it is a breather issue.
Posted on Jul 18, 2011
How to replace clutch spring on a echo 650 chain saw?
id replace the entire clutch as if spring came out then therese got to be a reason
Mar 01, 2015 | Echo Cs-650evl Cs 650evl Chain Saw...
How do I replace the primer bulb on an Echo cs-346 chaln saw?
The part number is 12318139130 and this youtube video covers this part's replacement.
http://www.youtube.com/watch?v=cnzag2RqhRo
Jul 12, 2014 | Echo Garden
Brand new Echo cs-400 chain saw: The chain spins fast on idle. Should'nt the chain be stationary on idle?
The manual is available here:
http://safemanuals.com/user-guide-instructions-owner-manual/ECHO/CS-400-_E
The idle speed of the negine may be too high.
Page 26 of the manual gives instructions for adjusting the speed with the "T" screw on the carburettor.
May 12, 2011 | Echo CS400 18" Chain Saw
I have an Echo CS-3450 model... The throttle trigger has become disengaged somehow. When I depress it, no reaction from the engine or bar. Any ideas how to fix it?
Feb 12, 2011 | Echo Garden
Echo cs-3400 wont start . no spark. what are the primary and secondary coil readings?
if you have no spark
check for faulty plug 1st, then pull kill wire off at kill switch, then check for grounding ht lead ,
then pull kill wire off at armature , if still no spark most likley faulty ignition armature
i suspect the part number you need if its type 1 is 15662639130
replace it and set air gap and reassemble and test
here is web site for parts
http://www.ereplacementparts.com/echo-cs3400-type-chainsaw-parts-c-35043_35970_36021.html
or you could try www.partstree.com , go to echo saws , then find your model
cheers hope it helps
pauly 46
Jan 28, 2011 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Chainbrake spring broke need new one
Parts Catalogs Parts Catalog, Chain Saw Model(s): CS-310 Serial: C04511001001 - C04511999999 Language: English Parts Catalog, Chain Saw Model(s): CS-310 Serial: C04612001001 - C04612999999 Language: English Parts Catalog, Chain Saw Model(s): CS-310 Serial: C04713001001 - C04713999999 Language: English
Jan 05, 2011 | Echo CS310 14" Bar Length Fully Assembled...
My cs-3450 saw has no spark. the ign wire shows to be grounded. bought a new coil, still no fire. the ign wire on this coil also shows to be grounded. what is the problem?
disconnect the on /off switch that is how it gets grounded so that it will shut off may be a bad switch disconnecting it will allow it to start.
Nov 14, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Echo cs-310....how to put chain on after it became lose....also how to tighen when it becomes loose.
At the right side take out the panel that hide the bolt that has a large groove.When unbolt move froward the chain holder and tight the bolt but not too tight just go further until you can test it by hand making the chain to move freely but stable.Reverse the procedure.
Post / thumbs / testimonial are welcome!
Nov 12, 2010 | Echo CS310 14" Bar Length Fully Assembled...
Yes I have a echo CS-3450 type 1-E and have to work the throttle just to keep it running.changed the fuel filter,sparkplug,gas ratio 40:1
Check the fuel lines for decay or other damage. Make sure the muffler is not plugged. If the jet screws have slot heads, turn the H jet screw CCW somewhat until the engine 4-strokes at speed, but immediately 2-strokes when cutting. If the engine lags behind the throttle when accelerating, turn the L jet screw CCW about 1/8 to 1/4 turn. Hope this helps!
Oct 30, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
What are the adjustments for the high and low mixture screws on the carbureator? the carbureator is from an echo 500vl chainsaw.
Echo thinks your actual model number is CS-550EVL. Page 14 lists the starting points for carburetor adjustment here:
http://www.echo-usa.com/pdf/documentation/CS550evle_010186.pdf
Additional manuals for you saw can be found here:
EchoUSA
http://www.echo-usa.com/documentation.asp
More choices can be found by typing CS in the model: window then clicking “Search”.
Once initialized this is the best procedure I have found.
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too. HTH
Lou
Feb 13, 2010 | Garden
Echo 30.1CC Chainsaw With a 14 In.bar and Chain Logo
217 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
colesmowers
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
