Question about Zanussi ZWF1630 Front Load Washer
Hi there I have a Zanussi ZWF 1631 F washing machine that has just stopped mid cycles. It is still full of water and has clothing inside. I have tried using the skip button and go straight to drain but nothing happens(time display goes down for a couple of mins and then saye "E20". Have turned off machine and tried the reset process of holding in start and skip together. This results in all display leds to flash from top to bottom,left to right. Then turn off machine again and "ELE" is displayed on screen. This results in it slowly turning once to the left and then to the right repeatedly. Have tried turning machine off and choosing different cycle but nothing happens. I'm sure "E20" is something to do with pump but have recently took out pump and cleaned it out! Would the machine just stop mid cycle if pump has problem? Many thanks for any help given in advance. Paul
4 Suggested Answers
SOURCE: zwf 1631 w
Have you took the front cover off and looked for the strainer which is located before the water pump. I have seen many of them plugged tightly, causing the water not to drain. Look inside the owners manual that came with the machine. It also should give you some things to check that would cause the code E20 to keep flashing. Hope this helps.
Posted on May 09, 2008
  • 17 Answers
SOURCE: zanussi electrolux washing machine zwf1431w
Error E20 means the machine has failed to pump out. 1st check the filter at the bottom right hand side there may still be water inside if so pull the grey tab to the left of the filter there should be a thin hose extend it put it into a shallow dish and pull the cap off to let the water drain this may be a slow process. When the filters out look into the hole with a torch to see if any obstructions in the pump impeller this looks like a cross. If the filters and pump are clear it may be the pump has failed.
Posted on Dec 17, 2008
blueextc3221
  • 15935 Answers
SOURCE: error cde E20 on zanussi
E20 is an error code for drainage failure.
Check where the appliance drain hose connects to the house drains for a blockage.
If it's onto a spigot under the sink, take them off and check both for a blockage.
If these are ok then it's likely to be a blockage in the pump.
You'll need to drain the water out manually.
Put a shallow dish below the filter and slacken the filter.
Tighten it to stop the flow of water while you empty the dish.
Once empty, take the filter out, clean out the debris and ensure nothing is left jamming the pump.
Before refitting the filter, put the machine on drain or spin and listen at the filter housing to see if you can hear the pump running.
If you do, fit the filter and try the machine again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
Why did my washer stop mid cycle and now won't work at all?
Hope your warranty is still in effect. It sounds like your control board has an electronic problem that will require replacement; typically around $135 for the part and $110 for the service visit.
Aug 21, 2014 | Zanussi Washing Machines
My zanussi ZWF 1631 -W is showin fault E50 ..any idea ??
Hopefully answered on your other posting ;-0) John C
Sep 10, 2011 | Zanussi ZWF1630 Front Load Washer
Zanussi electrolux washing machine zwf1431w
Dec 17, 2008 | Zanussi ZWF1430W Front Load Washer
Zwf 1631 w
May 09, 2008 | Zanussi ZWF1430W Front Load Washer
Zanusi zwf 1631 w wont work
all of the e50 codes indicate motor check your brushes. if you still have problems email me
Feb 10, 2008 | Zanussi ZWF1630 Front Load Washer
Washing machine stops mid-cycle and full of water
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 06, 2008 | Washing Machines
Zanussi turbo dry 1200
Try cleaning out the pump, and main hose to sump. If problem persists replace pump.
Slim Jim
Nov 12, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi wdj 1094 washer dryer
possibly the motor brushes are worn, the clicking is the pcb relay changing the motor direction.
May 19, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi Electrolux ZWF 1430 W (E20 error)
Check water "forreign object trap". It's under the lid at the bottom of the machine. First drain water by pulling out the hose and pull out the plug. Then unscrew the trap. Have had this E20 error twice. First it was two coins there, next it was a big paperclip. Have worked fine ever since.11_20_2011_8_57_27_am.jpg
Sep 26, 2006 | Zanussi ZWF1430W Front Load Washer
Zanussi ZWF1630 Front Load Washer Logo
127 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
