Question about Pedals Look Quartz Carbon Mtb Clipless Mountain Bike
I hear a clicking sound on my left pedals evrytime i put load on it.
    Brigadier General:
  • 8,546 Answers
I have a 2006 pacifica. I have no brake lights (left right). When I press the brake pedal, I hear a click sound coming from under the shifter area. Weird?
No not weird that clicking sound is your shift lock it's supposed to make that sound first check
Brake light fuse if that is good check brake light switch witch is mounted under the dash above the brake pedal somtimes they can unadjust them selves and the switch doesn't hit the pedal or it is just bad and if that's not the problem it's the module that you will have to take to a repair shop
Dec 13, 2014 | 2006 Chrysler Pacifica
Shifter
Sounds like the brake pedal switch is bad. When you step on the brake pedal with the key on you should hear a click
May 26, 2014 | 2005 Chevrolet TrailBlazer
Troubleshooting guide
The clicking is the safety switch connected to the Brake pedal that allows u to move the shifter to another gear, like Drive or reverse. This is normal ...My HHR had the same clicking sound when pressing the brake pedal before putting the Vehicle in gear.
May 03, 2014 | 2008 Chevrolet Silverado 1500 2WD
Clicking noise brake pedal
It possibly is the brake light switch, this is mounted on the top of the brake pedal, check the brake lights are working? The switch is not normally loud enough to hear? Check the area around the brake pedal, make sure things like heater air pipes are secure and away from the pedal. If the brakes are ok and the brake lights are working, it has to be something fouling the pedal.
Jan 21, 2014 | 2010 Honda Odyssey
I used type my passward evrytime i open the computer.now i can open without.so I want put my passward evrytime i open computer
You can remove or change the Window's User or administrator's password. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
Jan 13, 2013 | Lenovo ThinkPad Computers & Internet
I have a very annoying clicking noise from my Shimano Ultegra PDR6oo pedals.This noise only happens when climbing.I have just changed the cleats,but the noise persists.They are about six years old and have...
Hi, the clicking noise that you hear is the sound of bearings/races reaching the end of their service life. You will need to take the pedals off and then remove the pedal from the shaft itself. Inspect the bearings and the races for excessive wear. The new bearings can be put in place using some thick grease on the race you can then stick each bearing into the grease and the will stay put until you are ready to do the opposite side of the pedal.
Nov 17, 2010 | Cycling
No breaklights and stuck in park
replace the stop lamp switch. It's right behind the brake pedal and it should take care of your problem. Double check it by listening for a clicking sound at the shifter when you step on the brake to release it from park. If you don't hear the clicking sound then its the stop lamp switch. If you do hear the clicking sound then you have two problems. The stop lamp switch and the shifter assembly. There is also a manual override for the shifter located right behind the shifter. Its the little spring loaded flap. Stick a pencil in there to release the shifter.
Oct 22, 2010 | 2002 Mercedes-Benz M-Class
My 04 navigator left power seat wont move any direction and pedal adjust wont move...there is a clicking sound coming from a black box under seat but no function
it does not appear that the driver seat or adjustable pedal share anything in common
furthermore, the sound you hear clicking may be the actual seat motor trying to work, but lets do a quick test
try to move the seat up/down, forward/back and any combination. If while holding the button in said position and you consistently hear the clicking sound that follow the sound and touch the motor under your seat. If you feel the "clicking" then your seat motor is bound or siezed and will need repair.
if instead you just hear one click then you might be experiencing a relay problem
As for the pedal adjustment... have you checked fuse #109 (30A) @ the CJB (Central Junction Box) behind the right kick panel?
Apr 10, 2010 | 2005 Lincoln Navigator
When I put my 95 windstar into drive or reverse I get a wheel hop and thump sound. Drives fine other than that. do you think its ball joint, motor or trans mount?
well without hearing it, i would think its a cv-shaft that has too much play banging around there...at the same time, it also sounds like it could something internal in the trans spinning too far before engaging....mounts usually makes noise under load..just after you put it in gear, and step on the accelerator pedal, you will then hear a clunk..not as soon as you put it in gear, unless extremely bad.
Nov 19, 2009 | 1996 Ford Windstar
Blank screen with flashing curser in top left hand corner,
I need a little bit more info.
Do you have a floppy disk in the floppy drive? Remove it. Do you have a CD in the CD drive? Remove it and restart your notebook.
Put your ear on the left side of the track pad. Do you hear any clicking sounds? Do the same for the right side. Do you hear any clicking sounds? If you hear any clicking sounds, and it seems to be constant, you may have a failed hard disk drive.
Try these thing and let me know what happens. Binary Bob
Nov 16, 2008 | Dell Inspiron 6000 Notebook
Pedals Look Quartz Carbon Mtb Clipless  Mountain Bike Logo
146 people viewed this question
Top Pedals Cycling Experts
ray gallant
Donald Ayers-Marsh
Are you a Pedals Cycling Expert? Answer questions, earn points and help others
