Question about Philips CDR775 2-Disc CD Recorder
RECORDING FROM EXTERNAL SOURCE MANUALLY ON CD775 RECORDER. NO INDICATION OF AUDIO INPUT, CONSQEUNTLY AFTER ABOUT 20 SECONDS OF TYING TO RECORD THE MESSAGE UPDATE IN PROGRESS. THIS IS NORMAL PROCEDURE FOR THE CDR775. MY QUESTION----WHY NO AUDIO INTO THE RECORDER???? RECORDING CD TO CD WORKS GREAT.GOOD AUDIO SIGNAL IN. WHEN RECORDING ANALOG , EXTERNAL SOURCE MANUALLY (AS STATED AT THE BEGINNING) NO AUDIO SIGNAL REACHING THE RECODER. I KNOW THE AUDIO SIGNL IS GOOD UP TO THE INPUT PLUGS ON RECORDER.. tHIS JUST STARTED ON THIS RECORDING SESSION!!!!!! WORKED FINE ON PREVIOUS SESSIONS. WHERE DO I GO FROM HERE????? CAN YOU GIVE SOME POINTERS FOR TROUBLESHOOTING OR TRACING THE SIGNAL INTERNALLY!?!?!?. THE SIGNAL IS GOOD UP TO THE FIRST PRINTEDE CIRCUIT BOARD, I DON'T KNOW HOW TO TRACE FURTHER UP THE LINE !!!!!! HELP, HELP rbarelbe@gmail.com 904 796 3835 (cell)
    Brigadier General:
  • 8,546 Answers
Reset the CAPS lock on your keyboard.
You don't indicate if you have actually selected the external souce and if it'sanalog or digital.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Philips-CDR775BK-CD-Players-manual/id/364ci376/t/2/
Page 19-21
Posted on Apr 04, 2011
Vcr stopped recording audio
I often have the problem of no audio recorded when I'm recording from an external source (a cable box, for example), either because I accidentally muted the cable box (or other external source) during the recording, or because of a bad cable connection - the input ports on my VCR are loose and sometimes need to be jiggled around to get a good connection.
Nov 04, 2011 | Sony Televison & Video
Connectding audio/video cables when you have a cable box and sound bar with dvd player
How To Connect a DVD Recorder to a Television:
1.If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
2.To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
3.To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
5. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
6. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
7. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
8. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
9. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
10. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Oct 17, 2011 | Televison & Video
Phillips cdr775/00 how do i record from laptop headphone socket into recorder i n=have tried my usual lead jack to two phonos it says start source when i do no signal comes into recorder analogue in
MANUAL RECORDING FROM COMPUTER HEADPHONE SOCKET.. FIRST RIGHT LEAD REQUIRED YOU NEED STEREO 3.5mm stero jack plug to lef right phono male leads... prepare for manual record place jack in computer headphone socket. check correct socket play track on computer their should be no sound. if sound present in wrong socket... if ok place phono left right into analogue aux inputs on cdr recorder.next make shure you have blank scratch free cd .next press ext(ernal) source repeatedly until the required input is selected i.e digital analogue optical etc..when auto track is on the disk will number automatically.with auto track on it their needs to be 2.7 second gap to rec number change. with the recorder stopped press rec type five times to enter in the manual record standby mode. manual start s to flash and the display shows REC EXT MAN followed by WAIT.after a few seconds press record . play the source track ie on your computer to set record level on cd recorder.. adjust audio card settings or volume control on pc etc .rotate easy jog/enter key until on the record /play level bar all the blue led are alight but not the red( clipping) display shows xx decibel eg 3bd. stop the source material (track on computer get ready to record ii.e to start track again..to start recording set you track going wilst pressing RECORD on the cd recorder, and immediatley the source material playing. the track number and recording time left appear in display . if check input message is displayed check the connections are correct etc .to stop recording press stop on cd recorder . update lights up and arrow goes out. after recording display will show UPDATE FOR SEVERAL SECONDS WRITTING TOC.. IF YOU WANT TO PLAY THIS DISC ON NORMAL CD PLAYERS YOU NEED TO FINALIZE THE TRACK . HOPE THIS HELPS..yammandan.
Aug 19, 2010 | Philips CDR775 2-Disc CD Recorder
Ive been able to record and now i cant record bcuz the screen says "no inputs..." but i can hear music thru the inputs and the lexicon alpha is selected as the input and output sourc. whats wrong????
It sounds like you have NOT connected via the recording software.
It is like the normal Windows software audio has hijacked the audio system even though it is external.
Go into your recording software and look for an option to select the Lexicon device. You did not tell us what recording software you are using.
This is not an uncommon problem with these external audio recording devices.
Apr 14, 2010 | Lexicon Alpha Personal Recording Studio
Converting Audio Cassettes to CDs
First off I assume you have the manual for you're 5700. if not a PDF copy is here
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000027911.pdf
Assuming you have a standalone tape deck that has phono inputs and outputs connection and recording recording should be easily achieved.
Forget the coaxial unless of course your tape deck has digital outputs.
Assuming it hasn't just connect the two output sockets from the tape dec which may be labelled REC out left and REC out right to the Line in (L) and Line (R) of the CD recorder.
The physical setup is now complete.
The increment level they refer to in the manual offers you a choice of 3 final decibel output levels in other words how loud it will be when it is finally recorded onto the disc.
the last paragraph on page 16 is relevant to the setup described above.
Page 15 of your manual is all you need to achieve tape transfer to CD.
follow the steps below and choose ANALOG the source to be played is your tape deck so once the process has begun press the play button on your tape deck and you should get a decent recording. Leave everything else at their default settings until you get a better understanding of how to tweak your recordings.
Personally I transfer audio tapes directly to my PC and Audio edit them until they are perfect but I've been doing this for years.
Good luck
here's a snippet
To record from an external source:
1. Turn power ON.
2. Place a recordable audio disc (CD-R or CD-RW) label side up
in TRAY II.
3. Close TRAY II. (When a blank disc is placed in TRAY II, the display
will show BLANK.)
4. Press INPUT until the source you want to record is selected.
DIGITAL OPTICAL:
record a source connected to the DIGITAL IN (OPTICAL) terminal.
DIGITAL COAXIAL:
record a source connected to the DIGITAL IN (COAXIAL) terminal.
ANALOG:
record a source connected to the analog LINE IN jacks.
5. Select the desired mode of track division (track number
assignment) by pressing the MANUAL/AUTO button (see the
ADVANCED RECORDING section for more information).
6. Press the RECORD button.
The unit enters record pause mode.
The PAUSE [ ] icon and REC blink on the display.
7. Press the PLAY (ENTER) [ ] button of TRAY II to start recording.
8. Play the source to be recorded.
• During digital recording, if the input signal stops for 5 seconds,
recording will stop.
• During analog recording, if the input signal stops for 20 seconds,
• If the unit detects copy-prohibit signals during recording,
CAN’T COPY appears on the display and recording is stopped.
To stop recording: Press the STOP [] button
To temporarily pause recording: Press the PAUSE [ ] button.
Remember that every time recording is paused or stopped,
a new track number will be assigned.
Jan 11, 2009 | TDK DA-5700 CD Player
User Manual
Why did you disconnect the chat session?
Anyways here are the detailed instructions for connecting a DVD recorder to a TV
  1. The first step to connecting a DVD Recorder to your TV is to determine what type of connection you want to make between the TV source (Cable, Satellite, Antenna), the DVD Recorder and the TV. This is usually determined by the outputs and inputs available on the DVD Recorder and the TV.
  2. If you have an older TV that only accepts RF (Coaxial) input, then you would connect the RF output (a coaxial cable) from your TV source (in my case a Cable Box) to the RF input on the DVD Recorder. Then connect the RF output from the DVD Recorder to the RF input on the TV. This is the most basic (and lowest quality) option for connecting a DVD Recorder to any TV.
  3. If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
  4. To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
  5. To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
  6. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
  7. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
  8. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
  9. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
  10. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
  11. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Sep 27, 2008 | Televison & Video
No Audio 10 Error
What have you got hooked up? Another CD, tape outs from an amp or a record deck? No audio is a strange message to get, like you say you're using an audio cdr and that's usually what it means. What about if you press record with *no* source connected? Unit should record 20 seconds of silence then cut off.
Jan 20, 2008 | Philips CDR765 2-Disc CD Recorder
Does not record
Have you selected the correct input? These recorders are desinged to stop after 20 seconds of silence. Do you get any level showing on the record level meters? Press the source button until it shows 'analogue' if recording to the 2 phono inputs.
Dec 29, 2007 | Philips CDR770 CD Recorder
I can't play any VCR tapes or DVD's in my Magnavox. Shows E1
It may be a timer setting after a power problem. On page 90 of the manual there are setups for the timers My VCR won't do things without the time set either. The manual may be downloaded here.
http://www.funai-corp.com/6pdf/om/MWR20V6.pdf
Basically get into the setups and set the time and hit enter. I hope this works.
Sep 12, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Record mode
Hi everyone! In reply to my own question.The answer was operator error,not knowing the operation of the unit.It was due to the incorrect timing of the input source to be recorded.Everything ok now.
Mar 05, 2007 | Philips CDR778 2-Disc CD Recorder
Philips CDR775 2-Disc CD Recorder Logo
127 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
