Question about Maytag Neptune FAV6800AW Top Load Washer
I have a Maytag Neptune TL ( Model # FAV6800AWW) washing machine does spend but clothes still soak after it done. when you spend it by hand, it only spend in counterclockwise.
  • 335 Answers
Any error codes. What happens if you start a Spin Only Cycle witht the same load? Does the times stay stuck at xx minutes in the LED display and the machine constantely starts and stops?
The more info on your problem the better.
Do you want to DIY the fix? Google this; Neptune TL Washer FAV6800AWW see the 5th post down here for general info and the Service Manual. If you want to try to DIY the repair I will help.
Posted on Apr 04, 2011
  • dh1200s
    dh1200s Apr 04, 2011
    ""I have a Maytag Neptune TL ( Model # FAV6800AWW) washing machine does spend but clothes still soak after it done. when you spend it by hand, it only spend in counterclockwise. ""
    If you open the washer lid and rotate the wash basket CCW it should only rotate CCW That's a good sign. It should not rotate CW.
    Look behind the rear right console you will firn the model number and Serial Number. What are the first digits of your Serial Number? The number range will be 10 or 11 on up to 18. That will help me understand what possible Clutch Pulley is in the machine.
Neptune TL Washer FAV6800AWW need owners manual
Google This ""Neptune TL Washer FAV6800AWW""
5th post down is a link for the FAV6800A/FAV9800A SM.
Aug 18, 2011 | Maytag Neptune FAV6800AW Top Load Washer
OD signal goes on w/ neptune washer w/ lid closed. Technician said it needed control latch assembly ($105) and control board($221). Plus labor ($155). Are these easy to get and replace? Is all this...
OD error code is associated with the Left Hand Lid Lock.
If you want to troubleshoot and repair yourself Google this""
That is a repair sticky where I have DIY support for FAV6800A or FAV9800A Maytag TL's.
You do not need a lot of mechanical experience just some guidance if you wan to save your 1$K machine.
Aug 04, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My maytag neptune fav6800vaw washer will not complete the wash cycle. i press pause but the lid does not unlock so the machine is still filled with clothes & water.
I would go into Service Mode and try to unlock the lid latches. Google this
Go to the 5th post down there is a link to the Service Manual. The Service Manual will show you how to get into Service Manual and unlock the lid Locks. If you can't unlock in Service Mode the Service Manual will show you how to release the washer top from thew base to remove your clothes.
If you need additional help post in that forum for help ; Maytag/Magic Chef/Admiral/Jenn-Air
Fav6800aww machine wont stay balanced move the clothes around it starts back up for about one minute then stops code comes up dc thanks earl
This is a DIY Appliance repair forum and you can get the Service Manual and repair support at that site..
In the Sticky: Neptune TL Washer FAV6800AWW 5 post down you will find a link to the Service Manual. You absolutely need the Service Manual to DIY issues with the machine. It's not the best SM but will get you started. I also have repair post in that sticky to help with the most common issues that I have helped owners with. I'm an owner of a FAV6800AWW top load machine.
In that Sticky I discuss what is the cause of DC or UC unbalance errors and the fix.
Apr 14, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I start load of wash, with setting of Max Extract being ON. Clothes come out very wet
I would put the machine in Service Mode with that Wet Wash Load in the wash basket and do a Quick Spin Test on page 14 of the Service Manual and record the fastest RPM that the wash basket will pin up too.
If you don't have the Service Manual Google this Neptune TL Washer FAV6800AWW
If you want help post your issue in that Maytag DIY froum and I will help you......or stay here and see how it's goes.
Mar 21, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Code reads "OP" what does this mean?
Go here Neptune TL Washer FAV6800AWW
read the 7th post down ""issues related to the Left Hand Lid Lock for FAV6800A or FAV9800A machines.""
Mar 18, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune tl error op
You have lost signaling thru the Left Hand Lid lock or you could have a Lid Magnet out of posistion;
Google Neptune TL Washer FAV6800AWW
6 or so post down and I have service notes to help you troubleshoot.
Mar 13, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My MAytag will not spin the water outta my clothes on spin cycle
If you machine is a FAV6800A or FAV9800A don't worry about the last two letters of the model number.
If you need help post in the Maytag/Magic Chef/Admiral/Jenn-Air forum with your issue and we will try to help.
Feb 28, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag toploader Neptune washer stops with 10 minutes left on quick wash and code "uc" on LED. There is a little water left in bottom of tub and cloths are soaked. It does fine until the spin...
It sounds like the Outer Bearings are going due to a leaky Tub Seal. Bothe can be repaired and have done on this site. This site has no way to reference past post to machine issues.
I have helped owners of theFAV6800A and FAV9800A machines here but I prefer a tru DIY site.
I no longer post on this site no way to post a Sticky for machine issues.
If you want to DIY the repair Google this phrase ""Sticky: Neptune TL Washer FAV6800AWW""" Read the post Part 1; DC or UC unbalance error codes in Spin Cycle what is causing this issue? Part 2 for the fix action.
Post your issue in the repair forum not in the Sticky. Please include your Model Number i.e. FAV6800A or FAV9800A and I will help you.
Jan 22, 2011 | Maytag Neptune FAV6800AW Top Load Washer
How to get front panel off neptune fav6800aww washing machine
Just a quick search in this forum fot "Front Panel" returned this post which says it better then I could.
http://www.fixya.com/support/t538238-remove_front_panel
Jan 18, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
200 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
