Question about Toshiba 35A44 35" TV
My on off switch is broke! anything i can do?
    Sergeant:
    Champion:
  • 293 Answers
Switch on the power.then use use your remote. or replace power switch. unplug first before replacing switch.
Posted on Apr 04, 2011
Bike won't start. Battery has enough juice. Lights come on bright. Horns loud but does nothing when start button. I did lay it down made repairs and still has issue. Crash switch? Or anything?
it is possible that the starter wire got broke or came lose from the starter. another possibility is the neutral safety switch got broke or became disconnected
Sep 11, 2015 | Motorcycles
Turning on hp slate 500 without power switch
I hope you found a solution months ago, but just in case:
My switch also broke a while back, and this is a common problem with the slate 500 due to the construction of the switch.
This should help:
http://forum.tabletpcreview.com/hp-slate/41309-my-power-switch-just-broke-2.html
My solution: remove what's left of the plastic switch (if anything) then use a long thin thing (LTT) (about 2 cm long) in the hole where the switch was. I use a squashed paper clip - someone else had a mini screwdriver, someone else the toothpick on their pen knife.
Put the LTT straight at the top of the switch hole and pull down, the same way you used to pull down on the power switch, then let go. The indicator light under the switch hole will blink 3 times quickly if you've successfully tripped the switch.
All the best!
Nov 05, 2012 | HP Slate 500 8.9 Tablet
When the machine is switched on,water starts leaking.
Good luck with your machine! Ours has the same problem, and the motherboard fried out twice, the seal broke once, the door lock broke , oh and the GFI switch samsung sent out to prevent an electrical short and fire hazard stopped working after 1 month of use; and we've replaced that GFI twice ourselves and Samsung won't do anything to help us or exchange this lemon machine
Aug 26, 2010 | Samsung WF316BAC 3.79 cu.ft High...
Can't shut off power.
I have an '86, and the ignition switch is on the steering column, right under the column shroud. That's what the actuator rod connects to, it activates the ignition switch when you turn the key. So if yours is anything like mine, there's just two screws holding the shroud on, so you should be able to remove the shroud and manually manipulate the ignition switch since the actuator rod isn't connected to it anymore. That way you can hopefully start it as well as turn it off.
Oct 21, 2008 | 1988 Ford F 150
Toshiba 35A44 35" TV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
